Der Group,
after updating to OS X Yosemite the License data of Maple 18 are invalid. What can I do?
Yours
Berthold
Hi Maple friends.
If I have y=-x^2+9 and y=x+3, how can I find the area that is bounded by the functions?
Easy enough to calculate by hand, but I need to use Maple to check my answers. Most preferably I'd like to use the Maple context menu to get the result, but any solution will be appreciated.
Can anyone tell me where I can find tutorial explaining how to solve laplace transform? I need a tutorial that explains starting with simple resolution to advanced resolution.
Hi all;
I have following program for plotting numerous function using hybrid functions.
if g1(t) is arbitrary function and g2(t) is its approximate by hybrid functions, I want to have a table of g1(t)-g2(t) for different value of t. but the result is without numeric values. what part is wrong????
best wishes
OHB.mws
Mahmood   Dadkhah
Ph.D Candidate
Hi Everyone,
I have an expression that contains a second order derivative: EXPR:=ay''(x) + bz'(x) + cf'(x)+... The variable y  obeys an ordinary differential equation, y''(x) = f(y,x). I would like to replace the second order deriavtive in my expression with f(y,x). So far I have tried applyrule([y''(x)=f(y,x)],EXPR), subs(y''(x)=f(y,x),EXPR) and algsubs(y''(x)=f(y,x),EXPR) and nothing seems to work. Any helpful suggestions?
How to calculate the Amplitude of two combined sinusoidal of different frequency and phase of a general equation as:
A sin(\omega_1 t)+B sin(\omega_2 t+\theta)
I need to know if the Software Maple solve, step-by-step series of Fourier and Laplace transforms? The Maple command has to solve step by step series of Fourier and Laplace transforms? or commands show only the direct solution?
I have a set "EQ" containing N linear equations in N unknowns. The only symbolic variables in each "EQ[i]" are the unknowns. I want to write a procedure that derives the matrices "A" and "b" where A.x=b is the same linear system stored in "EQ". In other words, I want to write the linear system in the matrix form.
Can anyone guide me through writting such a procedure?
As an example do it with the system written in the following file.
Note: This procedure will be used for large linear systems (e.g. 2000 Equations, 2000 Unknowns) so it will be important that the procedure uses the least operations required.
LinearSystem.mw
I have a large system of linear algebraic equations that I want to solve (2005 Unknowns, 2005 Equations). I was wondering that what are the proper commands to use in maple for solving the system as fast as possible. Take a look at the files in the download link if you want to see the system of linear algebraic equations.
http://pc.cd/h79
Please provide me any suggesitons that you may think will be helpful like using other sofwares that are good in doing this work such as MATLAB or something else.
Thanks in Advance
Hi again,
I am lost... again. I worked with the Physics package and have obtained my result in form of a lengthy equation of commutators of non-commuting objects. So basically my problem is solved, except that I now want to compute some examples to see, if everything is correct. For that purpose I want to replace now the non-commuting objects with explicit matrices, compute the result and see if it agrees with numerical studies. However, I have no clue which command to use, because if I try it with subs, then the multiplication is of the wrong type and Maple won't multiply my matrices. I tried to use eval but wasn't successful.
Here is an exampe to see what I mean.
Test2.mw
Thank you for your time
NOh
The following MWE shows what I mean:
with(Physics):Setup(mathematical=true):
Setup(noncommutativeprefix={MX,MY,MZ});
test:=proc()
    local eq;
    eq:=-Commutator(MX,MY)-Commutator(MZ,MY);
    eq:=simplify(subs(MX=-MZ,eq));
    return eq;
test();  # yields -[-MZ,MY] - [MZ,MY]
%  # yields 0
Any ideas how I can solve this? I would like to return the simplified version.
how to convert legendre polynomials into system of polynomials of 3 variables for drawing sphere with this ideal?
is possible to draw sphere from system of monomial polynomials?
I wanted to get the following function integrated with Maple 17:
I used the following command to get a numerical solution for my choise of limits:
Unfortunately, I just get the Integral itself back. Also, taking pi/2 as the upper limit for x does improve anything. I also tried the AllSolutions option but it does not help as well as first trying to integrate only over y and leaving x as it is in order to get at least one integration done.
I hope someone can help. I do not necessarily need to solve it for myself, so if someone gets the result and posts it here, I'm okay with that. Anyway, being able to calculate it myself would be even better.
Hello everyone.
need to know what is the difference between use of GAMMA and gamma in maple.
thanks.
I call the MeijerG function in the matlab: MeijerG([[-.3], []], [[.8, 1.3, -.8, -.3, -1.3], []], 1.), and it return an error as follows:
Error, (in evalf/MeijerG) the function is not defined: corresponding GAMMA poles must not coincide.
But when I change the first parameter from -0.3 to -1.3, I can get the result.
So, can you help to explain it? how can I fixed it?
First 1365 1366 1367 1368 1369 1370 1371 Last Page 1367 of 2429
