hi
i want clear ss variable but i can not do it please help me.
my code:
a := Matrix([1, 2, 3, 4, 5]); S := {}; ss := {};
for k to 5 do
S := `union`(S, {op(DirectSearch:-SolveEquations([a(1, k)*x+2+y = 0, x+y = 0])[3])});
ss := map(proc (c) options operator, arrow; rhs(c) end proc, S);
aaa := op(ss[[1]]); bbb := op(ss[[2]]);
"i want clear ss and then make ss as ss:={} in loop"
"for example if clear command clear ss variable"
"clear(ss)"
"ss:={}"
end do
Does there exist a Frobenius Group which is not  neither a Dihedralgroup nor  Symm(3) ?
Best regards
Kurt Ewald
Hello those in Mapleprimes,
What I want to know is whether this is possible or not, and if possible, how should I write a code?
The following code works properly:
U:=(x,y)->(x^theta+y^theta+X)^(1/theta);
diff(U(x,y),x)/diff(U(x,y),y)=p/q;simplify(%);
But, what I want to ask is this. As for the part of simplify(%), I want to do it with a way which has me
feel more being from the former to latter.
That is, if ,for example, "diff(U(x,y),x)/diff(U(x,y),y)=p/q;@simplify;" works, it is better to me, though this does not work.
As the second part, @simplify, receives the result of the first part"diff(U(x,y),x)/diff(U(x,y),y)", it seems more
natural to me than to write simplify(%).
Can't I do this, in a meaning, reversal of operator to argument?
taro
I have a system of first order diff. equations which I would like to solve symbolically. Unfortunately, Maple does not solve the system. Do anybody have suggestions how can I solve this system (please see below):
diff(S(t), t) = -eta*(C[max]*w*N-alpha*Q(t))*K(t)*S(t)/(w*N*(S(t)+K(t))),
diff(K(t), t) = S(t)*((z*eta*alpha*(C[max]*w*N-alpha*Q(t))*S(t)-upsilon*(eta*alpha^2*Q(t)^2-2*C[max]*w*N*eta*alpha*Q(t)+((-N*w+z)*alpha+N*C[max]^2*w*eta)*N*w))*K(t)^2+(2*((1/2)*z*eta*(C[max]*w*N-alpha*Q(t))*S(t)+N*w*upsilon*(N*w-z)))*S(t)*alpha*K(t)+N*S(t)^2*w*alpha*upsilon*(N*w-z))/((K(t)^2*alpha*z+3*S(t)*K(t)*alpha*z+S(t)*(2*S(t)*z*alpha+upsilon*(C[max]*w*N-alpha*Q(t))))*(S(t)+K(t))*N*w),
diff(Q(t), t) = (-alpha*z*(z*eta*(C[max]*w*N-alpha*Q(t))*K(t)+N*w*upsilon*(N*w-z))*S(t)^2+(-z^2*eta*alpha*(C[max]*w*N-alpha*Q(t))*K(t)^2-(eta*alpha^2*Q(t)^2-2*C[max]*w*N*eta*alpha*Q(t)+N*w*((2*N*w-2*z)*alpha+N*C[max]^2*w*eta))*z*upsilon*K(t)-N*w*upsilon^2*(N*w-z)*(C[max]*w*N-alpha*Q(t)))*S(t)-N*w*z*alpha*upsilon*K(t)^2*(N*w-z))/((2*S(t)^2*alpha*z+(3*z*alpha*K(t)+upsilon*(C[max]*w*N-alpha*Q(t)))*S(t)+K(t)^2*alpha*z)*N*w*upsilon)
where initials conditions are:
S(0) = S0, K(0) = K0, Q(0) = Q0
Dmitry
I want to know whether there is a good way to modify the first expression to the second one below.
first expression:
> p+p^(-1/(theta-1))*sum(q[i]^(theta/(theta-1)), i = (1 .. n));
second expression:
> p^(-1/(theta-1))*(p^(theta/(theta-1))+sum(q[i]^(theta/(theta-1)),i=1..n));
First and Second are the same. But, I want to know how I can modify from the former to the latter.
Thank you in advance.
taro
Let us consider the expression
f := log[x](1+(x^a-1)*(x^b-1)/(x-1));
Does it define a convex function on the interval 0..1 and on the interval 1..infinity if the parameters a>0, a< 1, b >0, b <1?
My try is
At the same time I have got problems in the general case. For example,
Error, (in @) too many levels of recursion
That's all right if
convex.mw
very slow cause my computer have sound and overheat, still can not
calculated result
%c := Old_Asso_eigenvector1, a := Old_Asso_eigenvector3,
%b := Old_Asso_eigenvector2
% b <= c, a <= c,
% a ^ c = a, a V c = c
% b ^ c = b, b V c = c
with(ExcelTools):
with(ListTools):
with(DynamicSystems):
filename := "1207.HK";
open3 := Import(cat(cat("C://Temp//HK//Coal//",filename),".xls"), filename, "B2:B100");
high3 := Import(cat(cat("C://Temp//HK//Coal//",filename),".xls"), filename, "C2:C100");
low3 := Import(cat(cat("C://Temp//HK//Coal//",filename),".xls"), filename, "D2:D100");
close3 := Import(cat(cat("C://Temp//HK//Coal//",filename),".xls"), filename, "E2:E100");
with(CurveFitting):
n := 31;
f := Vector(n);
f2 := Vector(n);
open2 := Vector(n);high2 := Vector(n);gain2 := Vector(n);algebra2 := Vector(n);creative2 := Vector(n);creative3 := Vector(n);
upper2 := Vector(n);lower2 := Vector(n);upperloweratio := Vector(n);
deltaopen2 := Vector(n); deltahigh2 := Vector(n); deltalow2 := Vector(n); deltaclose2 := Vector(n);
logn := Vector(n);
for i from 0 to n-4 do
open2[i+1] := PolynomialInterpolation([[0,open3[n-i][1]],[1,open3[n-(i+1)][1]],[2,open3[n-(i+2)][1]],[4,open3[n-(i+3)][1]]],t):
high2[i+1] := PolynomialInterpolation([[0,high3[n-i][1]],[1,high3[n-(i+1)][1]],[2,high3[n-(i+2)][1]],[4,high3[n-(i+3)][1]]],t):
low2[i+1] := PolynomialInterpolation([[0,low3[n-i][1]],[1,low3[n-(i+1)][1]],[2,low3[n-(i+2)][1]],[4,low3[n-(i+3)][1]]],t):
if (close3[i+1][1]/close3[i+2][1]-1) < 0 then
gain2[i+1] := -1*round(100*abs(close3[i+1][1]/close3[i+2][1]-1)):
gain2[i+1] := round(abs(100*(close3[i+1][1]/close3[i+2][1]-1))):
deltaclose2[i+1] := close3[i+1][1] - close3[i+2][1];
deltahigh2[i+1] := high3[i+1][1] - high3[i+2][1];
deltaopen2[i+1] := open3[i+1][1] - open3[i+2][1];
logn[i+1] := ln(close3[i+1][1]/close3[i+2][1]);
f[i+1] := (high2[i+1] - open2[i+1])/4*1.8:
f2[i+1] := (open2[i+1] - low2[i+1])/4*1.8:
creative2[i+1] := simplify(((((close3[i+1][1]-close3[i+2][1]) + x)^2 -(close3[i+1][1]-close3[i+2][1])^2))/x)-x;
creative3[i+1] := simplify(((((close3[i+1][1]-close3[i+2][1]) + x)^3 -(close3[i+1][1]-close3[i+2][1])^3))/x);
upper2[i+1] := high3[i+1]-close3[i+1];
lower2[i+1] := close3[i+1]-low3[i+1];
upperloweratio[i+1] := round((lower2[i+1]/upper2[i+1])[1]);
od;
HilbertConj := proc(Px,Py)
return MatrixMatrixMultiply(Px,Py);
HilbertDisj := proc(Px,Py)
return Px+Py- MatrixMatrixMultiply(Px,Py);
t:=1;
i := 0;
InputMatrix3 := Matrix([[xxx, close3(t+1+i) , close3(t+2+i)],
[close3(t+1+i) , close3(t+2+i),0],
[close3(t+2+i),0 , 0]]):
InputMatrix3b := Matrix([[close3(t+1+i), close3(t+2+i) , close3(t+3+i)],
[close3(t+2+i) , close3(t+3+i),0],
[close3(t+3+i),0 , 0]]):
InputMatrix3c := Matrix([[close3(t+2+i), close3(t+3+i) , close3(t+4+i)],
[close3(t+3+i) , close3(t+4+i),0],
[close3(t+4+i),0 , 0]]):
m := MatrixMatrixMultiply(Transpose(InputMatrix3), InputMatrix3);
eigenvalues1 := Eigenvalues(m);
sys1 := MatrixMatrixMultiply(m-Matrix([[eigenvalues1[1],0,0],[0,eigenvalues1[1],0],[0,0,eigenvalues1[1]]]), Matrix([[x],[y],[z]]));
%solve([sys1[1][1],sys1[2][1],sys1[3][1]], [x,y,z]);
sol1 := solve([sys1[1][1],sys1[2][1]], [x,y,z]);
sys2 := MatrixMatrixMultiply(m-Matrix([[eigenvalues1[2],0,0],[0,eigenvalues1[2],0],[0,0,eigenvalues1[2]]]), Matrix([[x],[y],[z]]));
%solve([sys2[1][1],sys2[2][1],sys2[3][1]], [x,y,z]);
sol2 := solve([sys2[1][1],sys2[2][1]], [x,y,z]);
sys3 := MatrixMatrixMultiply(m-Matrix([[eigenvalues1[3],0,0],[0,eigenvalues1[3],0],[0,0,eigenvalues1[3]]]), Matrix([[x],[y],[z]]));
%solve([sys3[1][1],sys3[2][1],sys3[3][1]], [x,y,z]);
sol3 := solve([sys3[1][1],sys3[2][1]], [x,y,z]);
Old_Asso_eigenvector1 := Matrix([[rhs(sol1[1][1]),rhs(sol2[1][1]),rhs(sol3[1][1])],[rhs(sol1[1][2]),rhs(sol2[1][2]),rhs(sol3[1][2])],[rhs(sol1[1][3]),rhs(sol2[1][3]),rhs(sol3[1][3])]]);
Old_Asso_eigenvector2 := Eigenvectors(MatrixMatrixMultiply(Transpose(InputMatrix3b), InputMatrix3b)):
Old_Asso_eigenvector3 := Eigenvectors(MatrixMatrixMultiply(Transpose(InputMatrix3c), InputMatrix3c)):
% b <= c, a <= c, c := Old_Asso_eigenvector1, a := Old_Asso_eigenvector3, b := Old_Asso_eigenvector2
testa := HilbertConj(Old_Asso_eigenvector3[2], Old_Asso_eigenvector1);
testb := HilbertDisj(Old_Asso_eigenvector3[2], Old_Asso_eigenvector1);
testc := HilbertConj(Old_Asso_eigenvector2[2], Old_Asso_eigenvector1);
testd := HilbertDisj(Old_Asso_eigenvector2[2], Old_Asso_eigenvector1);
sysa := testa[1][1] = Old_Asso_eigenvector3[2][1][1];
sysb := testb[1][1] = Old_Asso_eigenvector1[2][1][1];
sysc := testc[1][1] = Old_Asso_eigenvector2[2][1][1];
sysd := testd[1][1] = Old_Asso_eigenvector1[2][1][1];
solve(sysa, xxx);
I'm trying to plot the regions of a cube that are defined by an inequality. At the moment I am able to plot only the surface defined by the corresponding equality.
That's the code:
with(plots)
implicitplot3d(x^2*y = z, z = 0 .. 1, y = 0 .. 1, x = 0 .. 1);
Now I would like to plot the two regions defined by the corresponding inequality.
Have you got any idea on how to do this?
Bests
Manuele
Hi My main problem is that the new installer is ridiculously small that I cannot even press the buttons acuratley. I am running windows 8.1 on a Surface Pro 2. I had no problems installing maple 17.
I also ran into errors using the Bitrock installer 3 times, I am not even sure if it is installed correctly now.
is there anyway to get maple 18 without using the Bitrock installer?
Hello guys ...
I used a numerically method to solve couple differential equation that it has some boundary conditions. My problem is that some range of answers has 50% error . Do you know things for improving our answers in maple ?
my problem is :
a*Φ''''(x)+b*Φ''(x)+c*Φ(x)+d*Ψ''(x)+e*Ψ(x):=0
d*Φ''(x)+e*Φ(x)+j*Ψ''(x)+h*Ψ(x):=0
suggestion method by preben Alsholm:
a,b,c,d,e,j,h are constants.suppose some numbers for these constants . I used this code:
VR22:=0.1178*diff(phi(x),x,x,x,x)-0.2167*diff(phi(x),x,x)+0.0156*diff(psi(x),x,x)+0.2852*phi(x)+0.0804*psi(x);
VS22:=0.3668*diff(psi(x),x,x)-0.0156*diff(phi(x),x,x)-0.8043*psi(x)-0.80400*phi(x);
bok:=evalf(dsolve({VR22=0,VS22=0}));
PHI,PSI:=op(subs(bok,[phi(x),psi(x)]));
Eqs:={eval(PHI,x=1.366)=1,eval(diff(PHI,x),x=1.366)=0,eval(PHI,x=-1.366)=1,eval(diff(PHI,x),x=-1.366)=0,
eval(PSI,x=1.366)=1,eval(PSI,x=1.366)=1};
C:=fsolve(Eqs,indets(%,name));
eval(bok,C);
SOL:=fnormal(evalc(%));
I used digits for my code at the first of writting.
please help me ... what should i do?
X belongto A, eigenvector(X) = 0
from this statement ,
using linearalgebra package eigenvectors function
the eigenvector matrix [3][1],[3][2],[3][3] are 1 , contradict 1=0
so, need to find another kind of eigenvector in terms of algebra
using original basic calculation solve, however got error
m := Matrix([[a1,a2,a3],[a4,a5,a6],[a7,a8,a9]]);
eigenvector1 := Eigenvectors(m);
solve(
[eigenvector1[2][1][1]=0, eigenvector1[2][1][2]=0, eigenvector1[2][1][3]=0,
eigenvector1[2][2][1]=0, eigenvector1[2][2][2]=0, eigenvector1[2][2][3]=0,
eigenvector1[2][3][1]=0, eigenvector1[2][3][2]=0, eigenvector1[2][3][3]=0]
solve(
eigenvector1[2][2][1]=0, eigenvector1[2][2][2]=0, eigenvector1[2][2][3]=0]
eigenvalue1 :=
(1/6)*(36*a7*a1*a3+108*a7*a2*a6+108*a8*a4*a3+36*a8*a5*a6
eigenvalue2 :=
-(1/12)*(36*a7*a1*a3+108*a7*a2*a6+108*a8*a4*a3+36*a8*a5*a6
eigenvalue3 :=
solve(MatrixMatrixMultiply(Matrix([[a1,a2,a3],[a4,a5,a6],[a7,a8,a9]])-Matrix([[eigenvalue1,0,0],[0,eigenvalue1,0],[0,0,eigenvalue1]]), Matrix([[x],[y],[z]])),[x,y,z]);
solve(MatrixMatrixMultiply(Matrix([[a1,a2,a3],[a4,a5,a6],[a7,a8,a9]])-Matrix([[eigenvalue2,0,0],[0,eigenvalue2,0],[0,0,eigenvalue2]]), Matrix([[x],[y],[z]])),[x,y,z]);
solve(MatrixMatrixMultiply(Matrix([[a1,a2,a3],[a4,a5,a6],[a7,a8,a9]])-Matrix([[eigenvalue3,0,0],[0,eigenvalue3,0],[0,0,eigenvalue3]]), Matrix([[x],[y],[z]])),[x,y,z]);
got error when using solve
> solve(MatrixMatrixMultiply(Matrix([[a1, a2, a3], [a4, a5, a6], [a7, a8, a9]])-Matrix([[eigenvalue1, 0, 0], [0, eigenvalue1, 0], [0, 0, eigenvalue1]]), Matrix([[x], [y], [z]])), [x, y, z]);
Error, invalid input: solve expects its 1st argument, eqs, to be of type {`and`, `not`, `or`, algebraic, relation(algebraic), ({set, list})({`and`, `not`, `or`, algebraic, relation(algebraic)})}, but received Matrix(3, 1, {(1, 1) = ((2/3)*a1-(1/6)*(36*a7*a1*a3+108*a7*a2*a6+108*a8*a4*a3+36*a8*a6*a5-72*a7*a3*a5-72*a8*a6*a1-72*a9*a4*a2+48*a9*a5*a1-12*a9*a1^2-12*a5*a1^2+8*a1^3-12*a9^2*a1-12*a5^2*a1-12*a9^2*a5-12*a9*a5^2+36*a8*a6*a9+36*a7*a3*a9+36*a4*a2*a1+36*a4*a2*a5+8*a9^3+8*a5^3+12*(54*a7*a2^2*a6*a4*a1+114*a8*a6*a9*a1*a4*a2+6*a8*a6*a9*a1*a7*a3+54*a8*a4*a3^2*a7*a9-60*a9*a1^2*a8*a6*a5-60*a8*a6*a7*a3*a5^2-60*a8*a6*a4*a2*a9^2-24*a9*a1*a4^2*a2^2+6*...
MatrixOperation := module() option package;  export `+`, LinearAlgebra;
    `+` := proc(a::float, b::float) option overload;
 :-`+`(map(x->x^2,a),map(x->x^2,b));
end module;
with(MatrixOperation);
m := Matrix([[1,2],[3,4]]);
L := MatrixMatrixMultiply(m,m);
1 2  1 2
3 4  3 4
1*1+2*3 = 1 + 6 = 1 after overload + with a+b-a*b
1*2+2*4 = 2 + 8 = -6
L should be Matrix([[1, -6],[....]])
 http://en.wikibooks.org/wiki/Linear_Algebra/
Representing_Linear_Maps_with_Matrices
how to calculate the first step
(2,0) -> (1,1,1) and (1,4) -> (1,2,0)
how to use maple command to get (1,1,1) and (1,2,0)
how to use maple command to calculate rep(h)
to get (0,-1/2,1) and (1,-1,0)
/Representing_Linear_Maps_with_Matrices
hello evreybody i have these Error :
restart:with(plots):
mb:=765; mp:=587;Ib:=76.3*10^3;Ip:=7.3*10^3; l:=0.92; d:=10; F:=1.2; omega:=0.43;g:=9.81;ly:=3;k:=0.02001014429;h:=3;a:=30;b:=15;
765
587
76300.0
7300.0
.92
10
1.2
.43
9.81
0.2001014429e-1
30
15
A:=(1000*g)/2;
4905.00
v:=1/tan(theta(t));
1/tan(theta(t))
s:=(1000*F*g*sin(omega*t-k*x(t)))/k*sinh(k*h);
35337.21492*sin(.43*t-0.2001014429e-1*x(t))
n:=49.97465213;
49.97465213
Z:=z(t)-a/2*sin(theta(t))+b/2*cos(theta(t));
z(t)-15*sin(theta(t))+(15/2)*cos(theta(t))
Za:=z(t)+a/2*sin(theta(t))+b/2*cos(theta(t));
z(t)+15*sin(theta(t))+(15/2)*cos(theta(t))
eq1:=(mp+mb)*diff(x(t),t$2)+mp*(d*cos(theta(t))+l*cos(alpha(t)+theta(t)))*diff(theta(t),t$2)+mp*l*cos(alpha(t)+theta(t))*diff(alpha(t),t$2)+mp*(d*diff(theta(t),t)^2*sin(theta(t))+l*(diff(theta(t),t)+diff(alpha(t),t))^2*sin(alpha(t)+theta(t)))+A*(Z)^2+s*(sinh(k*(h+Z))-sinh(k*h))-A*(Za)^2-s*(sinh(k*(h+Za))-sinh(k*h))+A*(Za^2-Z^2)-s*(sinh(k*(h+Za))-sinh(k*(h+Z)))=0;
1352*(diff(diff(x(t), t), t))+587*(10*cos(theta(t))+.92*cos(alpha(t)+theta(t)))*(diff(diff(theta(t), t), t))+540.04*cos(alpha(t)+theta(t))*(diff(diff(alpha(t), t), t))+5870*(diff(theta(t), t))^2*sin(theta(t))+540.04*(diff(theta(t), t)+diff(alpha(t), t))^2*sin(alpha(t)+theta(t))+35337.21492*sin(.43*t-0.2001014429e-1*x(t))*(sinh(0.6003043287e-1+0.2001014429e-1*z(t)-.3001521644*sin(theta(t))+.1500760822*cos(theta(t)))-0.6006649417e-1)-35337.21492*sin(.43*t-0.2001014429e-1*x(t))*(sinh(0.6003043287e-1+0.2001014429e-1*z(t)+.3001521644*sin(theta(t))+.1500760822*cos(theta(t)))-0.6006649417e-1)-35337.21492*sin(.43*t-0.2001014429e-1*x(t))*(sinh(0.6003043287e-1+0.2001014429e-1*z(t)+.3001521644*sin(theta(t))+.1500760822*cos(theta(t)))-sinh(0.6003043287e-1+0.2001014429e-1*z(t)-.3001521644*sin(theta(t))+.1500760822*cos(theta(t)))) = 0
eq2:=(mp+mb)*diff(z(t),t$2)-mp*d*(sin(theta(t)+alpha(t))+sin(theta(t)))*diff(theta(t),t$2)-mp*l*sin(alpha(t)+theta(t))*diff(alpha(t),t$2)+mp*(d*diff(theta(t),t)^2*cos(theta(t))+l*(diff(theta(t),t)+diff(alpha(t),t))^2*cos(alpha(t)+theta(t)))-A*tan(theta(t))*(Z)^2-s*tan(theta(t))*(sinh(k*(h+Z))-sin(k*h))+A*tan(theta(t))*(Za)^2+s*tan(theta(t))*(sinh(k*(h+Za))-sin(k*h))+A*v*(Za^2-Z^2)+s*v*(sinh(k*(h+Za))-sinh(k*(h+Z)))=0;
1352*(diff(diff(z(t), t), t))-5870*(sin(alpha(t)+theta(t))+sin(theta(t)))*(diff(diff(theta(t), t), t))-540.04*sin(alpha(t)+theta(t))*(diff(diff(alpha(t), t), t))+5870*(diff(theta(t), t))^2*cos(theta(t))+540.04*(diff(theta(t), t)+diff(alpha(t), t))^2*cos(alpha(t)+theta(t))-4905.00*tan(theta(t))*(z(t)-15*sin(theta(t))+(15/2)*cos(theta(t)))^2-35337.21492*sin(.43*t-0.2001014429e-1*x(t))*tan(theta(t))*(sinh(0.6003043287e-1+0.2001014429e-1*z(t)-.3001521644*sin(theta(t))+.1500760822*cos(theta(t)))-0.5999438456e-1)+4905.00*tan(theta(t))*(z(t)+15*sin(theta(t))+(15/2)*cos(theta(t)))^2+35337.21492*sin(.43*t-0.2001014429e-1*x(t))*tan(theta(t))*(sinh(0.6003043287e-1+0.2001014429e-1*z(t)+.3001521644*sin(theta(t))+.1500760822*cos(theta(t)))-0.5999438456e-1)+4905.00*(-(z(t)-15*sin(theta(t))+(15/2)*cos(theta(t)))^2+(z(t)+15*sin(theta(t))+(15/2)*cos(theta(t)))^2)/tan(theta(t))+35337.21492*sin(.43*t-0.2001014429e-1*x(t))*(sinh(0.6003043287e-1+0.2001014429e-1*z(t)+.3001521644*sin(theta(t))+.1500760822*cos(theta(t)))-sinh(0.6003043287e-1+0.2001014429e-1*z(t)-.3001521644*sin(theta(t))+.1500760822*cos(theta(t))))/tan(theta(t)) = 0
eq3:=mp*(d*cos(theta(t))+l*cos(alpha(t)+theta(t)))*diff(x(t),t$2)-mp*(l*sin(theta(t)+alpha(t))+d*sin(theta(t)))*diff(z(t),t$2)+(Ip+Ib+mp*(d^2+l^2)+2*mp*d*l*cos(alpha(t)))*diff(theta(t),t$2)+(Ip+mp*l^2+mp*d*l*cos(alpha(t)))*diff(alpha(t),t$2)-mp*sin(alpha(t))*(l*d*diff(alpha(t),t)^2-l*d*(diff(alpha(t),t)+diff(theta(t),t))^2)+mp*9.81*l*sin(alpha(t)+theta(t))+mp*9.81*d*sin(theta(t))=0;
587*(10*cos(theta(t))+.92*cos(alpha(t)+theta(t)))*(diff(diff(x(t), t), t))-587*(.92*sin(alpha(t)+theta(t))+10*sin(theta(t)))*(diff(diff(z(t), t), t))+(142796.8368+10800.80*cos(alpha(t)))*(diff(diff(theta(t), t), t))+(7796.8368+5400.40*cos(alpha(t)))*(diff(diff(alpha(t), t), t))-587*sin(alpha(t))*(9.20*(diff(alpha(t), t))^2-9.20*(diff(theta(t), t)+diff(alpha(t), t))^2)+5297.7924*sin(alpha(t)+theta(t))+57584.70*sin(theta(t)) = 0
eq4:=mp*l*cos(alpha(t)+theta(t))*diff(x(t),t$2)-mp*l*sin(alpha(t)+theta(t))*diff(z(t),t$2)+(Ip+mp*l^2+mp*d*l*cos(alpha(t)))*diff(theta(t),t$2)+(Ip+mp*l^2)*diff(alpha(t),t$2)-mp*9.81*l*sin(alpha(t)+theta(t))+l*d*mp*diff(theta(t),t$1)^2*sin(alpha(t))=0;
540.04*cos(alpha(t)+theta(t))*(diff(diff(x(t), t), t))-540.04*sin(alpha(t)+theta(t))*(diff(diff(z(t), t), t))+(7796.8368+5400.40*cos(alpha(t)))*(diff(diff(theta(t), t), t))+7796.8368*(diff(diff(alpha(t), t), t))-5297.7924*sin(alpha(t)+theta(t))+5400.40*(diff(theta(t), t))^2*sin(alpha(t)) = 0
CI:= x(0)=0,z(0)=3,theta(0)=0,alpha(0)=0,D(x)(0)=0,D(alpha)(0)=0,D(z)(0)=0,D(theta)(0)=0;
x(0) = 0, z(0) = 3, theta(0) = 0, alpha(0) = 0, (D(x))(0) = 0, (D(alpha))(0) = 0, (D(z))(0) = 0, (D(theta))(0) = 0
solution:=dsolve([eq1,eq2,eq3,eq4,CI],numeric,maxfun=0);
proc (x_rkf45) local _res, _dat, _vars, _solnproc, _xout, _ndsol, _pars, _n, _i; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; if 1 < nargs then error "invalid input: too many arguments" end if; _EnvDSNumericSaveDigits := Digits; Digits := 15; if _EnvInFsolve = true then _xout := evalf[_EnvDSNumericSaveDigits](x_rkf45) else _xout := evalf(x_rkf45) end if; _dat := Array(1..4, {(1) = proc (_xin) local _xout, _dtbl, _dat, _vmap, _x0, _y0, _val, _dig, _n, _ne, _nd, _nv, _pars, _ini, _par, _i, _j, _k, _src; option `Copyright (c) 2002 by Waterloo Maple Inc. All rights reserved.`; table( [( "complex" ) = false ] ) _xout := _xin; _pars := []; _dtbl := array( 1 .. 4, [( 1 ) = (array( 1 .. 20, [( 1 ) = (datatype = float[8], order = C_order, storage = rectangular), ( 2 ) = (datatype = float[8], order = C_order, storage = rectangular), ( 3 ) = ([0, 0, 0, Array(1..0, 1..2, {}, datatype = float[8], order = C_order)]), ( 5 ) = (Array(1..28, {(1) = .0, (2) = 0.10e-5, (3) = .0, (4) = 0.500001e-14, (5) = .0, (6) = undefined, (7) = .0, (8) = 0.10e-5, (9) = .0, (10) = .0, (11) = .0, (12) = .0, (13) = 1.0, (14) = .0, (15) = .49999999999999, (16) = .0, (17) = 1.0, (18) = 1.0, (19) = .0, (20) = .0, (21) = 1.0, (22) = 1.0, (23) = .0, (24) = .0, (25) = 0.10e-14, (26) = .0, (27) = .0, (28) = .0}, datatype = float[8], order = C_order)), ( 4 ) = (Array(1..53, {(1) = 8, (2) = 8, (3) = 0, (4) = 0, (5) = 0, (6) = 0, (7) = 1, (8) = 0, (9) = 0, (10) = 0, (11) = 0, (12) = 0, (13) = 0, (14) = 0, (15) = 0, (16) = 0, (17) = 0, (18) = 1, (19) = 0, (20) = 0, (21) = 1, (22) = 1, (23) = 4, (24) = 0, (25) = 1, (26) = 15, (27) = 1, (28) = 0, (29) = 1, (30) = 3, (31) = 3, (32) = 0, (33) = 1, (34) = 0, (35) = 0, (36) = 0, (37) = 0, (38) = 0, (39) = 0, (40) = 0, (41) = 0, (42) = 0, (43) = 1, (44) = 0, (45) = 0, (46) = 0, (47) = 0, (48) = 0, (49) = 0, (50) = 50, (51) = 1, (52) = 0, (53) = 0}, datatype = integer[4])), ( 7 ) = ([Array(1..4, 1..7, {(1, 1) = .0, (1, 2) = .203125, (1, 3) = .3046875, (1, 4) = .75, (1, 5) = .8125, (1, 6) = .40625, (1, 7) = .8125, (2, 1) = 0.6378173828125e-1, (2, 2) = .0, (2, 3) = .279296875, (2, 4) = .27237892150878906, (2, 5) = -0.9686851501464844e-1, (2, 6) = 0.1956939697265625e-1, (2, 7) = .5381584167480469, (3, 1) = 0.31890869140625e-1, (3, 2) = .0, (3, 3) = -.34375, (3, 4) = -.335235595703125, (3, 5) = .2296142578125, (3, 6) = .41748046875, (3, 7) = 11.480712890625, (4, 1) = 0.9710520505905151e-1, (4, 2) = .0, (4, 3) = .40350341796875, (4, 4) = 0.20297467708587646e-1, (4, 5) = -0.6054282188415527e-2, (4, 6) = -0.4770040512084961e-1, (4, 7) = .77858567237854}, datatype = float[8], order = C_order), Array(1..6, 1..6, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (1, 5) = .0, (1, 6) = 1.0, (2, 1) = .25, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (2, 5) = .0, (2, 6) = 1.0, (3, 1) = .1875, (3, 2) = .5625, (3, 3) = .0, (3, 4) = .0, (3, 5) = .0, (3, 6) = 2.0, (4, 1) = .23583984375, (4, 2) = -.87890625, (4, 3) = .890625, (4, 4) = .0, (4, 5) = .0, (4, 6) = .2681884765625, (5, 1) = .1272735595703125, (5, 2) = -.5009765625, (5, 3) = .44921875, (5, 4) = -0.128936767578125e-1, (5, 5) = .0, (5, 6) = 0.626220703125e-1, (6, 1) = -0.927734375e-1, (6, 2) = .626220703125, (6, 3) = -.4326171875, (6, 4) = .1418304443359375, (6, 5) = -0.861053466796875e-1, (6, 6) = .3131103515625}, datatype = float[8], order = C_order), Array(1..6, {(1) = .0, (2) = .386, (3) = .21, (4) = .63, (5) = 1.0, (6) = 1.0}, datatype = float[8], order = C_order), Array(1..6, {(1) = .25, (2) = -.1043, (3) = .1035, (4) = -0.362e-1, (5) = .0, (6) = .0}, datatype = float[8], order = C_order), Array(1..6, 1..5, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (1, 5) = .0, (2, 1) = 1.544, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (2, 5) = .0, (3, 1) = .9466785280815533, (3, 2) = .25570116989825814, (3, 3) = .0, (3, 4) = .0, (3, 5) = .0, (4, 1) = 3.3148251870684886, (4, 2) = 2.896124015972123, (4, 3) = .9986419139977808, (4, 4) = .0, (4, 5) = .0, (5, 1) = 1.2212245092262748, (5, 2) = 6.019134481287752, (5, 3) = 12.537083329320874, (5, 4) = -.687886036105895, (5, 5) = .0, (6, 1) = 1.2212245092262748, (6, 2) = 6.019134481287752, (6, 3) = 12.537083329320874, (6, 4) = -.687886036105895, (6, 5) = 1.0}, datatype = float[8], order = C_order), Array(1..6, 1..5, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (1, 5) = .0, (2, 1) = -5.6688, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (2, 5) = .0, (3, 1) = -2.4300933568337584, (3, 2) = -.20635991570891224, (3, 3) = .0, (3, 4) = .0, (3, 5) = .0, (4, 1) = -.10735290581452621, (4, 2) = -9.594562251021896, (4, 3) = -20.470286148096154, (4, 4) = .0, (4, 5) = .0, (5, 1) = 7.496443313968615, (5, 2) = -10.246804314641219, (5, 3) = -33.99990352819906, (5, 4) = 11.708908932061595, (5, 5) = .0, (6, 1) = 8.083246795922411, (6, 2) = -7.981132988062785, (6, 3) = -31.52159432874373, (6, 4) = 16.319305431231363, (6, 5) = -6.0588182388340535}, datatype = float[8], order = C_order), Array(1..3, 1..5, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (1, 5) = .0, (2, 1) = 10.126235083446911, (2, 2) = -7.487995877607633, (2, 3) = -34.800918615557414, (2, 4) = -7.9927717075687275, (2, 5) = 1.0251377232956207, (3, 1) = -.6762803392806898, (3, 2) = 6.087714651678606, (3, 3) = 16.43084320892463, (3, 4) = 24.767225114183653, (3, 5) = -6.5943891257167815}, datatype = float[8], order = C_order)]), ( 6 ) = (Array(1..8, {(1) = .0, (2) = .0, (3) = .0, (4) = .0, (5) = .0, (6) = .0, (7) = 3.0, (8) = .0}, datatype = float[8], order = C_order)), ( 10 ) = ([proc (N, X, Y, YP) option `[Y[1] = alpha(t), Y[2] = diff(alpha(t),t), Y[3] = theta(t), Y[4] = diff(theta(t),t), Y[5] = x(t), Y[6] = diff(x(t),t), Y[7] = z(t), Y[8] = diff(z(t),t)]`; YP[2] := -(1352*(7796.8368+5400.40*cos(Y[1]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))+1352*(7796.8368+5400.40*cos(Y[1]))*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))-1827904*(7796.8368+5400.40*cos(Y[1]))*(-587*sin(Y[1])*(9.20*Y[2]^2-9.20*(Y[4]+Y[2])^2)+5297.7924*sin(Y[1]+Y[3])+57584.70*sin(Y[3]))-730134.08*cos(Y[1]+Y[3])*(142796.8368+10800.80*cos(Y[1]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))-540.04*cos(Y[1]+Y[3])*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))+540.04*cos(Y[1]+Y[3])*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))+730134.08*cos(Y[1]+Y[3])*(-587*sin(Y[1])*(9.20*Y[2]^2-9.20*(Y[4]+Y[2])^2)+5297.7924*sin(Y[1]+Y[3])+57584.70*sin(Y[3]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))+730134.08*sin(Y[1]+Y[3])*(142796.8368+10800.80*cos(Y[1]))*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))-540.04*sin(Y[1]+Y[3])*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))^2*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))+540.04*sin(Y[1]+Y[3])*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-730134.08*sin(Y[1]+Y[3])*(-587*sin(Y[1])*(9.20*Y[2]^2-9.20*(Y[4]+Y[2])^2)+5297.7924*sin(Y[1]+Y[3])+57584.70*sin(Y[3]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))+1827904*(-5297.7924*sin(Y[1]+Y[3])+5400.40*Y[4]^2*sin(Y[1]))*(142796.8368+10800.80*cos(Y[1]))-1352*(-5297.7924*sin(Y[1]+Y[3])+5400.40*Y[4]^2*sin(Y[1]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))^2-1352*(-5297.7924*sin(Y[1]+Y[3])+5400.40*Y[4]^2*sin(Y[1]))*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3])))/(2035121836544224.7506+153931588575265.01376*cos(Y[1])-10541323.3536*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))^2-10541323.3536*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-1827904*(7796.8368+5400.40*cos(Y[1]))^2+1460268.16*(7796.8368+5400.40*cos(Y[1]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*cos(Y[1]+Y[3])-730134.08*(7796.8368+5400.40*cos(Y[1]))*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*sin(Y[1]+Y[3])-394301608.5632*cos(Y[1]+Y[3])^2*(142796.8368+10800.80*cos(Y[1]))+291643.2016*cos(Y[1]+Y[3])^2*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))+291643.2016*cos(Y[1]+Y[3])*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*sin(Y[1]+Y[3])-730134.08*sin(Y[1]+Y[3])*(7796.8368+5400.40*cos(Y[1]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-394301608.5632*sin(Y[1]+Y[3])^2*(142796.8368+10800.80*cos(Y[1]))+291643.2016*sin(Y[1]+Y[3])*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*cos(Y[1]+Y[3])*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))+291643.2016*sin(Y[1]+Y[3])^2*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))^2); YP[4] := (10541323.3536*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))+10541323.3536*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))+8365847205177.4464*sin(Y[1])*(9.20*Y[2]^2-9.20*(Y[4]+Y[2])^2)-75503444196167.489249*sin(Y[1]+Y[3])-820689610827907.49184*sin(Y[3])-730134.08*cos(Y[1]+Y[3])*(7796.8368+5400.40*cos(Y[1]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))-291643.2016*cos(Y[1]+Y[3])^2*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))-291643.2016*cos(Y[1]+Y[3])*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))*sin(Y[1]+Y[3])+394301608.5632*cos(Y[1]+Y[3])^2*(-587*sin(Y[1])*(9.20*Y[2]^2-9.20*(Y[4]+Y[2])^2)+5297.7924*sin(Y[1]+Y[3])+57584.70*sin(Y[3]))+730134.08*sin(Y[1]+Y[3])*(7796.8368+5400.40*cos(Y[1]))*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))-291643.2016*sin(Y[1]+Y[3])*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*cos(Y[1]+Y[3])*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))-291643.2016*sin(Y[1]+Y[3])^2*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))+394301608.5632*sin(Y[1]+Y[3])^2*(-587*sin(Y[1])*(9.20*Y[2]^2-9.20*(Y[4]+Y[2])^2)+5297.7924*sin(Y[1]+Y[3])+57584.70*sin(Y[3]))+1827904*(-5297.7924*sin(Y[1]+Y[3])+5400.40*Y[4]^2*sin(Y[1]))*(7796.8368+5400.40*cos(Y[1]))-730134.08*(-5297.7924*sin(Y[1]+Y[3])+5400.40*Y[4]^2*sin(Y[1]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*cos(Y[1]+Y[3])+730134.08*(-5297.7924*sin(Y[1]+Y[3])+5400.40*Y[4]^2*sin(Y[1]))*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*sin(Y[1]+Y[3]))/(2035121836544224.7506+153931588575265.01376*cos(Y[1])-10541323.3536*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))^2-10541323.3536*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-1827904*(7796.8368+5400.40*cos(Y[1]))^2+1460268.16*(7796.8368+5400.40*cos(Y[1]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*cos(Y[1]+Y[3])-730134.08*(7796.8368+5400.40*cos(Y[1]))*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*sin(Y[1]+Y[3])-394301608.5632*cos(Y[1]+Y[3])^2*(142796.8368+10800.80*cos(Y[1]))+291643.2016*cos(Y[1]+Y[3])^2*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))+291643.2016*cos(Y[1]+Y[3])*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*sin(Y[1]+Y[3])-730134.08*sin(Y[1]+Y[3])*(7796.8368+5400.40*cos(Y[1]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-394301608.5632*sin(Y[1]+Y[3])^2*(142796.8368+10800.80*cos(Y[1]))+291643.2016*sin(Y[1]+Y[3])*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*cos(Y[1]+Y[3])*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))+291643.2016*sin(Y[1]+Y[3])^2*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))^2); YP[6] := -(10541323.3536*(142796.8368+10800.80*cos(Y[1]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))+7796.8368*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))-7796.8368*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-10541323.3536*(-587*sin(Y[1])*(9.20*Y[2]^2-9.20*(Y[4]+Y[2])^2)+5297.7924*sin(Y[1]+Y[3])+57584.70*sin(Y[3]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))-1352*(7796.8368+5400.40*cos(Y[1]))^2*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))-540.04*(7796.8368+5400.40*cos(Y[1]))*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*cos(Y[1]+Y[3])*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))-540.04*(7796.8368+5400.40*cos(Y[1]))*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))*sin(Y[1]+Y[3])+730134.08*(7796.8368+5400.40*cos(Y[1]))*(-587*sin(Y[1])*(9.20*Y[2]^2-9.20*(Y[4]+Y[2])^2)+5297.7924*sin(Y[1]+Y[3])+57584.70*sin(Y[3]))*cos(Y[1]+Y[3])+540.04*sin(Y[1]+Y[3])*(7796.8368+5400.40*cos(Y[1]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))-540.04*sin(Y[1]+Y[3])*(7796.8368+5400.40*cos(Y[1]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-291643.2016*sin(Y[1]+Y[3])*(142796.8368+10800.80*cos(Y[1]))*cos(Y[1]+Y[3])*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))-291643.2016*sin(Y[1]+Y[3])^2*(142796.8368+10800.80*cos(Y[1]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))+291643.2016*sin(Y[1]+Y[3])*(-587*sin(Y[1])*(9.20*Y[2]^2-9.20*(Y[4]+Y[2])^2)+5297.7924*sin(Y[1]+Y[3])+57584.70*sin(Y[3]))*cos(Y[1]+Y[3])*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))+291643.2016*sin(Y[1]+Y[3])^2*(-587*sin(Y[1])*(9.20*Y[2]^2-9.20*(Y[4]+Y[2])^2)+5297.7924*sin(Y[1]+Y[3])+57584.70*sin(Y[3]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))+1352*(-5297.7924*sin(Y[1]+Y[3])+5400.40*Y[4]^2*sin(Y[1]))*(7796.8368+5400.40*cos(Y[1]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))-730134.08*(-5297.7924*sin(Y[1]+Y[3])+5400.40*Y[4]^2*sin(Y[1]))*(142796.8368+10800.80*cos(Y[1]))*cos(Y[1]+Y[3])+540.04*(-5297.7924*sin(Y[1]+Y[3])+5400.40*Y[4]^2*sin(Y[1]))*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*cos(Y[1]+Y[3])*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))+540.04*(-5297.7924*sin(Y[1]+Y[3])+5400.40*Y[4]^2*sin(Y[1]))*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*sin(Y[1]+Y[3]))/(2035121836544224.7506+153931588575265.01376*cos(Y[1])-10541323.3536*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))^2-10541323.3536*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-1827904*(7796.8368+5400.40*cos(Y[1]))^2+1460268.16*(7796.8368+5400.40*cos(Y[1]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*cos(Y[1]+Y[3])-730134.08*(7796.8368+5400.40*cos(Y[1]))*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*sin(Y[1]+Y[3])-394301608.5632*cos(Y[1]+Y[3])^2*(142796.8368+10800.80*cos(Y[1]))+291643.2016*cos(Y[1]+Y[3])^2*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))+291643.2016*cos(Y[1]+Y[3])*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*sin(Y[1]+Y[3])-730134.08*sin(Y[1]+Y[3])*(7796.8368+5400.40*cos(Y[1]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-394301608.5632*sin(Y[1]+Y[3])^2*(142796.8368+10800.80*cos(Y[1]))+291643.2016*sin(Y[1]+Y[3])*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*cos(Y[1]+Y[3])*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))+291643.2016*sin(Y[1]+Y[3])^2*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))^2); YP[8] := -(291643.2016*cos(Y[1]+Y[3])^2*(-587*sin(Y[1])*(9.20*Y[2]^2-9.20*(Y[4]+Y[2])^2)+5297.7924*sin(Y[1]+Y[3])+57584.70*sin(Y[3]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-540.04*(-5297.7924*sin(Y[1]+Y[3])+5400.40*Y[4]^2*sin(Y[1]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*cos(Y[1]+Y[3])*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))+1080.08*cos(Y[1]+Y[3])*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))*(7796.8368+5400.40*cos(Y[1]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))-291643.2016*cos(Y[1]+Y[3])^2*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))*(142796.8368+10800.80*cos(Y[1]))+730134.08*sin(Y[1]+Y[3])*(-5297.7924*sin(Y[1]+Y[3])+5400.40*Y[4]^2*sin(Y[1]))*(142796.8368+10800.80*cos(Y[1]))+10541323.3536*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))*(142796.8368+10800.80*cos(Y[1]))-7796.8368*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))^2-1352*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))*(7796.8368+5400.40*cos(Y[1]))^2+540.04*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))*sin(Y[1]+Y[3])*(7796.8368+5400.40*cos(Y[1]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))-291643.2016*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))*sin(Y[1]+Y[3])*cos(Y[1]+Y[3])*(142796.8368+10800.80*cos(Y[1]))+7796.8368*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-10541323.3536*(-587*sin(Y[1])*(9.20*Y[2]^2-9.20*(Y[4]+Y[2])^2)+5297.7924*sin(Y[1]+Y[3])+57584.70*sin(Y[3]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-540.04*cos(Y[1]+Y[3])*(7796.8368+5400.40*cos(Y[1]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))+291643.2016*cos(Y[1]+Y[3])*(-587*sin(Y[1])*(9.20*Y[2]^2-9.20*(Y[4]+Y[2])^2)+5297.7924*sin(Y[1]+Y[3])+57584.70*sin(Y[3]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*sin(Y[1]+Y[3])+1352*(-5297.7924*sin(Y[1]+Y[3])+5400.40*Y[4]^2*sin(Y[1]))*(7796.8368+5400.40*cos(Y[1]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-540.04*(-5297.7924*sin(Y[1]+Y[3])+5400.40*Y[4]^2*sin(Y[1]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))^2*sin(Y[1]+Y[3])-730134.08*sin(Y[1]+Y[3])*(7796.8368+5400.40*cos(Y[1]))*(-587*sin(Y[1])*(9.20*Y[2]^2-9.20*(Y[4]+Y[2])^2)+5297.7924*sin(Y[1]+Y[3])+57584.70*sin(Y[3])))/(2035121836544224.7506+153931588575265.01376*cos(Y[1])-10541323.3536*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))^2-10541323.3536*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-1827904*(7796.8368+5400.40*cos(Y[1]))^2+1460268.16*(7796.8368+5400.40*cos(Y[1]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*cos(Y[1]+Y[3])-730134.08*(7796.8368+5400.40*cos(Y[1]))*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*sin(Y[1]+Y[3])-394301608.5632*cos(Y[1]+Y[3])^2*(142796.8368+10800.80*cos(Y[1]))+291643.2016*cos(Y[1]+Y[3])^2*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))+291643.2016*cos(Y[1]+Y[3])*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*sin(Y[1]+Y[3])-730134.08*sin(Y[1]+Y[3])*(7796.8368+5400.40*cos(Y[1]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-394301608.5632*sin(Y[1]+Y[3])^2*(142796.8368+10800.80*cos(Y[1]))+291643.2016*sin(Y[1]+Y[3])*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*cos(Y[1]+Y[3])*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))+291643.2016*sin(Y[1]+Y[3])^2*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))^2); YP[1] := Y[2]; YP[3] := Y[4]; YP[5] := Y[6]; YP[7] := Y[8]; 0 end proc, -1, 0, 0, 0, 0, 0, 0]), ( 11 ) = (Array(1..6, 0..8, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (1, 5) = .0, (1, 6) = .0, (1, 7) = .0, (1, 8) = .0, (2, 0) = .0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (2, 5) = .0, (2, 6) = .0, (2, 7) = .0, (2, 8) = .0, (3, 0) = .0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0, (3, 4) = .0, (3, 5) = .0, (3, 6) = .0, (3, 7) = .0, (3, 8) = .0, (4, 0) = .0, (4, 1) = .0, (4, 2) = .0, (4, 3) = .0, (4, 4) = .0, (4, 5) = .0, (4, 6) = .0, (4, 7) = .0, (4, 8) = .0, (5, 0) = .0, (5, 1) = .0, (5, 2) = .0, (5, 3) = .0, (5, 4) = .0, (5, 5) = .0, (5, 6) = .0, (5, 7) = .0, (5, 8) = .0, (6, 0) = .0, (6, 1) = .0, (6, 2) = .0, (6, 3) = .0, (6, 4) = .0, (6, 5) = .0, (6, 6) = .0, (6, 7) = .0, (6, 8) = .0}, datatype = float[8], order = C_order)), ( 8 ) = ([Array(1..8, {(1) = .0, (2) = .0, (3) = .0, (4) = .0, (5) = .0, (6) = .0, (7) = .0, (8) = .0}, datatype = float[8], order = C_order), Array(1..8, {(1) = .0, (2) = .0, (3) = .0, (4) = .0, (5) = .0, (6) = .0, (7) = .0, (8) = .0}, datatype = float[8], order = C_order), Array(1..8, {(1) = .0, (2) = undefined, (3) = .0, (4) = undefined, (5) = .0, (6) = undefined, (7) = .0, (8) = undefined}, datatype = float[8], order = C_order)]), ( 9 ) = ([Array(1..8, {(1) = .1, (2) = .1, (3) = .1, (4) = .1, (5) = .1, (6) = .1, (7) = .1, (8) = .1}, datatype = float[8], order = C_order), Array(1..8, {(1) = .0, (2) = .0, (3) = .0, (4) = .0, (5) = .0, (6) = .0, (7) = .0, (8) = .0}, datatype = float[8], order = C_order), Array(1..8, {(1) = .0, (2) = .0, (3) = .0, (4) = .0, (5) = .0, (6) = .0, (7) = .0, (8) = .0}, datatype = float[8], order = C_order), Array(1..8, {(1) = .0, (2) = .0, (3) = .0, (4) = .0, (5) = .0, (6) = .0, (7) = .0, (8) = .0}, datatype = float[8], order = C_order), Array(1..8, {(1) = .0, (2) = .0, (3) = .0, (4) = .0, (5) = .0, (6) = .0, (7) = .0, (8) = .0}, datatype = float[8], order = C_order), Array(1..8, 1..8, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (1, 5) = .0, (1, 6) = .0, (1, 7) = .0, (1, 8) = .0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (2, 5) = .0, (2, 6) = .0, (2, 7) = .0, (2, 8) = .0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0, (3, 4) = .0, (3, 5) = .0, (3, 6) = .0, (3, 7) = .0, (3, 8) = .0, (4, 1) = .0, (4, 2) = .0, (4, 3) = .0, (4, 4) = .0, (4, 5) = .0, (4, 6) = .0, (4, 7) = .0, (4, 8) = .0, (5, 1) = .0, (5, 2) = .0, (5, 3) = .0, (5, 4) = .0, (5, 5) = .0, (5, 6) = .0, (5, 7) = .0, (5, 8) = .0, (6, 1) = .0, (6, 2) = .0, (6, 3) = .0, (6, 4) = .0, (6, 5) = .0, (6, 6) = .0, (6, 7) = .0, (6, 8) = .0, (7, 1) = .0, (7, 2) = .0, (7, 3) = .0, (7, 4) = .0, (7, 5) = .0, (7, 6) = .0, (7, 7) = .0, (7, 8) = .0, (8, 1) = .0, (8, 2) = .0, (8, 3) = .0, (8, 4) = .0, (8, 5) = .0, (8, 6) = .0, (8, 7) = .0, (8, 8) = .0}, datatype = float[8], order = C_order), Array(1..8, 1..8, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (1, 5) = .0, (1, 6) = .0, (1, 7) = .0, (1, 8) = .0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (2, 5) = .0, (2, 6) = .0, (2, 7) = .0, (2, 8) = .0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0, (3, 4) = .0, (3, 5) = .0, (3, 6) = .0, (3, 7) = .0, (3, 8) = .0, (4, 1) = .0, (4, 2) = .0, (4, 3) = .0, (4, 4) = .0, (4, 5) = .0, (4, 6) = .0, (4, 7) = .0, (4, 8) = .0, (5, 1) = .0, (5, 2) = .0, (5, 3) = .0, (5, 4) = .0, (5, 5) = .0, (5, 6) = .0, (5, 7) = .0, (5, 8) = .0, (6, 1) = .0, (6, 2) = .0, (6, 3) = .0, (6, 4) = .0, (6, 5) = .0, (6, 6) = .0, (6, 7) = .0, (6, 8) = .0, (7, 1) = .0, (7, 2) = .0, (7, 3) = .0, (7, 4) = .0, (7, 5) = .0, (7, 6) = .0, (7, 7) = .0, (7, 8) = .0, (8, 1) = .0, (8, 2) = .0, (8, 3) = .0, (8, 4) = .0, (8, 5) = .0, (8, 6) = .0, (8, 7) = .0, (8, 8) = .0}, datatype = float[8], order = C_order), Array(1..8, 1..6, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (1, 5) = .0, (1, 6) = .0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (2, 5) = .0, (2, 6) = .0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0, (3, 4) = .0, (3, 5) = .0, (3, 6) = .0, (4, 1) = .0, (4, 2) = .0, (4, 3) = .0, (4, 4) = .0, (4, 5) = .0, (4, 6) = .0, (5, 1) = .0, (5, 2) = .0, (5, 3) = .0, (5, 4) = .0, (5, 5) = .0, (5, 6) = .0, (6, 1) = .0, (6, 2) = .0, (6, 3) = .0, (6, 4) = .0, (6, 5) = .0, (6, 6) = .0, (7, 1) = .0, (7, 2) = .0, (7, 3) = .0, (7, 4) = .0, (7, 5) = .0, (7, 6) = .0, (8, 1) = .0, (8, 2) = .0, (8, 3) = .0, (8, 4) = .0, (8, 5) = .0, (8, 6) = .0}, datatype = float[8], order = C_order), Array(1..8, {(1) = 0, (2) = 0, (3) = 0, (4) = 0, (5) = 0, (6) = 0, (7) = 0, (8) = 0}, datatype = integer[4]), Array(1..8, {(1) = .0, (2) = .0, (3) = .0, (4) = .0, (5) = .0, (6) = .0, (7) = 3.0, (8) = .0}, datatype = float[8], order = C_order), Array(1..8, {(1) = .0, (2) = .0, (3) = .0, (4) = .0, (5) = .0, (6) = .0, (7) = .0, (8) = .0}, datatype = float[8], order = C_order), Array(1..8, {(1) = .0, (2) = .0, (3) = .0, (4) = .0, (5) = .0, (6) = .0, (7) = .0, (8) = .0}, datatype = float[8], order = C_order), Array(1..8, {(1) = .0, (2) = .0, (3) = .0, (4) = .0, (5) = .0, (6) = .0, (7) = .0, (8) = .0}, datatype = float[8], order = C_order)]), ( 15 ) = ("rkf45"), ( 14 ) = ([0, 0]), ( 13 ) = (), ( 12 ) = (), ( 20 ) = ([]), ( 16 ) = ([0, 0, 0, []]), ( 17 ) = ([proc (N, X, Y, YP) option `[Y[1] = alpha(t), Y[2] = diff(alpha(t),t), Y[3] = theta(t), Y[4] = diff(theta(t),t), Y[5] = x(t), Y[6] = diff(x(t),t), Y[7] = z(t), Y[8] = diff(z(t),t)]`; YP[2] := -(1352*(7796.8368+5400.40*cos(Y[1]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))+1352*(7796.8368+5400.40*cos(Y[1]))*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))-1827904*(7796.8368+5400.40*cos(Y[1]))*(-587*sin(Y[1])*(9.20*Y[2]^2-9.20*(Y[4]+Y[2])^2)+5297.7924*sin(Y[1]+Y[3])+57584.70*sin(Y[3]))-730134.08*cos(Y[1]+Y[3])*(142796.8368+10800.80*cos(Y[1]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))-540.04*cos(Y[1]+Y[3])*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))+540.04*cos(Y[1]+Y[3])*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))+730134.08*cos(Y[1]+Y[3])*(-587*sin(Y[1])*(9.20*Y[2]^2-9.20*(Y[4]+Y[2])^2)+5297.7924*sin(Y[1]+Y[3])+57584.70*sin(Y[3]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))+730134.08*sin(Y[1]+Y[3])*(142796.8368+10800.80*cos(Y[1]))*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))-540.04*sin(Y[1]+Y[3])*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))^2*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))+540.04*sin(Y[1]+Y[3])*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-730134.08*sin(Y[1]+Y[3])*(-587*sin(Y[1])*(9.20*Y[2]^2-9.20*(Y[4]+Y[2])^2)+5297.7924*sin(Y[1]+Y[3])+57584.70*sin(Y[3]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))+1827904*(-5297.7924*sin(Y[1]+Y[3])+5400.40*Y[4]^2*sin(Y[1]))*(142796.8368+10800.80*cos(Y[1]))-1352*(-5297.7924*sin(Y[1]+Y[3])+5400.40*Y[4]^2*sin(Y[1]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))^2-1352*(-5297.7924*sin(Y[1]+Y[3])+5400.40*Y[4]^2*sin(Y[1]))*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3])))/(2035121836544224.7506+153931588575265.01376*cos(Y[1])-10541323.3536*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))^2-10541323.3536*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-1827904*(7796.8368+5400.40*cos(Y[1]))^2+1460268.16*(7796.8368+5400.40*cos(Y[1]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*cos(Y[1]+Y[3])-730134.08*(7796.8368+5400.40*cos(Y[1]))*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*sin(Y[1]+Y[3])-394301608.5632*cos(Y[1]+Y[3])^2*(142796.8368+10800.80*cos(Y[1]))+291643.2016*cos(Y[1]+Y[3])^2*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))+291643.2016*cos(Y[1]+Y[3])*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*sin(Y[1]+Y[3])-730134.08*sin(Y[1]+Y[3])*(7796.8368+5400.40*cos(Y[1]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-394301608.5632*sin(Y[1]+Y[3])^2*(142796.8368+10800.80*cos(Y[1]))+291643.2016*sin(Y[1]+Y[3])*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*cos(Y[1]+Y[3])*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))+291643.2016*sin(Y[1]+Y[3])^2*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))^2); YP[4] := (10541323.3536*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))+10541323.3536*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))+8365847205177.4464*sin(Y[1])*(9.20*Y[2]^2-9.20*(Y[4]+Y[2])^2)-75503444196167.489249*sin(Y[1]+Y[3])-820689610827907.49184*sin(Y[3])-730134.08*cos(Y[1]+Y[3])*(7796.8368+5400.40*cos(Y[1]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))-291643.2016*cos(Y[1]+Y[3])^2*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))-291643.2016*cos(Y[1]+Y[3])*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))*sin(Y[1]+Y[3])+394301608.5632*cos(Y[1]+Y[3])^2*(-587*sin(Y[1])*(9.20*Y[2]^2-9.20*(Y[4]+Y[2])^2)+5297.7924*sin(Y[1]+Y[3])+57584.70*sin(Y[3]))+730134.08*sin(Y[1]+Y[3])*(7796.8368+5400.40*cos(Y[1]))*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))-291643.2016*sin(Y[1]+Y[3])*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*cos(Y[1]+Y[3])*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))-291643.2016*sin(Y[1]+Y[3])^2*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))+394301608.5632*sin(Y[1]+Y[3])^2*(-587*sin(Y[1])*(9.20*Y[2]^2-9.20*(Y[4]+Y[2])^2)+5297.7924*sin(Y[1]+Y[3])+57584.70*sin(Y[3]))+1827904*(-5297.7924*sin(Y[1]+Y[3])+5400.40*Y[4]^2*sin(Y[1]))*(7796.8368+5400.40*cos(Y[1]))-730134.08*(-5297.7924*sin(Y[1]+Y[3])+5400.40*Y[4]^2*sin(Y[1]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*cos(Y[1]+Y[3])+730134.08*(-5297.7924*sin(Y[1]+Y[3])+5400.40*Y[4]^2*sin(Y[1]))*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*sin(Y[1]+Y[3]))/(2035121836544224.7506+153931588575265.01376*cos(Y[1])-10541323.3536*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))^2-10541323.3536*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-1827904*(7796.8368+5400.40*cos(Y[1]))^2+1460268.16*(7796.8368+5400.40*cos(Y[1]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*cos(Y[1]+Y[3])-730134.08*(7796.8368+5400.40*cos(Y[1]))*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*sin(Y[1]+Y[3])-394301608.5632*cos(Y[1]+Y[3])^2*(142796.8368+10800.80*cos(Y[1]))+291643.2016*cos(Y[1]+Y[3])^2*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))+291643.2016*cos(Y[1]+Y[3])*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*sin(Y[1]+Y[3])-730134.08*sin(Y[1]+Y[3])*(7796.8368+5400.40*cos(Y[1]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-394301608.5632*sin(Y[1]+Y[3])^2*(142796.8368+10800.80*cos(Y[1]))+291643.2016*sin(Y[1]+Y[3])*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*cos(Y[1]+Y[3])*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))+291643.2016*sin(Y[1]+Y[3])^2*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))^2); YP[6] := -(10541323.3536*(142796.8368+10800.80*cos(Y[1]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))+7796.8368*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))-7796.8368*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-10541323.3536*(-587*sin(Y[1])*(9.20*Y[2]^2-9.20*(Y[4]+Y[2])^2)+5297.7924*sin(Y[1]+Y[3])+57584.70*sin(Y[3]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))-1352*(7796.8368+5400.40*cos(Y[1]))^2*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))-540.04*(7796.8368+5400.40*cos(Y[1]))*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*cos(Y[1]+Y[3])*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))-540.04*(7796.8368+5400.40*cos(Y[1]))*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))*sin(Y[1]+Y[3])+730134.08*(7796.8368+5400.40*cos(Y[1]))*(-587*sin(Y[1])*(9.20*Y[2]^2-9.20*(Y[4]+Y[2])^2)+5297.7924*sin(Y[1]+Y[3])+57584.70*sin(Y[3]))*cos(Y[1]+Y[3])+540.04*sin(Y[1]+Y[3])*(7796.8368+5400.40*cos(Y[1]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))-540.04*sin(Y[1]+Y[3])*(7796.8368+5400.40*cos(Y[1]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-291643.2016*sin(Y[1]+Y[3])*(142796.8368+10800.80*cos(Y[1]))*cos(Y[1]+Y[3])*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))-291643.2016*sin(Y[1]+Y[3])^2*(142796.8368+10800.80*cos(Y[1]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))+291643.2016*sin(Y[1]+Y[3])*(-587*sin(Y[1])*(9.20*Y[2]^2-9.20*(Y[4]+Y[2])^2)+5297.7924*sin(Y[1]+Y[3])+57584.70*sin(Y[3]))*cos(Y[1]+Y[3])*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))+291643.2016*sin(Y[1]+Y[3])^2*(-587*sin(Y[1])*(9.20*Y[2]^2-9.20*(Y[4]+Y[2])^2)+5297.7924*sin(Y[1]+Y[3])+57584.70*sin(Y[3]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))+1352*(-5297.7924*sin(Y[1]+Y[3])+5400.40*Y[4]^2*sin(Y[1]))*(7796.8368+5400.40*cos(Y[1]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))-730134.08*(-5297.7924*sin(Y[1]+Y[3])+5400.40*Y[4]^2*sin(Y[1]))*(142796.8368+10800.80*cos(Y[1]))*cos(Y[1]+Y[3])+540.04*(-5297.7924*sin(Y[1]+Y[3])+5400.40*Y[4]^2*sin(Y[1]))*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*cos(Y[1]+Y[3])*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))+540.04*(-5297.7924*sin(Y[1]+Y[3])+5400.40*Y[4]^2*sin(Y[1]))*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*sin(Y[1]+Y[3]))/(2035121836544224.7506+153931588575265.01376*cos(Y[1])-10541323.3536*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))^2-10541323.3536*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-1827904*(7796.8368+5400.40*cos(Y[1]))^2+1460268.16*(7796.8368+5400.40*cos(Y[1]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*cos(Y[1]+Y[3])-730134.08*(7796.8368+5400.40*cos(Y[1]))*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*sin(Y[1]+Y[3])-394301608.5632*cos(Y[1]+Y[3])^2*(142796.8368+10800.80*cos(Y[1]))+291643.2016*cos(Y[1]+Y[3])^2*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))+291643.2016*cos(Y[1]+Y[3])*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*sin(Y[1]+Y[3])-730134.08*sin(Y[1]+Y[3])*(7796.8368+5400.40*cos(Y[1]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-394301608.5632*sin(Y[1]+Y[3])^2*(142796.8368+10800.80*cos(Y[1]))+291643.2016*sin(Y[1]+Y[3])*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*cos(Y[1]+Y[3])*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))+291643.2016*sin(Y[1]+Y[3])^2*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))^2); YP[8] := -(291643.2016*cos(Y[1]+Y[3])^2*(-587*sin(Y[1])*(9.20*Y[2]^2-9.20*(Y[4]+Y[2])^2)+5297.7924*sin(Y[1]+Y[3])+57584.70*sin(Y[3]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-540.04*(-5297.7924*sin(Y[1]+Y[3])+5400.40*Y[4]^2*sin(Y[1]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*cos(Y[1]+Y[3])*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))+1080.08*cos(Y[1]+Y[3])*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))*(7796.8368+5400.40*cos(Y[1]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))-291643.2016*cos(Y[1]+Y[3])^2*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))*(142796.8368+10800.80*cos(Y[1]))+730134.08*sin(Y[1]+Y[3])*(-5297.7924*sin(Y[1]+Y[3])+5400.40*Y[4]^2*sin(Y[1]))*(142796.8368+10800.80*cos(Y[1]))+10541323.3536*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))*(142796.8368+10800.80*cos(Y[1]))-7796.8368*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))^2-1352*(5870*Y[4]^2*cos(Y[3])+540.04*(Y[4]+Y[2])^2*cos(Y[1]+Y[3])-4905.00*tan(Y[3])*(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*tan(Y[3])*(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*tan(Y[3])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.5999438456e-1)+4905.00*(-(Y[7]-15*sin(Y[3])+(15/2)*cos(Y[3]))^2+(Y[7]+15*sin(Y[3])+(15/2)*cos(Y[3]))^2)/tan(Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3])))/tan(Y[3]))*(7796.8368+5400.40*cos(Y[1]))^2+540.04*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))*sin(Y[1]+Y[3])*(7796.8368+5400.40*cos(Y[1]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))-291643.2016*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))*sin(Y[1]+Y[3])*cos(Y[1]+Y[3])*(142796.8368+10800.80*cos(Y[1]))+7796.8368*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-10541323.3536*(-587*sin(Y[1])*(9.20*Y[2]^2-9.20*(Y[4]+Y[2])^2)+5297.7924*sin(Y[1]+Y[3])+57584.70*sin(Y[3]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-540.04*cos(Y[1]+Y[3])*(7796.8368+5400.40*cos(Y[1]))*(5870*Y[4]^2*sin(Y[3])+540.04*(Y[4]+Y[2])^2*sin(Y[1]+Y[3])+35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-0.6006649417e-1)-35337.21492*sin(.43*X-0.2001014429e-1*Y[5])*(sinh(0.6003043287e-1+0.2001014429e-1*Y[7]+.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))-sinh(0.6003043287e-1+0.2001014429e-1*Y[7]-.3001521644*sin(Y[3])+.1500760822*cos(Y[3]))))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))+291643.2016*cos(Y[1]+Y[3])*(-587*sin(Y[1])*(9.20*Y[2]^2-9.20*(Y[4]+Y[2])^2)+5297.7924*sin(Y[1]+Y[3])+57584.70*sin(Y[3]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*sin(Y[1]+Y[3])+1352*(-5297.7924*sin(Y[1]+Y[3])+5400.40*Y[4]^2*sin(Y[1]))*(7796.8368+5400.40*cos(Y[1]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-540.04*(-5297.7924*sin(Y[1]+Y[3])+5400.40*Y[4]^2*sin(Y[1]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))^2*sin(Y[1]+Y[3])-730134.08*sin(Y[1]+Y[3])*(7796.8368+5400.40*cos(Y[1]))*(-587*sin(Y[1])*(9.20*Y[2]^2-9.20*(Y[4]+Y[2])^2)+5297.7924*sin(Y[1]+Y[3])+57584.70*sin(Y[3])))/(2035121836544224.7506+153931588575265.01376*cos(Y[1])-10541323.3536*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))^2-10541323.3536*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-1827904*(7796.8368+5400.40*cos(Y[1]))^2+1460268.16*(7796.8368+5400.40*cos(Y[1]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*cos(Y[1]+Y[3])-730134.08*(7796.8368+5400.40*cos(Y[1]))*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*sin(Y[1]+Y[3])-394301608.5632*cos(Y[1]+Y[3])^2*(142796.8368+10800.80*cos(Y[1]))+291643.2016*cos(Y[1]+Y[3])^2*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))+291643.2016*cos(Y[1]+Y[3])*(-540.04*sin(Y[1]+Y[3])-5870*sin(Y[3]))*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*sin(Y[1]+Y[3])-730134.08*sin(Y[1]+Y[3])*(7796.8368+5400.40*cos(Y[1]))*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))-394301608.5632*sin(Y[1]+Y[3])^2*(142796.8368+10800.80*cos(Y[1]))+291643.2016*sin(Y[1]+Y[3])*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))*cos(Y[1]+Y[3])*(-5870*sin(Y[1]+Y[3])-5870*sin(Y[3]))+291643.2016*sin(Y[1]+Y[3])^2*(5870*cos(Y[3])+540.04*cos(Y[1]+Y[3]))^2); YP[1] := Y[2]; YP[3] := Y[4]; YP[5] := Y[6]; YP[7] := Y[8]; 0 end proc, -1, 0, 0, 0, 0, 0, 0]), ( 18 ) = ([]), ( 19 ) = (0)  ] ))  ] ); _y0 := Array(0..8, {(1) = 0., (2) = 0., (3) = 0., (4) = 0., (5) = 0., (6) = 0., (7) = 0., (8) = 3.}); _vmap := array( 1 .. 8, [( 1 ) = (1), ( 2 ) = (2), ( 3 ) = (3), ( 5 ) = (5), ( 4 ) = (4), ( 7 ) = (7), ( 6 ) = (6), ( 8 ) = (8)  ] ); _x0 := _dtbl[1][5][5]; _n := _dtbl[1][4][1]; _ne := _dtbl[1][4][3]; _nd := _dtbl[1][4][4]; _nv := _dtbl[1][4][16]; if not type(_xout, 'numeric') then if member(_xout, ["start", "left", "right"]) then if _Env_smart_dsolve_numeric = true or _dtbl[1][4][10] = 1 then if _xout = "left" then if type(_dtbl[2], 'table') then return _dtbl[2][5][1] end if elif _xout = "right" then if type(_dtbl[3], 'table') then return _dtbl[3][5][1] end if end if end if; return _dtbl[1][5][5] elif _xout = "method" then return _dtbl[1][15] elif _xout = "storage" then return evalb(_dtbl[1][4][10] = 1) elif _xout = "leftdata" then if not type(_dtbl[2], 'array') then return NULL else return eval(_dtbl[2]) end if elif _xout = "rightdata" then if not type(_dtbl[3], 'array') then return NULL else return eval(_dtbl[3]) end if elif _xout = "enginedata" then return eval(_dtbl[1]) elif _xout = "enginereset" then _dtbl[2] := evaln(_dtbl[2]); _dtbl[3] := evaln(_dtbl[3]); return NULL elif _xout = "initial" then return procname(_y0[0]) elif _xout = "laxtol" then return _dtbl[`if`(member(_dtbl[4], {2, 3}), _dtbl[4], 1)][5][18] elif _xout = "numfun" then return `if`(member(_dtbl[4], {2, 3}), _dtbl[_dtbl[4]][4][18], 0) elif _xout = "parameters" then return [seq(_y0[_n+_i], _i = 1 .. nops(_pars))] elif _xout = "initial_and_parameters" then return procname(_y0[0]), [seq(_y0[_n+_i], _i = 1 .. nops(_pars))] elif _xout = "last" then if _dtbl[4] <> 2 and _dtbl[4] <> 3 or _x0-_dtbl[_dtbl[4]][5][1] = 0. then error "no information is available on last computed point" else _xout := _dtbl[_dtbl[4]][5][1] end if elif _xout = "function" then if _dtbl[1][4][33]-2. = 0 then return eval(_dtbl[1][10], 1) else return eval(_dtbl[1][10][1], 1) end if elif _xout = "map" then return copy(_vmap) elif type(_xin, `=`) and type(rhs(_xin), 'list') and member(lhs(_xin), {"initial", "parameters", "initial_and_parameters"}) then _ini, _par := [], []; if lhs(_xin) = "initial" then _ini := rhs(_xin) elif lhs(_xin) = "parameters" then _par := rhs(_xin) elif select(type, rhs(_xin), `=`) <> [] then _par, _ini := selectremove(type, rhs(_xin), `=`) elif nops(rhs(_xin)) < nops(_pars)+1 then error "insufficient data for specification of initial and parameters" else _par := rhs(_xin)[-nops(_pars) .. -1]; _ini := rhs(_xin)[1 .. -nops(_pars)-1] end if; _xout := lhs(_xout); if _par <> [] then `dsolve/numeric/process_parameters`(_n, _pars, _par, _y0) end if; if _ini <> [] then `dsolve/numeric/process_initial`(_n-_ne, _ini, _y0, _pars, _vmap) end if; `dsolve/numeric/SC/reinitialize`(_dtbl, _y0, _n, procname, _pars); if _Env_smart_dsolve_numeric = true and type(_y0[0], 'numeric') and _dtbl[1][4][10] <> 1 then procname("right") := _y0[0]; procname("left") := _y0[0] end if; if _xout = "initial" then return [_y0[0], seq(_y0[_vmap[_i]], _i = 1 .. _n-_ne)] elif _xout = "parameters" then return [seq(_y0[_n+_i], _i = 1 .. nops(_pars))] else return [_y0[0], seq(_y0[_vmap[_i]], _i = 1 .. _n-_ne)], [seq(_y0[_n+_i], _i = 1 .. nops(_pars))] end if elif _xin = "eventstop" then if _nv = 0 then error "this solution has no events" end if; _i := _dtbl[4]; if _i <> 2 and _i <> 3 then return 0 end if; if _dtbl[_i][4][10] = 1 and assigned(_dtbl[5-_i]) and _dtbl[_i][4][9] < 10 and 10 <= _dtbl[5-_i][4][9] then _i := 5-_i; _dtbl[4] := _i; _j := round(_dtbl[_i][4][17]); return round(_dtbl[_i][3][1][_j, 1]) elif 10 <= _dtbl[_i][4][9] then _j := round(_dtbl[_i][4][17]); return round(_dtbl[_i][3][1][_j, 1]) else return 0 end if elif _xin = "eventstatus" then if _nv = 0 then error "this solution has no events" end if; _i := [selectremove(proc (a) options operator, arrow; _dtbl[1][3][1][a, 7] = 1 end proc, {seq(_j, _j = 1 .. round(_dtbl[1][3][1][_nv+1, 1]))})]; return ':-enabled' = _i[1], ':-disabled' = _i[2] elif _xin = "eventclear" then if _nv = 0 then error "this solution has no events" end if; _i := _dtbl[4]; if _i <> 2 and _i <> 3 then error "no events to clear" end if; if _dtbl[_i][4][10] = 1 and assigned(_dtbl[5-_i]) and _dtbl[_i][4][9] < 10 and 10 < _dtbl[5-_i][4][9] then _dtbl[4] := 5-_i; _i := 5-_i end if; if _dtbl[_i][4][9] < 10 then error "no events to clear" elif _nv < _dtbl[_i][4][9]-10 then error "event error condition cannot be cleared" else _j := _dtbl[_i][4][9]-10; if irem(round(_dtbl[_i][3][1][_j, 4]), 2) = 1 then error "retriggerable events cannot be cleared" end if; _j := round(_dtbl[_i][3][1][_j, 1]); for _k to _nv do if _dtbl[_i][3][1][_k, 1] = _j then if _dtbl[_i][3][1][_k, 2] = 3 then error "range events cannot be cleared" end if; _dtbl[_i][3][1][_k, 8] := _dtbl[_i][3][1][_nv+1, 8] end if end do; _dtbl[_i][4][17] := 0; _dtbl[_i][4][9] := 0; if _dtbl[1][4][10] = 1 then if _i = 2 then try procname(procname("left")) catch:  end try else try procname(procname("right")) catch:  end try end if end if end if; return  elif type(_xin, `=`) and member(lhs(_xin), {"eventdisable", "eventenable"}) then if _nv = 0 then error "this solution has no events" end if; if type(rhs(_xin), {('list')('posint'), ('set')('posint')}) then _i := {op(rhs(_xin))} elif type(rhs(_xin), 'posint') then _i := {rhs(_xin)} else error "event identifiers must be integers in the range 1..%1", round(_dtbl[1][3][1][_nv+1, 1]) end if; if select(proc (a) options operator, arrow; _nv < a end proc, _i) <> {} then error "event identifiers must be integers in the range 1..%1", round(_dtbl[1][3][1][_nv+1, 1]) end if; _k := {}; for _j to _nv do if member(round(_dtbl[1][3][1][_j, 1]), _i) then _k := `union`(_k, {_j}) end if end do; _i := _k; if lhs(_xin) = "eventdisable" then _dtbl[4] := 0; _j := [evalb(assigned(_dtbl[2]) and member(_dtbl[2][4][17], _i)), evalb(assigned(_dtbl[3]) and member(_dtbl[3][4][17], _i))]; for _k in _i do _dtbl[1][3][1][_k, 7] := 0; if assigned(_dtbl[2]) then _dtbl[2][3][1][_k, 7] := 0 end if; if assigned(_dtbl[3]) then _dtbl[3][3][1][_k, 7] := 0 end if end do; if _j[1] then for _k to _nv+1 do if _k <= _nv and not type(_dtbl[2][3][4][_k, 1], 'undefined') then userinfo(3, {'events', 'eventreset'}, `reinit #2, event code `, _k, ` to defined init `, _dtbl[2][3][4][_k, 1]); _dtbl[2][3][1][_k, 8] := _dtbl[2][3][4][_k, 1] elif _dtbl[2][3][1][_k, 2] = 0 and irem(iquo(round(_dtbl[2][3][1][_k, 4]), 32), 2) = 1 then userinfo(3, {'events', 'eventreset'}, `reinit #2, event code `, _k, ` to rate hysteresis init `, _dtbl[2][5][24]); _dtbl[2][3][1][_k, 8] := _dtbl[2][5][24] elif _dtbl[2][3][1][_k, 2] = 0 and irem(iquo(round(_dtbl[2][3][1][_k, 4]), 2), 2) = 0 then userinfo(3, {'events', 'eventreset'}, `reinit #2, event code `, _k, ` to initial init `, _x0); _dtbl[2][3][1][_k, 8] := _x0 else userinfo(3, {'events', 'eventreset'}, `reinit #2, event code `, _k, ` to fireinitial init `, _x0-1); _dtbl[2][3][1][_k, 8] := _x0-1 end if end do; _dtbl[2][4][17] := 0; _dtbl[2][4][9] := 0; if _dtbl[1][4][10] = 1 then procname(procname("left")) end if end if; if _j[2] then for _k to _nv+1 do if _k <= _nv and not type(_dtbl[3][3][4][_k, 2], 'undefined') then userinfo(3, {'events', 'eventreset'}, `reinit #3, event code `, _k, ` to defined init `, _dtbl[3][3][4][_k, 2]); _dtbl[3][3][1][_k, 8] := _dtbl[3][3][4][_k, 2] elif _dtbl[3][3][1][_k, 2] = 0 and irem(iquo(round(_dtbl[3][3][1][_k, 4]), 32), 2) = 1 then userinfo(3, {'events', 'eventreset'}, `reinit #3, event code `, _k, ` to rate hysteresis init `, _dtbl[3][5][24]); _dtbl[3][3][1][_k, 8] := _dtbl[3][5][24] elif _dtbl[3][3][1][_k, 2] = 0 and irem(iquo(round(_dtbl[3][3][1][_k, 4]), 2), 2) = 0 then userinfo(3, {'events', 'eventreset'}, `reinit #3, event code `, _k, ` to initial init `, _x0); _dtbl[3][3][1][_k, 8] := _x0 else userinfo(3, {'events', 'eventreset'}, `reinit #3, event code `, _k, ` to fireinitial init `, _x0+1); _dtbl[3][3][1][_k, 8] := _x0+1 end if end do; _dtbl[3][4][17] := 0; _dtbl[3][4][9] := 0; if _dtbl[1][4][10] = 1 then procname(procname("right")) end if end if else for _k in _i do _dtbl[1][3][1][_k, 7] := 1 end do; _dtbl[2] := evaln(_dtbl[2]); _dtbl[3] := evaln(_dtbl[3]); _dtbl[4] := 0; if _dtbl[1][4][10] = 1 then if _x0 <= procname("right") then try procname(procname("right")) catch:  end try end if; if procname("left") <= _x0 then try procname(procname("left")) catch:  end try end if end if end if; return  elif type(_xin, `=`) and lhs(_xin) = "eventfired" then if not type(rhs(_xin), 'list') then error "'eventfired' must be specified as a list" end if; if _nv = 0 then error "this solution has no events" end if; if _dtbl[4] <> 2 and _dtbl[4] <> 3 then error "'direction' must be set prior to calling/setting 'eventfired'" end if; _i := _dtbl[4]; _val := NULL; if not assigned(_EnvEventRetriggerWarned) then _EnvEventRetriggerWarned := false end if; for _k in rhs(_xin) do if type(_k, 'integer') then _src := _k elif type(_k, 'integer' = 'anything') and type(evalf(rhs(_k)), 'numeric') then _k := lhs(_k) = evalf[max(Digits, 18)](rhs(_k)); _src := lhs(_k) else error "'eventfired' entry is not valid: %1", _k end if; if _src < 1 or round(_dtbl[1][3][1][_nv+1, 1]) < _src then error "event identifiers must be integers in the range 1..%1", round(_dtbl[1][3][1][_nv+1, 1]) end if; _src := {seq(`if`(_dtbl[1][3][1][_j, 1]-_src = 0., _j, NULL), _j = 1 .. _nv)}; if nops(_src) <> 1 then error "'eventfired' can only be set/queried for root-finding events and time/interval events" end if; _src := _src[1]; if _dtbl[1][3][1][_src, 2] <> 0. and _dtbl[1][3][1][_src, 2]-2. <> 0. then error "'eventfired' can only be set/queried for root-finding events and time/interval events" elif irem(round(_dtbl[1][3][1][_src, 4]), 2) = 1 then if _EnvEventRetriggerWarned = false then WARNING(`'eventfired' has no effect on events that retrigger`) end if; _EnvEventRetriggerWarned := true end if; if _dtbl[_i][3][1][_src, 2] = 0 and irem(iquo(round(_dtbl[_i][3][1][_src, 4]), 32), 2) = 1 then _val := _val, undefined elif type(_dtbl[_i][3][4][_src, _i-1], 'undefined') or _i = 2 and _dtbl[2][3][1][_src, 8] < _dtbl[2][3][4][_src, 1] or _i = 3 and _dtbl[3][3][4][_src, 2] < _dtbl[3][3][1][_src, 8] then _val := _val, _dtbl[_i][3][1][_src, 8] else _val := _val, _dtbl[_i][3][4][_src, _i-1] end if; if type(_k, `=`) then if _dtbl[_i][3][1][_src, 2] = 0 and irem(iquo(round(_dtbl[_i][3][1][_src, 4]), 32), 2) = 1 then error "cannot set event code for a rate hysteresis event" end if; userinfo(3, {'events', 'eventreset'}, `manual set event code `, _src, ` to value `, rhs(_k)); _dtbl[_i][3][1][_src, 8] := rhs(_k); _dtbl[_i][3][4][_src, _i-1] := rhs(_k) end if end do; return [_val] elif type(_xin, `=`) and lhs(_xin) = "direction" then if not member(rhs(_xin), {-1, 1, ':-left', ':-right'}) then error "'direction' must be specified as either '1' or 'right' (positive) or '-1' or 'left' (negative)" end if; _src := `if`(_dtbl[4] = 2, -1, `if`(_dtbl[4] = 3, 1, undefined)); _i := `if`(member(rhs(_xin), {1, ':-right'}), 3, 2); _dtbl[4] := _i; _dtbl[_i] := `dsolve/numeric/SC/IVPdcopy`(_dtbl[1], `if`(assigned(_dtbl[_i]), _dtbl[_i], NULL)); if 0 < _nv then for _j to _nv+1 do if _j <= _nv and not type(_dtbl[_i][3][4][_j, _i-1], 'undefined') then userinfo(3, {'events', 'eventreset'}, `reinit #4, event code `, _j, ` to defined init `, _dtbl[_i][3][4][_j, _i-1]); _dtbl[_i][3][1][_j, 8] := _dtbl[_i][3][4][_j, _i-1] elif _dtbl[_i][3][1][_j, 2] = 0 and irem(iquo(round(_dtbl[_i][3][1][_j, 4]), 32), 2) = 1 then userinfo(3, {'events', 'eventreset'}, `reinit #4, event code `, _j, ` to rate hysteresis init `, _dtbl[_i][5][24]); _dtbl[_i][3][1][_j, 8] := _dtbl[_i][5][24] elif _dtbl[_i][3][1][_j, 2] = 0 and irem(iquo(round(_dtbl[_i][3][1][_j, 4]), 2), 2) = 0 then userinfo(3, {'events', 'eventreset'}, `reinit #4, event code `, _j, ` to initial init `, _x0); _dtbl[_i][3][1][_j, 8] := _x0 else userinfo(3, {'events', 'eventreset'}, `reinit #4, event code `, _j, ` to fireinitial init `, _x0-2*_i+5.0); _dtbl[_i][3][1][_j, 8] := _x0-2*_i+5.0 end if end do end if; return _src elif _xin = "eventcount" then if _dtbl[1][3][1] = 0 or _dtbl[4] <> 2 and _dtbl[4] <> 3 then return 0 else return round(_dtbl[_dtbl[4]][3][1][_nv+1, 12]) end if else return "procname" end if end if; if _xout = _x0 then return [_x0, seq(evalf(_dtbl[1][6][_vmap[_i]]), _i = 1 .. _n-_ne)] end if; _i := `if`(_x0 <= _xout, 3, 2); if _xin = "last" and 0 < _dtbl[_i][4][9] and _dtbl[_i][4][9] < 10 then _dat := eval(_dtbl[_i], 2); _j := _dat[4][20]; return [_dat[11][_j, 0], seq(_dat[11][_j, _vmap[_i]], _i = 1 .. _n-_ne-_nd), seq(_dat[8][1][_vmap[_i]], _i = _n-_ne-_nd+1 .. _n-_ne)] end if; if not type(_dtbl[_i], 'array') then _dtbl[_i] := `dsolve/numeric/SC/IVPdcopy`(_dtbl[1], `if`(assigned(_dtbl[_i]), _dtbl[_i], NULL)); if 0 < _nv then for _j to _nv+1 do if _j <= _nv and not type(_dtbl[_i][3][4][_j, _i-1], 'undefined') then userinfo(3, {'events', 'eventreset'}, `reinit #5, event code `, _j, ` to defined init `, _dtbl[_i][3][4][_j, _i-1]); _dtbl[_i][3][1][_j, 8] := _dtbl[_i][3][4][_j, _i-1] elif _dtbl[_i][3][1][_j, 2] = 0 and irem(iquo(round(_dtbl[_i][3][1][_j, 4]), 32), 2) = 1 then userinfo(3, {'events', 'eventreset'}, `reinit #5, event code `, _j, ` to rate hysteresis init `, _dtbl[_i][5][24]); _dtbl[_i][3][1][_j, 8] := _dtbl[_i][5][24] elif _dtbl[_i][3][1][_j, 2] = 0 and irem(iquo(round(_dtbl[_i][3][1][_j, 4]), 2), 2) = 0 then userinfo(3, {'events', 'eventreset'}, `reinit #5, event code `, _j, ` to initial init `, _x0); _dtbl[_i][3][1][_j, 8] := _x0 else userinfo(3, {'events', 'eventreset'}, `reinit #5, event code `, _j, ` to fireinitial init `, _x0-2*_i+5.0); _dtbl[_i][3][1][_j, 8] := _x0-2*_i+5.0 end if end do end if end if; if _xin <> "last" then if 0 < 0 then if `dsolve/numeric/checkglobals`(op(_dtbl[1][14]), _pars, _n, _y0) then `dsolve/numeric/SC/reinitialize`(_dtbl, _y0, _n, procname, _pars, _i) end if end if; if _dtbl[1][4][7] = 0 then error "parameters must be initialized before solution can be computed" end if end if; _dat := eval(_dtbl[_i], 2); _dtbl[4] := _i; try _src := `dsolve/numeric/SC/IVPrun`(_dat, _xout) catch: userinfo(2, `dsolve/debug`, print(`Exception in solnproc:`, [lastexception][2 .. -1])); error  end try; if _src = 0 and 10 < _dat[4][9] then _val := _dat[3][1][_nv+1, 8] else _val := _dat[11][_dat[4][20], 0] end if; if _src <> 0 or _dat[4][9] <= 0 then _dtbl[1][5][1] := _xout else _dtbl[1][5][1] := _val end if; if _i = 3 and _val < _xout then Rounding := -infinity; if _dat[4][9] = 1 then error "cannot evaluate the solution further right of %1, probably a singularity", evalf[8](_val) elif _dat[4][9] = 2 then error "cannot evaluate the solution further right of %1, maxfun limit exceeded (see <a href='http://www.maplesoft.com/support/help/search.aspx?term=dsolve,maxfun' target='_new'>?dsolve,maxfun</a> for details)", evalf[8](_val) elif _dat[4][9] = 3 then if _dat[4][25] = 3 then error "cannot evaluate the solution past the initial point, problem may be initially singular or improperly set up" else error "cannot evaluate the solution past the initial point, problem may be complex, initially singular or improperly set up" end if elif _dat[4][9] = 4 then error "cannot evaluate the solution further right of %1, accuracy goal cannot be achieved with specified 'minstep'", evalf[8](_val) elif _dat[4][9] = 5 then error "cannot evaluate the solution further right of %1, too many step failures, tolerances may be too loose for problem", evalf[8](_val) elif 10 < _dat[4][9] then if _dat[4][9]-10 = _nv+1 then error "constraint projection failure on event at t=%1", evalf[8](_val) elif _dat[4][9]-10 = _nv+2 then error "index-1 and derivative evaluation failure on event at t=%1", evalf[8](_val) elif _dat[4][9]-10 = _nv+3 then error "maximum number of event iterations reached (%1) at t=%2", round(_dat[3][1][_nv+1, 3]), evalf[8](_val) else if _Env_dsolve_nowarnstop <> true then `dsolve/numeric/warning`(StringTools:-FormatMessage("cannot evaluate the solution further right of %1, event #%2 triggered a halt", evalf[8](_val), round(_dat[3][1][_dat[4][9]-10, 1]))) end if; Rounding := 'nearest'; _xout := _val end if else error "cannot evaluate the solution further right of %1", evalf[8](_val) end if elif _i = 2 and _xout < _val then Rounding := infinity; if _dat[4][9] = 1 then error "cannot evaluate the solution further left of %1, probably a singularity", evalf[8](_val) elif _dat[4][9] = 2 then error "cannot evaluate the solution further left of %1, maxfun limit exceeded (see <a href='http://www.maplesoft.com/support/help/search.aspx?term=dsolve,maxfun' target='_new'>?dsolve,maxfun</a> for details)", evalf[8](_val) elif _dat[4][9] = 3 then if _dat[4][25] = 3 then error "cannot evaluate the solution past the initial point, problem may be initially singular or improperly set up" else error "cannot evaluate the solution past the initial point, problem may be complex, initially singular or improperly set up" end if elif _dat[4][9] = 4 then error "cannot evaluate the solution further left of %1, accuracy goal cannot be achieved with specified 'minstep'", evalf[8](_val) elif _dat[4][9] = 5 then error "cannot evaluate the solution further left of %1, too many step failures, tolerances may be too loose for problem", evalf[8](_val) elif 10 < _dat[4][9] then if _dat[4][9]-10 = _nv+1 then error "constraint projection failure on event at t=%1", evalf[8](_val) elif _dat[4][9]-10 = _nv+2 then error "index-1 and derivative evaluation failure on event at t=%1", evalf[8](_val) elif _dat[4][9]-10 = _nv+3 then error "maximum number of event iterations reached (%1) at t=%2", round(_dat[3][1][_nv+1, 3]), evalf[8](_val) else if _Env_dsolve_nowarnstop <> true then `dsolve/numeric/warning`(StringTools:-FormatMessage("cannot evaluate the solution further left of %1, event #%2 triggered a halt", evalf[8](_val), round(_dat[3][1][_dat[4][9]-10, 1]))) end if; Rounding := 'nearest'; _xout := _val end if else error "cannot evaluate the solution further left of %1", evalf[8](_val) end if end if; if _EnvInFsolve = true then _dig := _dat[4][26]; _dat[4][26] := _EnvDSNumericSaveDigits; _Env_dsolve_SC_native := true; if _dat[4][25] = 1 then _i := 1; _dat[4][25] := 2 else _i := _dat[4][25] end if; _val := `dsolve/numeric/SC/IVPval`(_dat, _xout, _src); _dat[4][25] := _i; _dat[4][26] := _dig; [_xout, seq(_val[_vmap[_i]], _i = 1 .. _n-_ne)] else Digits := _dat[4][26]; _val := `dsolve/numeric/SC/IVPval`(eval(_dat, 2), _xout, _src); [_xout, seq(_val[_vmap[_i]], _i = 1 .. _n-_ne)] end if end proc, (2) = Array(0..0, {}), (3) = [t, alpha(t), diff(alpha(t), t), theta(t), diff(theta(t), t), x(t), diff(x(t), t), z(t), diff(z(t), t)], (4) = []}); _vars := _dat[3]; _pars := map(rhs, _dat[4]); _n := nops(_vars)-1; _solnproc := _dat[1]; if not type(_xout, 'numeric') then if member(x_rkf45, ["start", 'start', "method", 'method', "left", 'left', "right", 'right', "leftdata", "rightdata", "enginedata", "eventstop", 'eventstop', "eventclear", 'eventclear', "eventstatus", 'eventstatus', "eventcount", 'eventcount', "laxtol", 'laxtol', "numfun", 'numfun', NULL]) then _res := _solnproc(convert(x_rkf45, 'string')); if 1 < nops([_res]) then return _res elif type(_res, 'array') then return eval(_res, 1) elif _res <> "procname" then return _res end if elif member(x_rkf45, ["last", 'last', "initial", 'initial', "parameters", 'parameters', "initial_and_parameters", 'initial_and_parameters', NULL]) then _xout := convert(x_rkf45, 'string'); _res := _solnproc(_xout); if _xout = "parameters" then return [seq(_pars[_i] = _res[_i], _i = 1 .. nops(_pars))] elif _xout = "initial_and_parameters" then return [seq(_vars[_i+1] = [_res][1][_i+1], _i = 0 .. _n), seq(_pars[_i] = [_res][2][_i], _i = 1 .. nops(_pars))] else return [seq(_vars[_i+1] = _res[_i+1], _i = 0 .. _n)] end if elif type(_xout, `=`) and member(lhs(_xout), ["initial", 'initial', "parameters", 'parameters', "initial_and_parameters", 'initial_and_parameters', NULL]) then _xout := convert(lhs(x_rkf45), 'string') = rhs(x_rkf45); if type(rhs(_xout), 'list') then _res := _solnproc(_xout) else error "initial and/or parameter values must be specified in a list" end if; if lhs(_xout) = "initial" then return [seq(_vars[_i+1] = _res[_i+1], _i = 0 .. _n)] elif lhs(_xout) = "parameters" then return [seq(_pars[_i] = _res[_i], _i = 1 .. nops(_pars))] else return [seq(_vars[_i+1] = [_res][1][_i+1], _i = 0 .. _n), seq(_pars[_i] = [_res][2][_i], _i = 1 .. nops(_pars))] end if elif type(_xout, `=`) and member(lhs(_xout), ["eventdisable", 'eventdisable', "eventenable", 'eventenable', "eventfired", 'eventfired', "direction", 'direction', NULL]) then return _solnproc(convert(lhs(x_rkf45), 'string') = rhs(x_rkf45)) elif _xout = "solnprocedure" then return eval(_solnproc) elif _xout = "sysvars" then return _vars end if; if procname <> unknown then return ('procname')(x_rkf45) else _ndsol; _ndsol := pointto(_dat[2][0]); return ('_ndsol')(x_rkf45) end if end if; try _res := _solnproc(_xout); [seq(_vars[_i+1] = _res[_i+1], _i = 0 .. _n)] catch: error  end try end proc
#odeplot(solution,[[t,x(t)],[t,alpha(t)],[t,z(t)],[t,theta(t)]], t=0..1000, thickness=2);
odeplot(solution,[[t,x(t)]], t=0..100, thickness=2);
Warning, cannot evaluate the solution past the initial point, problem may be complex, initially singular or improperly set up
odeplot(solution,[[t,z(t)]], t=0..100, thickness=2);
odeplot(solution,[[t,alpha(t)]], t=0..100, thickness=2);
odeplot(solution,[[t,theta(t)]], t=0..100, thickness=2);
Download fffffffff_INFINI.mw
please help
thank you !
First 1414 1415 1416 1417 1418 1419 1420 Last Page 1416 of 2429
