I have a easy question I think but blocking for me.
I have a expression g(t):=f(x(t),alpha(t),beta(t))
I give
x(t):=0.12
alpha(t):=0
beta(t):=0
I would like to evaluate g(t).
And for the moment x(t), alpha(t) and beta(t) aren't replaced by their values.
How can i do in order to have the evaluation of g(t) ?
Thanks a lot for help.
i am using plot command to plot the first vs the second column in the attached file A.txt
it is giving a strange plot. while plotting the first vs second column in kgraph i am getting the correct plot
why is maple giving me a wrong plot
you can find the two plots and the raw data file A.txt
Download A.txt
Dihedralgroup(9) acts on the set 1..9 and has order 9
g:=SmallGroup(18,1) acts on the set 1..18 and has order 18.
Question:
Is it possible to let g act on 1..9, too) and how can I do that?
Best regards
Kurt Ewald
Hallo,
Is there a fairly straightforward method for obtaining an array of coordinates from an implicit equation? I have an ellipse defined implicitly (by a horrendously involved expression) and can't figure out how to extract a set of coordinates from an implicitplot. I'm reluctant to use seq and fsolve with a fixed stepsize.
Would be grateful for some insight!
Weirp
Hi Mapleprimers,
I was wondering if there way a way to use restart(); and clear Maple's memory, but protect the memory in a certain variable?  I would like to return the memory to the operating system, but keep a symholic function in memory.
Alternatively, is there a way to save a symbolic function to a file, then reload it at a seperate time?
hi everyone,i have two questions,
1. i have a problem with select command?
eq[1]:=diff(a[1](x),x$2)+diff(a[1](x),x$1)*diff(a[2](x),x$1)+diff(a[1](x),x$2)*diff(a[2](x),x$2)+diff(a[3](x),x$1)+diff(a[1](x),x$1)*diff(a[2](x),x$2)+diff(a[1](x),x$2)*diff(a[3](x),x$1);
diff(diff(a[1](x), x), x)+(diff(a[1](x), x))*(diff(a[2](x), x))+(diff(diff(a[1](x), x), x))*(diff(diff(a[2](x), x), x))+diff(a[3](x), x)+(diff(a[1](x), x))*(diff(diff(a[2](x), x), x))+(diff(diff(a[1](x), x), x))*(diff(a[3](x), x))
# how can i select the differentials which are of second order ? without using the function names , for example i do not want to use this :
select(has,eq[1],[seq](diff(a[i](x),x$2),i=1..3));
diff(diff(a[1](x), x), x)+(diff(diff(a[1](x), x), x))*(diff(diff(a[2](x), x), x))+(diff(a[1](x), x))*(diff(diff(a[2](x), x), x))+(diff(diff(a[1](x), x), x))*(diff(a[3](x), x))
#i just want maple to select the second order differentials,without knowing its name # just beacuse it is of second order,how can i do this !?
2. how i can select the parts which their addition of differential oreder,are the same ? for example,the second expression in eq[1] has the addition order of 2,third has 4 and ... how can isolate addition order ? tnx in advance .
Download select.mw
Hi All. Hope all is well.
Assume that we have partitioned [0,a], into N equidistant subintervals and in each subinterval we have M sets of polynomials of arbitrary form[say bij(t)](a.e Taylor series, or Bernstein series,…)
for Example with N=4, M=3 and by Taylor series we have:
now we want to approximate a function, asy f(t), in this interval with following form:
If we have:
(Tau is a constant number)
then: How can  we find L and Z matrices using maple? Is it any way? (or other softwares?)
Mahmood   Dadkhah
Ph.D Candidate
evalf(10.2^20, 50);
evalf((10+1/5)^20, 50);
Where are 50 digits of the first result?
I have a matrix (1002,2) where first column isthe time and the second is numerical solution of an angle.My angle should be oscillating periodically but I am getting a noise at large times. I need to check if this noise contains certain frequencies in it so I need to plot a power spectrum of my data. How can I do that
> restart;
> with(LinearAlgebra);
> q := a*mu^4+b*mu^3+d*mu^2+e*mu+f = 0;
> sol := solve(a*mu^4+b*mu^3+d*mu^2+e*mu+f = 0, mu);
> S[1] := allvalues(sol);
> PARAM := [a = -54/c^2-1269*A[1]/(8*c^2), b = 108/c^2+5013*A[1]/(8*c^2), d = 27-693/(2*c^2)+117*A[1]-7113*A[1]/(4*c^2), e = -27+585/(2*c^2)-111*A[1]+20439*A[1]/(16*c^2), f = 1-3*A[1]-18/c^2-8*A[1]/c^2];
> S2 := eval(S[1], PARAM);
Error, invalid input: eval received PARAM, which is not valid for its 2nd argument, eqns
> series(%, c = infinity, 3, A[1] = 0, 2]);
Please i mean by last statemene the solutions to be written i series as:
m1=.........+O(1/c^3)+O(A1^2)
m2=.......+O(1/c^3)+O(A1^2)
etf.
A1=0,2 means O(A1^2),therefore,i am not evaluating at .2 .
1. how to do optimization with partial differential equation as constraints in maple
2. how to do optimization with  partial differential equation as objective function in order to make output obey this model
how gr operators work?
I tried to run example given there but it is not working,
where can I get more examples to understand working of Gr operators work?
specially for raychaudhuri equations.
Hi MaplePrime-ers,
I'm using Maple17 in Matlab 2012b to evaluate a symbolic function over a grid of values.  The number of values is generally ~500k, and therefore I have a loop that dumps the solutions into MATLAB where the values are parsed and stored more efficiently.
I put this proceess in an optimization routine, and I keep getting crashes.  The crashes are NOT repeatable.  They generally happen after 4-10 times the routine has been called.
This is one of the stack dumps.  Anybody have any ideas?  I talked to MATLAB support, but they weren't very useful (they started pointing fingers).
Segmentation violation detected at Wed Jun 4 17:38:11 2014
Configuration:
Crash Decoding : Disabled
Current Visual : 0x24 (class 4, depth 24)
Default Encoding: UTF-8
GNU C Library : 2.15 stable
MATLAB Root : /opt/Matlab/R2012b
MATLAB Version : 8.0.0.783 (R2012b)
Operating System: Linux 3.2.0-37-generic #58-Ubuntu SMP Thu Jan 24 15:28:10 UTC 2013 x86_64
Processor ID : x86 Family 6 Model 23 Stepping 6, GenuineIntel
Virtual Machine : Java 1.6.0_17-b04 with Sun Microsystems Inc. Java HotSpot(TM) 64-Bit Server VM mixed mode
Window System : The XFree86 Project, Inc (40300000), display wildnode0:15.0
Fault Count: 1
Abnormal termination:
Register State (from fault):
RAX = 00007f3bcc0a80c0 RBX = 00007f3b97fe6000
RCX = 0000000000000000 RDX = 00007f3bcc0a84a0
RSP = 00007f3b8cb29d60 RBP = 0000000000000003
RSI = 5851f42d4c957f2d RDI = 00007f3bde026360
R8 = 65a1566174cc9e28 R9 = 0000000000000002
R10 = 00007f3b8cb29d90 R11 = 0000000000002e88
R12 = 0000000000000001 R13 = 00007f3b8cb29df0
R14 = 0000000000000000 R15 = 0000000000000003
RIP = 00007f3b977d0604 EFL = 0000000000010283
CS = 0033 FS = 0000 GS = 0000
Stack Trace (from fault):
[ 0] 0x00007f3c962b01de /opt/Matlab/R2012b/bin/glnxa64/libmwfl.so+00516574 _ZN2fl4diag15stacktrace_base7captureERKNS0_14thread_contextEm+000158
[ 1] 0x00007f3c962b14b2 /opt/Matlab/R2012b/bin/glnxa64/libmwfl.so+00521394
[ 2] 0x00007f3c962b2ffe /opt/Matlab/R2012b/bin/glnxa64/libmwfl.so+00528382 _ZN2fl4diag13terminate_logEPKcRKNS0_14thread_contextE+000174
[ 3] 0x00007f3c9559f093 /opt/Matlab/R2012b/bin/glnxa64/libmwmcr.so+00557203 _ZN2fl4diag13terminate_logEPKcPK8ucontext+000067
[ 4] 0x00007f3c9559bb9d /opt/Matlab/R2012b/bin/glnxa64/libmwmcr.so+00543645
[ 5] 0x00007f3c9559d835 /opt/Matlab/R2012b/bin/glnxa64/libmwmcr.so+00550965
[ 6] 0x00007f3c9559da55 /opt/Matlab/R2012b/bin/glnxa64/libmwmcr.so+00551509
[ 7] 0x00007f3c9559e0fe /opt/Matlab/R2012b/bin/glnxa64/libmwmcr.so+00553214
[ 8] 0x00007f3c9559e295 /opt/Matlab/R2012b/bin/glnxa64/libmwmcr.so+00553621
[ 9] 0x00007f3c93a86cb0 /lib/x86_64-linux-gnu/libpthread.so.0+00064688
[ 10] 0x00007f3b977d0604 /opt/maple17/bin.X86_64_LINUX/libmaple.so+01824260
[ 11] 0x00007f3b977cfc48 /opt/maple17/bin.X86_64_LINUX/libmaple.so+01821768
[ 12] 0x00007f3b977d2f88 /opt/maple17/bin.X86_64_LINUX/libmaple.so+01834888
[ 13] 0x00007f3b9763d63f /opt/maple17/bin.X86_64_LINUX/libmaple.so+00173631
[ 14] 0x00007f3c93a7ee9a /lib/x86_64-linux-gnu/libpthread.so.0+00032410
[ 15] 0x00007f3c937ab3fd /lib/x86_64-linux-gnu/libc.so.6+01000445 clone+000109
If this problem is reproducible, please submit a Service Request via:
http://www.mathworks.com/support/contact_us/
A technical support engineer might contact you with further information.
Thank you for your help.
I am trying to design a question to test for divisibility
$n3=range(0,9,1); and students have to choose the next digit to make the number divisible by 4
if $n3 is even the students must input 0,4,8 to be true
if $n3 is odd the students must input 2 or 6 to be correct.
I am not sure how to us the if(a,b,c) in this case or if I should be using indexof....or both?  Any help would be appreciated.
> with(Statistics);
> X := Vector([1, 2, 3, 4, 5, 6, 7], datatype = float);
> Y := Vector([155625, 172472, 179589, 186579, 205421, 214989, 237937], datatype = float);
> ExponentialFit(X, Y, x, output = residualsumofsquares);
Result by Maple: 0.00216641200893470318
But a real result is 8.159611742*10^7
Please, can anybody help me? Thank you.
First 1417 1418 1419 1420 1421 1422 1423 Last Page 1419 of 2429
