Hi , i need to write some maple functions for the equations below and i am not sure if this should be arrays or not. please see the question below;
Consider a factory which manufactures only one product. Raw material is bought from external supplier and stored until required.
Finished items are held in a warehouse. The operation of factory and its warehouse
can be modelled as a set of equations as folllows.
 Let us define at time t :
R(t) = Raw material stored (units)
F(t) = finished goods stock (units)
B(t) = order backlog (units)
T(t) = target stock level for finished goods (units)
All variables defined above give quantities at the start of week t.
X( t, t+1 )= weekly orders received from customers
M( t, t+1 )= raw material supplied per week.
P( t, t+1 )= production per week.
D(t, t+1 )= amount dispatched to customers per week.
All variables defined above give quantities over week t to t+1
(i.e over the week t). The operation of the factory and its warehouse can be expressed
as a set of equations given as follows:
Backlog and Stock Position
(1) B(t+1) = B(t)+X (t,t+1)–D(t,t+1)
(2) T(t+1) =(m +1)/m(X(t,t+1)+X(t–1,t)+…+X (t–m+1,t–m+2))
(assuming that the company wishes to maintain m (suppose m=5)) weeks stock of
finish items and hence the target level is m times the average of the last m–1 weeks)
(3) R (t+1)=R(t)+M(t,t+1)–P(t,t+1)
(4) F (t+1)=F (t) +P(t,t+1)–D(t,t+1)
Rates
(5) D (t,t+1) = B(t) if B(t)<F(t)
F (t) otherwise
(6) M (t,t+1) = P(t–1,t)
(7) P (t,t+1) = T(t) – F(t) + D(t,t+1)
= R(t) if result exceeds R(t)
= 0 if the result is negative
Given the initial values for the variables, it is possible to simulate this system to study
how the system will respond to the order rate. Suppose that all is calm, and the factory
has operated as follows for the last five weeks.
Target warehouse stock = 250
Finished goods stock = 250
Raw material stock = 150
Production rate = 50/week
Material supply rate = 50/week
Order rate = 50/week
Order backlog = 50
Suppose the behaviour continues for the first week of the simulation but that during
next week orders double due to the sales promotion. During the third week orders
drops to zero as all demand returns of the previous week was satisfied. For the fourth
week and the succeeding weeks, demand returns to an order rate of 50/week. What
happens elsewhere in the system? A deterministic simulation will provide the answer
to the above mentioned question.
 For this compute the following.
i) The values of the equations (1)–(4) at the start of week t.
ii) The values of the equations (5)–(7) i.e. the new values of the rates during
the following week.
iii) Move simulation time to the start of the next week.
Next simulation should be presented in tabular form and plot production and demand
rate to examine the performance of the system.
All help will be much appreciated.
Best Regards,
How can I solve x^2 on -Pi..Pi and to evaluate this at x= Pi to prove that Sum(1/n^2, n= 1..infinity) = Pi^2/6.
I do not have any code to produce yet.  I want to have Maple animate a bouncing ball on some 3d surface.
I want to animate this code
plots[odeplot](Trajectoire, [[x1(t), y1(t), t], [x2(t), y2(t), t], [x3(t), y3(t), t], [x4(t), y4(t), t], [x5(t), y5(t), t], [x6(t), y6(t), t], [x7(t), y7(t),t], [x8(t), y8(t), t], [x9(t), y9(t), t], [xA(t), yA(t), t]], TempsInitial..TempsFinal, numpoints = 10000,axes=boxed, scaling = constrained);
However, Maple 16 is giving me an error message :
Error, (in plots/animate) the first argument must be a procedure
I don't know how I can do to animate this code.
and if the A are an inversable matrix
worksheet output doesnt display the eigenvalues of a 19X19 matrix. Just gives in the form Root of(...). when datatype is indicated as anything other than complex(sflot) it gives error "unable to store". solution is required in compact mathematical expression form (may involve square roots etc). Please help.
restart:with(plots):
h3:=((1+lambda*m*x/a0+phi*((4/Pi*sum((-1)^(n+1)/(2*n-1)*cos(2*Pi*(2*n-1)*x),n=1..infinity)))));
q:=Q-1:
f:=sin(alpha)/E;
DP3:=Int(f-((q*(k+1)*(k+2))/((1-tau)^(k+1)*((h3^(k+2)))*(k+1+tau)))^(1/k),x=0..1);
E:=0.2:phi:=0.2:alpha:=0.1:k:=1:lambda:=0.1:a0:=0.5:m:=0.1:tau:=0.1:
plot((DP3),Q=0..1,axes=box,linestyle=1,color=[red]);
I am unable to plot DP3 vs Q, not only it take very long time but didn't give any output.
Please have a look.
Cheers!
I am looking for a spreadsheet to compute the precession of Mercury fom the Schwarzchilg metric and the geodesic equations. Are you aware of such an example?
When I try "touch and drag" in Maple documents, the documentation for example, I end up selecting text instead of scrolling. Unfortunately the alternatives for scrolling are a) the scrollbar, b) page-up/down or c) moving the cursor. Each of those alternatives is about 2.5311 orders of magnitude more inconvenient than touch&drag.
Does anybody know if its possible to get Maple (18) to scroll instead of select text when I touch the screen?
I am using Maple 17 to solve some equations. I am solving these equations with the solve command. There are some bounds on the parameters so I am including these inequalities. I have 4 variables, so I solve for 3 to get them in terms of the last one.
It returns piecewise solutions as per the inequalties as I hoped.
However for two ranges of the inequalities I get [] which I assume means no solution.
For another range I get an expression for each of my paramters.
For the final range I get 0 . What does this 0 mean and what do the [] mean?
I wondered if 0 meant that all paremeters equalling zero was a solution, but this is false.
Hi there
There seems to be a bug when evaluating elliptic integrals using assuming. Here's an example:
INT:=Int(1/sqrt(a*x^3+1),x=0..X);
is our integral for some a. Now evaluate the integral using assuming on X in different ways:
INT2:=simplify(value(INT)) assuming X>0, a>0, a<1;
INT3:=simplify(value(INT)) assuming X<0, a>0, a<1;
These give analytic solutions which are different. Now plot them both and compare to the numeric solution
plot([subs(a=0.1,INT2),subs(a=0.1,INT3),subs(a=0.1,INT)],X=-1..1,colour=[red,green,blue]);
I'm finding that the red curve which should work for X>0 is wrong, while the green one which is for X<0 is ok for X either sign. [blue is the correct answer - numerically!]
Any ideas?
Good afternoon sir.
Please let me know how to upgrade mu current version Maple17 to Maple 18.
With thanks & Regards
M.Anand
Assistant Professor in Mathematics
SR International Institute of Technology,
Hyderabad, Andhra Pradesh, INDIA.
Good afternoon sir.
I request your kind support to the above cited query.
M.Anand
Good afternoon sir.
I request your kind suggestion to the above cited query.
M.Anand
First 1443 1444 1445 1446 1447 1448 1449 Last Page 1445 of 2429
