I explain the required matrix by taking some example hope you will be understand. Please make it quickly... I will be very thank full. Help_Maple-1.mw
I wan to define a square matrix for M and r detial given in Maple sheet. Please Help....Help_Maple.mwHelp_Maple.mw
Is it possible that this expression has an elementary one (specifically the dilog's):
Y0:=(1/16)*(s*t*(exp(2*t)*s+exp(4*t)+1)*ln((exp(2*t)*s-(-s^2+1)^(1/2)+1)^16*(1+(-s^2+1)^(1/2))^16/((exp(2*t)*s+(-s^2+1)^(1/2)+1)^16*(1-(-s^2+1)^(1/2))^16))+s^3*t*(exp(4*t)+1)*ln((exp(2*t)*s-(-s^2+1)^(1/2)+1)^8*(1+(-s^2+1)^(1/2))^8/((exp(2*t)*s+(-s^2+1)^(1/2)+1)^8*(1-(-s^2+1)^(1/2))^8))+exp(2*t)*t*ln((exp(2*t)*s-(-s^2+1)^(1/2)+1)^32*(1+(-s^2+1)^(1/2))^32/((exp(2*t)*s+(-s^2+1)^(1/2)+1)^32*(1-(-s^2+1)^(1/2))^32))+4*((exp(4*t)+1)*s+2*exp(2*t))*(s^2+2)*dilog((-exp(2*t)*s+(-s^2+1)^(1/2)-1)/(-1+(-s^2+1)^(1/2)))-4*((exp(4*t)+1)*s+2*exp(2*t))*(s^2+2)*dilog((exp(2*t)*s+(-s^2+1)^(1/2)+1)/(1+(-s^2+1)^(1/2)))+((32*s^2*t+64*t)*exp(2*t)+16*(((t+1/8)*s^2+2*t+2)*exp(4*t)-(5/4)*s*exp(-2*t)-(1/8)*exp(-4*t)*s^2+(5/4)*s*exp(6*t)+(1/8)*s^2*exp(8*t)+(t-1/8)*s^2-2+2*t)*s)*arctanh((exp(2*t)-1)*(-1+s)/((-s^2+1)^(1/2)*(exp(2*t)+1)))+8*(-s^2+1)^(1/2)*((1/8)*s*(exp(4*t)+1)*ln((exp(4*t)*s+2*exp(2*t)+s)^12/s^12)+(1/8)*exp(2*t)*ln((exp(4*t)*s+2*exp(2*t)+s)^24/s^24)+(s^2-6*t-3)*exp(2*t)+((-(1/8)*s^2-3*t)*exp(4*t)+s*exp(-2*t)+(1/8)*exp(-4*t)*s^2+s*exp(6*t)+(1/8)*s^2*exp(8*t)-(1/8)*s^2-3*t)*s))/((s*exp(-2*t)+exp(2*t)*s+2)*(exp(4*t)*s+2*exp(2*t)+s)*((-s^2+1)^(1/2)+2*arctanh((-1+s)/(-s^2+1)^(1/2))))
Also I'm wondering since Y0 should solve the ode
-(diff(diff(y(t), t), t))+(4-12/(1+s*cosh(2*t))+8*(-s^2+1)/(1+s*cosh(2*t))^2)*y(t) = C/(1+s*cosh(2*t))
with some constant C but I only get rubbish.
I ask this because I found that in another context this seems to be correct:
f1:=-(1/12)*Pi^2*((-s^2+1)^(1/2)-arccosh(1/s))/(-s^2+1)^(3/2)+(1/12)*arccosh(1/s)^3/(-s^2+1)^(3/2)-(1/4)*arccosh(1/s)^2/(-s^2+1)
f2:=(1/2)*((-s^2+1)^(1/2)*(polylog(2, s/(-1+(-s^2+1)^(1/2)))+polylog(2, -s/(1+(-s^2+1)^(1/2))))-polylog(3, s/(-1+(-s^2+1)^(1/2)))+polylog(3, -s/(1+(-s^2+1)^(1/2))))/(-s^2+1)^(3/2)
and f1=f2
but maple doesnt convert it.
Also maple has trouble to convert
2*arctanh(sqrt((1-s)/(1+s)))=arccosh(1/s)
everywhere: 0<s<1
Aslam-u-Alikum. How are you. I want to make band matrix by using two vector. Detail given in Maple fine also. Please help me urgent.Help.mw
Is it possible to find the limit
limit(int(x*cos(x)/(1+3*sin(n*x)^2), x = 0 .. Pi), n = infinity)assuming n::posint
with Maple?
Calculations suggest the one equals -1.
I calculated following two expressions, x1,and x2.
x1:=map(f,a+b);
x2:=map(f,y=a+b);
The results of these are
f(a) + f(b)
f(y) = f(a + b)
for each. And, I can understand the logic of this.
If I want to derive the result of x2 as f(y)=f(a)+f(b), how should I do about x2?
Isn't there other way than to write
map(f, lhs(x2))=map(f,rhs(x2))
Please teach me this.
Thank you in advance.
Taro
How can I get maple to integrate this expression numerically.
For a specific value 0<s<1 it should be enough to integrate from -40..40 instead of -infinity..infinity
Anyway. My maple version always hangs up :-(
(1/2)*(-4*dilog(-(exp(2*t)*s-(-s^2+1)^(1/2)+1)/(-1+(-s^2+1)^(1/2)))*exp(4*t)+arctanh((-1+s)/(-s^2+1)^(1/2))*s^2+arctanh((exp(2*t)*s-exp(2*t)-s+1)/((exp(2*t)+1)*(-s^2+1)^(1/2)))*s^2+8*(-s^2+1)^(1/2)*exp(4*t)+4*dilog((exp(2*t)*s+(-s^2+1)^(1/2)+1)/(1+(-s^2+1)^(1/2)))*exp(4*t)+4*exp(4*t)*arctanh((-1+s)/(-s^2+1)^(1/2))-8*arctanh((exp(2*t)*s-exp(2*t)-s+1)/((exp(2*t)+1)*(-s^2+1)^(1/2)))*exp(4*t)*s^2*t-4*ln(1+(-s^2+1)^(1/2))*exp(4*t)*s^2*t+4*ln(1-(-s^2+1)^(1/2))*exp(4*t)*s^2*t-4*ln(exp(2*t)*s-(-s^2+1)^(1/2)+1)*exp(4*t)*s^2*t+4*ln(exp(2*t)*s+(-s^2+1)^(1/2)+1)*exp(4*t)*s^2*t+12*(-s^2+1)^(1/2)*exp(4*t)*t-16*arctanh((exp(2*t)*s-exp(2*t)-s+1)/((exp(2*t)+1)*(-s^2+1)^(1/2)))*exp(4*t)*t-8*ln(1+(-s^2+1)^(1/2))*exp(4*t)*t+8*ln(1-(-s^2+1)^(1/2))*exp(4*t)*t-8*ln(exp(2*t)*s-(-s^2+1)^(1/2)+1)*exp(4*t)*t+8*ln(exp(2*t)*s+(-s^2+1)^(1/2)+1)*exp(4*t)*t-(-s^2+1)^(1/2)*exp(2*t)*s+8*arctanh((exp(2*t)*s-exp(2*t)-s+1)/((exp(2*t)+1)*(-s^2+1)^(1/2)))*exp(2*t)*s+4*exp(2*t)*arctanh((-1+s)/(-s^2+1)^(1/2))*s-(-s^2+1)^(1/2)*exp(6*t)*s-8*arctanh((exp(2*t)*s-exp(2*t)-s+1)/((exp(2*t)+1)*(-s^2+1)^(1/2)))*exp(6*t)*s+4*exp(6*t)*arctanh((-1+s)/(-s^2+1)^(1/2))*s+2*dilog((exp(2*t)*s+(-s^2+1)^(1/2)+1)/(1+(-s^2+1)^(1/2)))*exp(4*t)*s^2+2*(-s^2+1)^(1/2)*exp(4*t)*s^2-arctanh((exp(2*t)*s-exp(2*t)-s+1)/((exp(2*t)+1)*(-s^2+1)^(1/2)))*exp(8*t)*s^2+exp(8*t)*arctanh((-1+s)/(-s^2+1)^(1/2))*s^2+2*exp(4*t)*arctanh((-1+s)/(-s^2+1)^(1/2))*s^2-6*(-s^2+1)^(1/2)*ln(exp(4*t)*s+2*exp(2*t)+s)*exp(4*t)+6*(-s^2+1)^(1/2)*ln(s)*exp(4*t)-2*dilog(-(exp(2*t)*s-(-s^2+1)^(1/2)+1)/(-1+(-s^2+1)^(1/2)))*exp(4*t)*s^2)/((-s^2+1)^(1/2)*exp(8*t)*s^2-2*arctanh((-s^2+1)^(1/2)/(1+s))*exp(8*t)*s^2+4*(-s^2+1)^(1/2)*exp(6*t)*s-8*arctanh((-s^2+1)^(1/2)/(1+s))*exp(6*t)*s+2*(-s^2+1)^(1/2)*exp(4*t)*s^2-4*arctanh((-s^2+1)^(1/2)/(1+s))*exp(4*t)*s^2+4*(-s^2+1)^(1/2)*exp(4*t)-8*arctanh((-s^2+1)^(1/2)/(1+s))*exp(4*t)+4*(-s^2+1)^(1/2)*exp(2*t)*s-8*arctanh((-s^2+1)^(1/2)/(1+s))*exp(2*t)*s+(-s^2+1)^(1/2)*s^2-2*arctanh((-s^2+1)^(1/2)/(1+s))*s^2)
I have an equation as follows:
By inspection one can see that the last three terms can be simplified (factored) to
How can I coerce Maple to do this? None of the available tools seem to be getting close to this. A partial solution is like this: Writ a procedure as follows:
Fac:=proc(xpr,a,b);
  tmp:=xpr+(a^2+2*a*b+b^2);
  return tmp-(a+b)^2;
and then call it:
Fac(lhs(eq),k0,2*Pi*n/L)=rhs(eq);
to get
which is what I want. But procedure Fac() is not general at all; e.g. it fails if the overall sign of the polynomial terms are different. There does not seem to be any way in Maple to determine the sign of a term in the sum of lhs(eq), I can only find ways to determine signs of a simple indeterminate. I'd like to make this procedure more general (which is trivial enough for a human) but I just cannot find any tools in Maple to support this.
Any ideas out there?
Mac Dude.
after a matrix operation, the result is not exactly the matrix i want
there is around 0.0001 difference difference in all element in matrix
how to deal with this random difference in order to be exact?
In order to get a little acquainted with the Grassmannian capabilities of the Physics package, I presently consider the following simple setup:
with(Physics):
Setup(
   mathematicalnotation = true,
   anticommutativepre   = theta
A := Matrix(2,(i,j) -> theta||i||j);
B := A . A;
C := Expand(B);
producing for A, B, and C the following results:
To me the [2,2]-entry of B seems erroneous: the first addend has the wrong ordering of the theta's, or, equivalently, the wrong sign. Not so surprisingly, this error is then present also in the [2,2]-entry of C. But in C, the [1,2]- and [2,1]-entries seem erroneous as well: the sign of theta11 in the [1,2]-entry is wrong, and so, too, is the sign of theta22 in the [2,1]-entry.
Have I fundamentally misunderstood something?
Hi everyone,
I have a very complicated function y with only one independent variable x, and want to fit or approximate it by a simpler function, say polynomial. Many books or maple reference seem to tell how to fit a set of data instead of a given function. But the argument x in the function is assumed to be continuous other than discrete, so I don't know whether it is possible to express datax in form of x's range such as 0..1, and express datay in form of the function. After that , maybe I can fit the two created data sets by a polynomial function.
Or, does anyone have a better or more direct way to do the fitting linking two fucntions?
I am appreciated for your help.
Best,
GOODLUCK
I have the following expression (obtained from an earlier calculation):
I want to collect all the terms under one summation. So I define a rule:
collectf:=proc(f)
A::algebraic*f(a::algebraic)+B::algebraic*f(b::algebraic)\
 +C::algebraic*f(c::algebraic)+D::algebraic*f(d::algebraic)=f(A*a+B*b+C*c+D*d);
and then
applyrule(collectf(Sum),%);
I get
Error, (in +) unable to identify A::algebraic
I used similar constructs before so I think the rule is constructed correctly. I should, however, mention that I use the Physics:-Vectors package and in fact the expression I start up with here reads, in 1-d Maple inputform:
Physics[Vectors][`+`](Physics[Vectors][`+`](Physics[Vectors][`+`](-y*(Sum((diff(a[n](r), r))/(exp(I*Pi*n/L))^2, n))/r, (2*I)*(Sum(a[n](r)/(exp(I*Pi*n/L))^2, n))*k0), y*(Sum(a[n](r)/(exp(I*Pi*n/L))^2, n))*k0^2), -y*(Sum((diff(a[n](r), r, r))/(exp(I*Pi*n/L))^2, n)))
Is my problem related to the use of Physics:-Vectors? If so, how can I get around that?
TIA,
Mac Dude
How can I show the expression of the following summation as the output, not 11?
3+7+1
Hi all and happy new year
First I am a beginner in Maple and I want to solve an equation, but I obtain a complexe result with this _Z, my equation is 6th order and the unkown is alpha:
I tried these instructions but without resul:
z := solve(my eq,alpha)
zsol := allvalues(z)
evalf(zsol)
And I get this result
I want a simple result and what is the meaning of _Z
 For some reason maple does not simplify root in the following cases:
sqrt((c^2, r^2));
another one is
sqrt(4), ....
Such square roots occur after this command:
eigenvectors := simplify(simplify(evectors, g * (g - 1) * (e - u * u + v * v + w * w) * 1/2 = c * c), sqrt, simbolic)
First 1480 1481 1482 1483 1484 1485 1486 Last Page 1482 of 2429
