Looking at the code of PDEtools:-declare, one sees that it does some brief initializing and then passes the job off to `PDEtools/declare`. I'd like to view this latter procedure, but I can't find it. It is not at the top level, nor is it an export or local of module PDEtools. So where is it?
How to find the sum of the products given below
where I couldn't write j not equal to i in the product.
sum(a[i],i=1..n)*product(s-b[j],j=1..n)
Has anyone an idea how to integrate
int(t^2/(1+s*cosh(2*t))^2,t=-infinity..infinity)
0<s<1
FirstEigenVector := Matrix(3, 1, {(1, 1) = -.736895432967255+0.*I, (2, 1) = -.588906969844997+0.*I, (3, 1) = -.331924240964690+0.*I});
SecondEigenVector := Matrix(3, 1, {(1, 1) = -.589856901397123+0.*I, (2, 1) = .320280857681335+0.*I, (3, 1) = .741275257969058+0.*I});
ThirdEigenVector := Matrix(3, 1, {(1, 1) = .330233185410229+0.*I, (2, 1) = -.742030156443046+0.*I, (3, 1) = .583384341736151+0.*I});
LHS := ProjOfEigenVector;
LHS := Matrix(3, 3, {(1, 1) = -.736895432967255+0.*I, (1, 2) = -.589856901397123+0.*I, (1, 3) = .330233185410229+0.*I, (2, 1) = -.588906969844997+0.*I, (2, 2) = .320280857681335+0.*I, (2, 3) = -.742030156443046+0.*I, (3, 1) = -.331924240964690+0.*I, (3, 2) = .741275257969058+0.*I, (3, 3) = .583384341736151+0.*I});
RHS := c1*FirstEigenVector+c2*SecondEigenVector+c3*ThirdEigenVector;
RHS := Matrix(3, 1, {(1, 1) = (-.736895432967255+0.*I)*c1+(-.589856901397123+0.*I)*c2+(.330233185410229+0.*I)*c3, (2, 1) = (-.588906969844997+0.*I)*c1+(.320280857681335+0.*I)*c2+(-.742030156443046+0.*I)*c3, (3, 1) = (-.331924240964690+0.*I)*c1+(.741275257969058+0.*I)*c2+(.583384341736151+0.*I)*c3});
solve([LHS[1][1] = RHS[1][1], LHS[2][2] = RHS[2][1], c1^2+c2^2+c3^2 = 1], [c1, c2, c3]);
after calculated the projection matrix,
it is a 3*3 matrix on left hand side
however, combination of eigenvectors on right hand side is 3*1 matrix
when calculated c1,c2,c3 under the condition c1^2+c2^2+c3^2 = 1
how to know whether LHS[1][1] = RHS[1][1], or LHS[1][2] = RHS[1][1] or
LHS[1][3] = RHS[1][1]
How to create a borel set from a list of decimal
if i interpolate three decimal number and solve it,
if any number substitute into this result which is a inverse function, can the results be said borel set?
t:=1;
NewMatrix3 := Matrix([[test10, close3(t) , close3(t+1)],
[close3(t) , close3(t+1) ,0],
[close3(t+1) , 0,0]]);
Matrix(3, 3, {(1, 1) = test10, (1, 2) = 5.59, (1, 3) = 5.74, (2, 1) = 5.59, (2, 2) = 5.74, (2, 3) = 0, (3, 1) = 5.74, (3, 2) = 0, (3, 3) = 0})
NewEigenMatrix := Eigenvalues(NewMatrix3);
solve([MatrixMatrixMultiply(NewMatrix3,Matrix([[x],[y],[z]]))[1][1] = NewEigenMatrix[1]* Matrix([[x],[y],[z]])[1][1],
MatrixMatrixMultiply(NewMatrix3,Matrix([[x],[y],[z]]))[2][1] = NewEigenMatrix[1]* Matrix([[x],[y],[z]])[2][1],
MatrixMatrixMultiply(NewMatrix3,Matrix([[x],[y],[z]]))[3][1] = NewEigenMatrix[1]* Matrix([[x],[y],[z]])[3][1]]
, [x,y,z]);
When i look into 'maple help' for Pade approximation, it only show a code for solving equation involving 1 variable only..what is the code for equation involving 2 or more variable for pade approximation?
Hi everyone
I'd be pleased if you could give a hand with the exploration assistant.
1. I want the exploration assistant to appear on the same document I am working on, but everytime I use it (either by right-clicking or by the explore command) it automatically appears on a new document.
2. can I manipulate a piecewise function when using embedded components? i.e.: plot the function and varying the parameters using sliders.
cesar
I have made a maplet. The aim is to take two numbers in textboxes and find their Jacobi symbol. The result should appear in a third textbox. Now I have done all the steps and called a procedure on buttonclick. Following is the procedure I have made
jacob := proc (x, y)
local A, B;
A := x;
B := y;
with(numtheory);
jacobi(A, B)
Problem: The problem is that when I make any small modification to the code it runs and shows the result in the 3rd textbox but as soon as I save it, restart maple and recompile the program, the textbox 3 will show jacobi(value of textbox1, value of textbox2) instead of the result. What should I do, actually I am new to maple. Please guide me.
k := a*x6^7 + b*x6^6 + c*x6^5 + d*x6^4 + e*x6^3 + f*x6^2 + g*x6;
discrim(k, x6);
after know the discriminant equation, how to do next?
solve(Max(Min(x, 1), Min(x, 2)));
solve(Min(Max(x, 1), Max(x, 2)));
i do not know how to use Rootof something
any other expression
Please, I solved a pde system of equation problem numerically, using maple 17.
But I dont know how to plot multiple solutions on one graph.
I want to vary one of the parameters....
e.g Pr=0.71, Pr=7, Pr=10 where other parameters are kept constant
My working is attachedtobi_msc_solution.mw
M := 1:
pde1 := diff(u(y, t), t)+Typesetting:-delayDotProduct(S, diff(u(y, t), y))-2*k^2*u(y, t) = diff(u(y, t), y, y)+theta(y, t)+Typesetting:-delayDotProduct(N, C(y, t))+Typesetting:-delayDotProduct(M, u(y, t))+u(y, t)/K:
                pde2 := theta(y, t)+t*(diff(theta(y, t), t))+S*(diff(theta(y, t), y)) = (diff(theta(y, t), y, y))/Pr-Typesetting:-delayDotProduct(alpha, theta(y, t)):
pde3 := C(y, t)+t*(diff(C(y, t), t))+S*(diff(C(y, t), y)) = (diff(C(y, t), y, y))/Sh-Typesetting:-delayDotProduct(R, C(y, t)):
PDE := {pde1, pde2, pde3}:
IBC := {C(0, t) = 1, C(1, t) = 0, C(y, 0) = 0, u(0, t) = 0, u(1, t) = 0, u(y, 0) = 0, theta(0, t) = 1, theta(1, t) = 0, theta(y, 0) = 0}:
pds := pdsolve(PDE, IBC, numeric)
pds:-plot[display](u(y, t), t = .5, linestyle = "solid", colour = "blue", legend = "Pr=0.71", title = "Velocity Profile", labels = ["y", "theta"])
Download tobi_msc_solution.mw
Please, Any help will be gracefully appreciated
I am solving a system of 8 boundary value differential equations with boundary conditions:
> restart; with(plots);
 eq1 := alpha*(F(eta)+(1/2)*eta*(diff(F(eta), eta)))+F(eta)*F(eta)-G(eta)*G(eta)+H(eta)*(diff(F(eta), eta))-(diff(F(eta), `$`(eta, 2)))-beta*(f(eta)-Q(eta)*F(eta)) = 0;
 eq2 := alpha*(G(eta)+(1/2)*eta*(diff(G(eta), eta)))+2*F(eta)*G(eta)+H(eta)*(diff(G(eta), eta))-(diff(G(eta), `$`(eta, 2)))-beta*(g(eta)-Q(eta)*G(eta)) = 0;
 eq3 := (1/2)*alpha*(H(eta)+eta*(diff(H(eta), eta)))+H(eta)*(diff(H(eta), eta))+diff(P(eta), eta)-(diff(H(eta), `$`(eta, 2)))-beta*(h(eta)-Q(eta)*H(eta)) = 0;
 eq4 := alpha*((Q(eta)*Q(eta))*f(eta)+((1/2)*eta*Q(eta)*Q(eta))*(diff(f(eta), eta))-(1/2)*eta*Q(eta)*f(eta)*(diff(Q(eta), eta)))+Q(eta)*f(eta)*f(eta)-Q(eta)*g(eta)*g(eta)+h(eta)*Q(eta)*(diff(f(eta), eta))-h(eta)*f(eta)*(diff(Q(eta), eta))+beta*((Q(eta)*Q(eta))*f(eta)-(Q(eta)*Q(eta))*Q(eta)*F(eta)) = 0;
 eq5 := alpha*((Q(eta)*Q(eta))*g(eta)+((1/2)*eta*Q(eta)*Q(eta))*(diff(g(eta), eta))-(1/2)*eta*Q(eta)*(diff(g(eta), eta))*(diff(Q(eta), eta)))+2*Q(eta)*f(eta)*g(eta)+h(eta)*Q(eta)*(diff(g(eta), eta))-h(eta)*g(eta)*(diff(Q(eta), eta))+beta*((Q(eta)*Q(eta))*g(eta)-(Q(eta)*Q(eta))*Q(eta)*G(eta)) = 0;
 eq6 := (1/2)*alpha*((Q(eta)*Q(eta))*h(eta)+(eta*Q(eta)*Q(eta))*(diff(h(eta), eta))-eta*h(eta)*Q(eta)*(diff(Q(eta), eta)))+Q(eta)*h(eta)*(diff(h(eta), eta))-(h(eta)*h(eta))*(diff(Q(eta), eta))+beta*((Q(eta)*Q(eta))*h(eta)-(Q(eta)*Q(eta))*Q(eta)*H(eta)) = 0;
 eq7 := 2*F(eta)+diff(H(eta), eta) = 0;
 eq8 := 2*f(eta)+diff(h(eta), eta) = 0;
bc := {F(0) = 1, G(0) = 1, H(0) = 0, F(8) = 0, G(8) = 0, f(8) = 0, g(8) = 0, h(8)-.2*H(8) = 0, Q(8) = .2, P(8) = 0};
sys:={bc, eq1, eq2, eq3, eq4, eq5, eq6, eq7, eq8};
para:= {alpha=0.5, beta=0.5};
A1 := dsolve(subs(para, {bc, eq1, eq2, eq3, eq4, eq5, eq6, eq7, eq8}), numeric, method = bvp[midrich], output = array([seq(0.1e-1*i, i = 0 .. 100*N)]))
But i am getting the error
"Error, (in dsolve/numeric/bvp/convertsys) unable to convert to an explicit first-order system".
I can't understand where is the problem. Please help
i am trying to built a maplet which can encode and decode.  for example i have Ceasar encryption codes and i want to built a maplet that can do it.
you can see below one of my try: encode is working but decode didnt work :/ what should i do?
with(Maplets[Elements]):
with(StringTools):
alphabet := convert([97, 98, 99, 231, 100, 101, 102, 103, 240, 104, 253, 105, 106, 107, 108, 109, 110, 111, 246, 112, 114, 115, 254, 116, 117, 252, 118, 121, 122],bytes):
code:= letter -> SearchText(letter,alphabet)-1:
char := i -> alphabet[i+1]:
modulus := Length(alphabet):
shift := proc(key);
i -> (i+key) mod modulus;
end:
CaesarEnc :=()-> Action(Evaluate('cpmessage'= 'Implode(map(char,map(shift('ky'),map(code,Explode('text')))))')):
CaesarDec := () -> Action(Evaluate('cpmessage' = 'CaesarEnc(-'ky','text')')):
Caesar := Maplet(Window('title'= "Caesar Encoding And Decoding", BoxLayout['BL1']( BoxColumn('halign'=left,
BoxRow(Label['l1']("Write message: ",'width'=100,'halign'=left), TextBox['text']('background'=white,'foreground'= brown,'height'=6,'editable'=true,'width'=50)),BoxRow(Label['l2']("Key: ",'width'=100,'halign'=left), TextBox['ky']('background'=white,'foreground'= black,'height'=3,'editable'=true,'width'=50)),Button("Encode",'onclick'=CaesarEnc()), Button("Decode",'onclick'=CaesarDec()),BoxRow(Label['l3']("Text: ",'width'=100,'halign'=left), TextBox['cpmessage']("",'background'=white,'foreground'= blue,'height'=6,'editable'=false,'width'=50) ))))):
Maplets[Display](Caesar);
i need to do it for my thesis. waiting for your answers, thank you :)
hey i am new here and i have a question,
i have an partial differential equation diff(u(t,x),t$2)=diff(u(t,x),x$2) with the intial value problem u(0,x)=f(x)=1/(1+x^2) and diff(u(0,x),t)=0
and now my question i have already programm it:
> with(inttrans);
with(DEtools);
> with(PDETools);
> k := diff(u(t, x), `$`(t, 2)) = diff(u(t, x), `$`(x, 2));
bc := u(0, x) = 1/(1+x^2);
v := diff(u(0, x), t) = 0;
d / d \ d / d \
--- |--- u(t, x)| = --- |--- u(t, x)|
dt \ dt / dx \ dx /
u(0, x) = ------
1 + x
0 = 0
> pdsolve(k, u(t, x));
print(`output redirected...`);
u(t, x) = _F1(x + t) + _F2(x - t)
> c := pdsolve({bc, k, v}, u(t, x));
 and now question at the last there is nothing does it means that maple can´t solve it with the intial value problem and how can solve it with Fourier-Transformation to x???
can anyone help me please and sorry my englisch is not so good ;)
First 1481 1482 1483 1484 1485 1486 1487 Last Page 1483 of 2429
