Here is the layout challenge: Whenever the value of a physical quantity is one as in
mass = 1* Unit('kg')
automatic simplification removes the one and the output displays
Desired would be which reads better (in particular when used inline in text passages).
Using the Empty Symbol
mass = ``(1)*Unit('kg')
an expression with parenthesis is obtained (that can be removed in subsequent calculations with the expand command) which looks worse than my current workaround of using floats
(Introducing floats in expressions is not always acceptable)
So the idea would be to use the empty symbol for initial parameter definition in textbook style layout and remove it with expand in subsequent calculations.
Any other symbol that prints as "1" that can be removed in later calculations by Maple commands is welcome as well. It should be better than
mass=`#mrow(mo("1"));`*Unit('kg');
subs(`#mrow(mo("1"));` = 1, %);
I wrote a little simple minded procedure for finding the sum of divisors for a positive integer.  I thought I would share.
sum_of_proper_divisors.mw
sum_of_proper_divisors.pdf
Has someone written better code for this task?
Matt
When there are print commands in a loop their content is printed as soon as this command is executed.
This is not the case with printf whose displays are delayed (buffered?).
Is there a way to force the display of printf when the command is executed?
TIA
Motivation: I want to display intermediate execution times in a prettier way than print offers.
Is it possible to enlarge the sliders in Explore(plot(...), ...) and increase their "resolution" (meaning to have a higher precision when the slider is moved)?
If Maple does offer this option, could you tell me from what version this is the case
TIA
For a project I need to construct a large symbolic adjoint matrix, hoping it can be factored afterward into nice expressions.
In the worksheet, I present an adjoint matrix using permuted Hadamard products. What puzzles me is that only for even dimensions, I need to multiply it (elementwise) with a parity matrix. Okay, not a specific Maple question, but maybe someone can help me out.
Download Adjoint.mw
The attached worksheet shows that Maple 2023 produces an incomplete plot of a function.  Maple 2021, however, produces the full graph.  I wonder if Maple 2023's behavior is due to a bad setting in my environment or a plotting bug in Maple.
kernelopts(version);
`Maple 2023.2, X86 64 LINUX, Oct 25 2023, Build ID 1753458`
y := -cos(sqrt(x))*x^3/(-x^2 + 24*cos(sqrt(x)) + 12*x - 24);
-cos(x^(1/2))*x^3/(-x^2+24*cos(x^(1/2))+12*x-24)
plot(y, x=0..1);
Here is the graph of the same function plotted correctly in Maple 2021:
Download cannot-plot.mw
I would like to plot graph of 2d function f(x, y) = (-ax/(1+y^2), x+by) where x from -5 to 5 and y from -5 to 5 and parameter bar of a and b. Thank you
Axis properties and line width reverts to some set of defaults each time my work recalculates the plot. Is there a way I can keep the axis properties and line width from changing each time recalculation occurs?
I've used LinearSolve(A,b) to find three unknowns. How do I assign these values to three named variables?
I assigned the resulting vector to a new one
V:=LinearSolve(A,b)
and then, one by one, assigned the elements to variables
C1:= V[1}
C2:= V[2]
C3:= V[3]
But there perhaps is a more elegant way to do this?
As I am new to using the statistics package, I have some doubts about how to perform certain operations in Maple.
For example, let sigma be a variable containing any real number, finding the average is easy, just use the command A0:=Median(sigma) and if you want A (see image below) just take A1:=A0^2. However, the terms that make up <sigma^2> cause a certain difficulty, how to do this? In other words, calculate the B of the image?
sigma := [2, 4, 0, 6]
AMedia := (2 + 4 + 0 + 6)/4;
AMedia1 := AMedia^2;
A0 := Median(sigma)
A1 := A0^2
BMedia := (2^2 + 4^2 + 0^2 + 6^2)/4
sigma0 := sigma^2
sigma1 := Mean(sigma0)
hi every one.
in the attached maple file at line x=o in the plotted figure we have some inconsistency in starting the branches from x=0 and the branches do not start from the same value on this axis.
I can not find the problem because there are not any differences between phi 1 and phi 2!
evalf(f1 - f2)= -5* 10 ^-49
h-x_nemodar-e.mw
Good day,
I am trying to solve the following problem.
For the following system:
With the following initial condition
What are the smallest e1 and e2 that would solve the system?
I would try a graphical approach to find them, but I don’t seem to set the correct procedure.
Thanks in advance!
How to clear this error and frame the series
FWF.mw
I thought I was improving my code by adding ::type to all the _self in my OOP code. As this is one main advantage in programming in Maple, which is being able to attach types to all name and variables. Make code more robust.
But it turned out Maple is not very happy now and gives that drearded error
    Error, static procedure ... refers to non-static local or export ... in surrounding scope
Only place I found that adding ::type_name is to _self is allowed, is on the constructor signature.
But in no other method of the object module. local or export method, it does not matter.
My question is, why is that?
So I went and removed all those _self::type_name and made it just _self to make Maple happy.
I also noticed this happes regardless of having kernelopts('assertlevel'=2): there or not.  Attached  is the worksheet.
Just tryting to understand the logic, that is all.
This is using Maple 2023.2.1
interface(version)
interface(warnlevel=4);
A:=module()
  export module person()
   option object;
   local m_name::string;
   local m_age::integer;
   export ModuleCopy::static:=proc(_self::A:-person,proto::A:-person,name::string,age::integer,$)
          _self:-m_age := age;
          _self:-m_name:=name;
          NULL;
   export name::static:=proc(_self,$) m_name; end proc;
   export age::static:=proc(_self,$) m_age; end proc;
 end module;
export  module young_person()
   option object;
   local m_person::A:-person;
   export ModuleCopy::static:=proc(_self::A:-young_person,proto::A:-young_person,p::A:-person,$)
          _self:-m_person := p;
          _self:-process_it();
   local process_it::static:=proc(_self,$)
         print(m_person:-name());
         print(m_person:-age());
   #to fix the problem, check _self::A... to just _self,  then no error!
   export process_it_from_outside::static:=proc(_self::A:-young_person,$)
end module;
end module;
_m2782933017664
o:=Object(A:-person,"me",99);
module person () local m_name::string, m_age::integer; option object; end module
p:=Object(A:-young_person,o);
Error, static procedure `young_person:-process_it_from_outside` refers to non-static local or export `young_person:-m_person::A:-person` in surrounding scope
Download why_adding_type_on_self_gives_error.mw
First 149 150 151 152 153 154 155 Last Page 151 of 2429
