I can't seem to find what's wrong with this function:
F:= x-> (-c-ax)/b;
G:=x-> (-d-ex)/f;
If -a/b = -e/f then print (false) else print (true); end if;
Hey all new to Maplesoft my question is this;
i have 3 equations which contains both numeric and symbols, how can i seprrate these to ?
for example :
> restart:
> eq1:=a[1]^3+a[2]+a[3]^2+50;
> eq2:=a[1]^2+5*a[2]+a[3]+44;
> eq3:=a[1]+a[2]+a[3]^2+74;
i want maple to seprate these three equations in two vectors,first vector including symbols and second one includes numerics , like this :
V1:=<<a[1]^3+a[2]+a[3]^2>,<a[1]^2+5*a[2]+a[3]>,<a[1]+a[2]+a[3]^2>>;
V2:=<<50>,<44>,<74>>;
eq:=<<eq1>,<eq2>,<eq3>>;
so that
is(V1+V2=eq);
gives me the answer true.
tnx for help.
For a control systems project I'am working on I need to minimize the actuator effort required to control an input voltage to certain output voltage. As a first experiment I chose a sinusoidal input ug and a sinusoidal output ul. The function to minimize is the funtion Uint. We know that when both the input voltage and output voltage share the frequency, phase and amplitude, that the control effort is zero. Running the animation (see Maple input below) shows that if the input and output voltage frequencies approach eachother the function Uint goes to zero. However, if the frequencies exactly match and I evaluate the function Uint I get a devision by zero notification (this could already be seen from the function of Uint). How can I solve this?
u[G] := sin(omega[G]*t)
u[L] := sin(omega[L]*t)
U[int] := int((u[G]-u[L])^2, t)
omega[G] := 9:
animate(plot, [[u[G], u[L], (1/10)*U[int]], t = 0 .. 5, legend = ["Public grid voltage", "Local grid voltage (control goal)", "Cum. Actuator voltage (scaled)"]], omega[L] = 8 .. 10, gridlines = true, labels = ["Time [s]","Voltage [V]"], labeldirections = ["horizontal", "vertical"], labelfont = ["ARIAL", "bold", 12])
omega[L] := 9; t := 10; evalf(U[int])
Download 20131109_Division_by.mw
I have just started using Maple 17 for general relativity, and I have managed to set up coordinates and enter a somewhat complicated spacetime metric, and to find the Killing vectors for the metric.
I can't seem to do something much more basic, though, initialize the components of a vector field as functions of the coordinates.
For example, how would I set up a 4-vector field A such that the contravariant component A^3 = cosh(x2), where x2 is one of my coordinates?
with(Optimization):
with(Statistics):
with(DEtools):
x11 := <0.208408965651696e-3, -0.157194487523421e-2, -0.294739401402979e-2, 0.788206708183853e-2, 0.499394753201753e-2, 0.191468321959759e-3, 0.504980449104750e-2, 0.222150494088535e-2, 0.132091821964287e-2, 0.161118434883258e-2, -0.281236534046873e-2, -0.398055875132037e-2, -0.111753680372819e-1, 0.588868146012489e-2, -0.354191562612469e-2, 0.984082837373291e-3, -0.116041186868374e-1, 0.603027845850267e-3, -0.448778128168742e-2, -0.127561485214862e-1, -0.412027655195339e-2, 0.379387381798949e-2, -0.602550446997765e-2, -0.605986284736216e-2, -0.751396992404410e-2, 0.633613424008655e-2, -0.677581832613623e-2>;
y11 := <-21321.9719565717, 231.709204951251, 1527.92905167191, -32.8508507060675, 54.9408176234139, -99.4222178124229, -675.771433486265, 42.0838668074923, -12559.3183308951, 5.21412214166344*10^5, 1110.50031772203, 3.67149699000155, -108.543878970269, -8.48861069398811, -521.810552387313, 26.4792411876883, -8.32240296737599, -1085.40982521906, -44.1390030597906, -203.891397612798, -56.3746416571417, -218.205643256096, -178.991498697065, -42.2468018350386, .328546922634921, -1883.18308996621, 111.747881085748>;
z11 := <1549.88755331800, -329.861725802688, 8.54200301129155, -283.381775745327, -54.5469129127573, 1875.94875597129, -16.2230517860850, 6084.82381954832, 1146.15489803104, -456.460512914647, 104.533252701641, 16.3998365630734, 11.5710907832054, -175.370276462696, 33.8045539958636, 2029.50029336951, 1387.92643570857, 9.54717543291120, -1999.09590358328, 29.7628085078953, 2.58210333216737*10^6, 57.7969622731082, -6.42551196941394, -8549.23677077892, -49.0081775323244, -72.5156360537114, 183.539911458475>;
ICS:=[x1(0)=x11[1],y1(0)=y11[1],z1(0)=z11[1]];
N := Dimension(x11)-1:
sys1 := [Diff(x1(t),t) = k1*x1(t)+ k2*y1(t)+ k3*z1(t), Diff(y1(t),t) = k5*x1(t)+ k6*y1(t)+ k7*z1(t), Diff(z1(t),t) = k9*x1(t)+ k10*y1(t)+ k11*z1(t)];
SS := proc(k1,k2,k3,k5,k6,k7,k9,k10,k11)
local F, V;
if not type([k1,k2,k3,k5,k6,k7,k9,k10,k11],[numeric,numeric,numeric,numeric,numeric,numeric,numeric,numeric,numeric]) then return 'SS'(k1,k2,k3,k5,k6,k7,k9,k10,k11);
elif k1<0 or k2<0 or k3<0 or k5<0 or k6<0 or k7<0 or k9<0 or k10<0 or k11<0 then return 1e100;
F := dsolve(eval({Diff(x1(t),t) = k1*x1(t)+ k2*y1(t)+ k3*z1(t), Diff(y1(t),t) = k5*x1(t)+ k6*y1(t)+ k7*z1(t), Diff(z1(t),t) = k9*x1(t)+ k10*y1(t)+ k11*z1(t),x1(0)=x11[1],y1(0)=y11[1],z1(0)=z11[1]},{:-k1=k1,:-k2=k2,:-k3=k3,:-k5=k5,:-k6=k6,:-k7=k7,:-k9=k9,:-k10=k10,:-k11=k11}), [x1(t),y1(t),z1(t)], numeric, output=Array([seq(k,k=0..N)]));
V := convert(Column(F[2,1],2),Vector);
Norm(V-x11,2);
Norm(V-y11,2);
Norm(V-z11,2);
params := NLPSolve(SS(k1,k2,k3,k5,k6,k7,k9,k10,k11), method=nonlinearsimplex, initialpoint=[k1=.1, k2=.1, k3=.1, k5=.1, k6=.1, k7=.1, k9=.1, k10=.1, k11=.1],evaluationlimit=200):
Warning, limiting number of function evaluations reached
reference from
http://www.maplesoft.com/applications/view.aspx?SID=1667
when debug
k1=.1; k2=.1; k3=.1; k5=.1; k6=.1; k7=.1; k9=.1; k10=.1; k11=.1;
F := dsolve({Diff(x1(t),t) = k1*x1(t)+ k2*y1(t)+ k3*z1(t), Diff(y1(t),t) = k5*x1(t)+ k6*y1(t)+ k7*z1(t), Diff(z1(t),t) = k9*x1(t)+ k10*y1(t)+ k11*z1(t),x1(0)=x11[1],y1(0)=y11[1],z1(0)=z11[1]}, [x1(t),y1(t),z1(t)], numeric, output=Array([seq(k,k=0..N)]));
Error, (in dsolve/numeric) Array/array solutions cannot be obtained for ODE containing unassigned global variables {k1, k10, k11, k2, k3, k5, k6, k7, k9}
x11 := Vector([0.208408965651696e-3, -0.157194487523421e-2, -0.294739401402979e-2, 0.788206708183853e-2, 0.499394753201753e-2, 0.191468321959759e-3, 0.504980449104750e-2, 0.222150494088535e-2, 0.132091821964287e-2, 0.161118434883258e-2, -0.281236534046873e-2, -0.398055875132037e-2, -0.111753680372819e-1, 0.588868146012489e-2, -0.354191562612469e-2, 0.984082837373291e-3, -0.116041186868374e-1, 0.603027845850267e-3, -0.448778128168742e-2, -0.127561485214862e-1, -0.412027655195339e-2, 0.379387381798949e-2, -0.602550446997765e-2, -0.605986284736216e-2, -0.751396992404410e-2, 0.633613424008655e-2, -0.677581832613623e-2]):
y11 := Vector([ -21321.9719565717, 231.709204951251, 1527.92905167191, -32.8508507060675, 54.9408176234139, -99.4222178124229, -675.771433486265, 42.0838668074923, -12559.3183308951, 5.21412214166344*10^5, 1110.50031772203, 3.67149699000155, -108.543878970269, -8.48861069398811, -521.810552387313, 26.4792411876883, -8.32240296737599, -1085.40982521906, -44.1390030597906, -203.891397612798, -56.3746416571417, -218.205643256096, -178.991498697065, -42.2468018350386, .328546922634921, -1883.18308996621, 111.747881085748]):
z11 := Vector([ 1549.88755331800, -329.861725802688, 8.54200301129155, -283.381775745327, -54.5469129127573, 1875.94875597129, -16.2230517860850, 6084.82381954832, 1146.15489803104, -456.460512914647, 104.533252701641, 16.3998365630734, 11.5710907832054, -175.370276462696, 33.8045539958636, 2029.50029336951, 1387.92643570857, 9.54717543291120, -1999.09590358328, 29.7628085078953, 2.58210333216737*10^6, 57.7969622731082, -6.42551196941394, -8549.23677077892, -49.0081775323244, -72.5156360537114, 183.539911458475]):
a1 := Diff(x1(t),t) = k1*x1(t)+ k2*y1(t)+ k3*z1(t) + k4*u(t);
b1 := Diff(y1(t),t) = k5*x1(t)+ k6*y1(t)+ k7*z1(t) + k8*u(t);
c1 := Diff(z1(t),t) = k9*x1(t)+ k10*y1(t)+ k11*z1(t) + k12*u(t);
ICS:=x1(0)=x11[1],y1(0)=y11[1],z1(0)=z11[1];
SOLN := dsolve( { a1,b1,c1, ICS }, {x1(t),y1(t),z1(t)} );
EQ1790 := subs(t= 0, SOLN );
EQ1800 := subs(t=10, SOLN );
PARAMETERS := solve( { EQ1790, EQ1800 }, { k1,k2,k3,k4,k5,k6,k7,k8,k9,k10,k11,k12 } );
d1 := Diff(u(t), t) = 0;
solL:=dsolve({a1,b1,c1,d1,ICS}, numeric, method=rkf45, parameters=[k1,k2,k3,k4,k5,k6,k7,k8,k9,k10,k11,k12]);
ans:=proc(p1,p2,p3) solL(parameters=[a1=p1,b1=p2,c1=p3]); end proc:
FitParams:=Statistics:-NonlinearFit(ans, x11, y11, z11, x1, y1, z1);
Error, (in Statistics:-NonlinearFit) unexpected parameters: Vector(27, {(1) = 1549.88755331800, (2) = -329.861725802688, (3) = 8.54200301129155, (4) = -283.381775745327, (5) = -54.5469129127573, (6) = 1875.94875597129, (7) = -16.2230517860850, (8) = 6084.82381954832, (9) = 1146.15489803104, (10) = -456.460512914647, (11) = 104.533252701641, (12) = 16.3998365630734, (13) = 11.5710907832054, (14) = -175.370276462696, (15) = 33.8045539958636, (16) = 2029.50029336951, (17) = 1387.92643570857, (18) = 9.54717543291120, (19) = -1999.09590358328, (20) = 29.7628085078953, (21) = 2582103.332, (22) = 57.7969622731082, (23) = -6.42551196941394, (24) = -...
So I am working on doing some trajectory simulations in Maple using standard Newton's Laws, some force expressions, and initial conditions.
Anyway, the numerical solution works fine if I let the initial conditions I specified (for z=-1) be actually for z=-0.9. To illustrate, when I give an initial condition like this:
x(-1) = x_0, D(x)(-1) = xd_0, Vz(-1) = v_0
the results don't make any sense. However, when using the same x_0, xd_0, and v_0 and I give initial conditions like this:
x(-.9) = x_0, D(x)(-.9) = xd_0, Vz(-0.9) = v_0,
the solutions at least make a bit of sense.
What's weird is that, when I let z -> 0.93 or so, the solution changes discontinuously. And this shouldn't happen. The initial conditions were calculated for and should work for z = -1. I don't understand why they aren't.
Here is my Maple document. ics1 are the problem.
dsolve_field_traject.mw
Do you guys have any idea what could be going on?
One can do igcd(12,8), and igcd(16,3), etc...
But how to define a list/set/array/vector/matrix, etc... that contains these pair of numbers, and then call/map igcd on this list?
I tried putting the pair of values in a list and set and even a matrix, calling calling map(igcd, lst) but not getting it right.
The confusing part for me with Maple is to know which data structure to use for each function, since there are more than one. Here are my silly attempts:
lst:={{12,8},{16,3}};
map(igcd,lst);
lst:=<<12|8>,<16|3>>;
map(igcd,lst);
lst:=[{12,8},{16,3}];
map(igcd,lst);
I was looking for something like in Mathematica:
lst = {{12, 8}, {16, 3}};
GCD @@ lst
    {4, 1}
I am sure it is possible to do this in Maple (i.e. map igcd to list of pair of numbers), I just can't get the syntax right. I did look at few examples somewhat related, but did not understand what they are doing. They said I need to pass an extra argument for map in this case?
thank you
Sorry for a basic question, but I am not able to find a setting for this, and I am stil newbie in using Maple UI.
A simple problem. When I copy some Maple code from the net, such as a proc() posted here or else where, then paste the code right into my open worksheet, then each line will show up with ">" at the left.
Is there a way to remove these ">" other than the way I do it now, which is manual process.
Having a ">" at start of each line does not seem to affect anything. The proc() gets defined fine, and I can call it. But normally when I write a proc(), there is no ">" to the left of each line, since those come only when hitting a RETURN. And that is what confuses me.
But what I am looking for, is a way to select some lines, and tell Maple to remove all the ">". Here is a screen shot of some code I just pasted to the worksheet:
the question is as follow:
The partition does not always have to be equal intervals. Consider evaluating f(x)=x3 between 3 and 5, but splitting up the interval into a partition in which the end points of the subintervals are in a geometric progression. The common ratio r has to be chosen so that 3 is the first term and 5 is the last. Also the subintervals must be capable of getting smaller as n the number of subintervals increases. Check that the geometric series
a, ar, ar2, ar3,.....ari, .....arn =b
with r=  and suitable choices for a and b satisfies these criteria. Treating the difference between ari and ar(i-1) as the width of the subinterval and using the right hand endpoint of the subinterval, evaluate the Riemann sum to n terms for f(x)=x3. Find the limit as n tends to infinity to show that the partition does not affect the result.
here is what i have got so far, can anyone check if im doing it right? thanks
>a:=3:
>b:=a*r^10:
>r:=(5/3)^1/10:
>for i from 0 to 5 do a*r^i end do; -> a list of number appear in sequence ie:3, 3.157...,3.323...3.497...etc
>restart;
>a:=3:
>b:=a*r^100:
>r:=(5/3)^1/100:
>dxj:=a*r^i-a*r^i-1
>xj:=i*dxj+a
>f:=x->x^3
>evalf(sum(f(xj^*)dxj,i=1..100)) -> my value is sth like 162.4788870...
I tried to find the limit, but maple 16 freezed so i think i must have done sth seriously wrong?
<math xmlns='http://www.w3.org/1998/Math/MathML'><mrow><mi>b</mi><mo>&coloneq;</mo><mi>a</mi><mo>&sdot;</mo><msup><mi>r</mi><mrow><mn>10</mn></mrow></msup><mo>&#x3b;</mo><mo>&nbsp;</mo></mrow></math>
Is there any way to write a function that determines the area of any n-sided polygon determined by a sequence of points? ie [[x_1, y_1]. [x_2, y_2], ... [x_n, y_n]] while returning 0 if any of the 2 segments intersect, otherwise print the area. Thanks for any help
would you please help me how can i introduce a probability distribution function to maple in document mode?
I want to calculate integral of x f(x)dx, while I want maple to know f(x) is a probability distribution function.
I do not have any assumption about f(x)(for example normal or exponential distriburion)
Hello, everyone!
Last week I’ve encountered problems with integration of Maple 17 in Microsoft Office Excel 2013. The Maplesoft note on the point (http://www.maplesoft.com/support/faqs/detail.aspx?sid=32651) offers some ways of fixing it up, though I’ve run all of them the problem is the same:
While the connection is established, after entering the formula “=Maple(“x+x”)”, the Excel returns “Critical Error in Formula”
Before contacting the Maplesoft Technical Support, I want to ask here whether someone had the same case and managed to solve it.
Many thanks in advance.
First 1510 1511 1512 1513 1514 1515 1516 Last Page 1512 of 2429
