I have the following six equations that I need to solve:
eq1 := A^5*f6+A^4*f5+A^3*f4+A^2*f3+A*f2+f1 = ln(V1);
print(??); # input placeholder
eq2 := B^5*f6+B^4*f5+B^3*f4+B^2*f3+B*f2+f1 = ln(V2);
eq3 := 5*A^4*f6+4*A^3*f5+3*A^2*f4+2*A*f3+f2 = F1/V1;
eq4 := 5*B^4*f6+4*B^3*f5+3*B^2*f4+2*B*f3+f2 = F2/V2;
eq5 := 20*A^3*f6+12*A^2*f5+6*A*f4+2*f3 = G1/V1-[F1/V1]^2;
eq6 := 20*B^3*f6+12*B^2*f5+6*B*f4+2*f3 = G2/V2-[F2/V2]^2;
 where V1, V2, F1 & F2 have previously been found/defined in the worksheet (document).
When I use the solve command, more often than not I get the expression for the numerical calculation for each variable f1-f6, rather than an actual value:
solutionset := solve({eq1, eq2, eq3, eq4, eq5, eq6}, {f1, f2, f3, f4, f5, f6})
{f1 = 0.4096495220755576e-2*[-1.328181534188746]^2-0.3072371415566682e-1*[-9.408269235937702]^2+12.64287210303000, f2 = .3686845698680018*[-9.408269235937702]^2-49.98313436120349-0.6690942193900774e-1*[-1.328181534188746]^2, f3 = -1.423532089212563*[-9.408269235937702]^2+150.6490386090756+.3909877105143377*[-1.328181534188746]^2, f4 = -.9490213928083751*[-1.328181534188746]^2+1.954938552571689*[-9.408269235937702]^2-190.3706247009334, f5 = .8192990441511152*[-1.328181534188746]^2-1.115157032316796*[-9.408269235937702]^2+103.8844069311055, f6 = .2275830678197542*[-9.408269235937702]^2-20.57204700597870-.2275830678197542*[-1.328181534188746]^2}
Why is Maple not giving me the actual value for the variables, and how do I get it to do so, everytime? [In fact it did output the actual values once – but I have no idea what I did differently: it seems to be very random….]
i.e. how do I output the following:
solutionset := {f1 = 9.930572749191651, f2 = -17.46685689954139, f3 = 25.33406943774393, f4 = -19.00233912206421, f5 = 6.620988906086421, f6 = -.8288827301180226}
hi
is there any way that i run my maplet output in  systems that havnt any maple install on them?
(i wanna run maple program without maple)
Reza2961
Bonjour,
Comment se calcule avec maple le développement de laurent d'une fonction de deux variables ?
Maple n'autorise pas la commande laurent(1/x/y, [x=0,y=0]).
Merci d'avance.
Gérard.
Does N variables caylay table have N permutation group so that can generate N functions?
for exmaple 3 variables cayley table have 3 permutation group, for 1, it has a permutation group , for 2 has a permutation group etc.
then does it mean that it has 3 functions, do it need to composite 3 functions in order to get a function belong to this cayley table?
1 1 1
1 2 2
1 2 3
Compute integral In(X)/(X-A)(X-1)    0<x<∞ for positive a.
Compute the sum∑(k^2+k-1)/(k+2)!
                        k=1
How to plot the function f := x->sum(sin(x/(k+1))/k, k = 1 .. infinity) on the interval 0..50? The series obviously converges.
Is there a way of extracting the terms of an expression with a certain dependence?
For example:
If I have,
expression:=f(x)+g(y)+x^2+y^3+65
I need to have,
f(x)+x^2
g(y)+y^3
65
parts separately.
(Of course, a way other than taking derivative.)
How would I find the polar representation of, say, (x^2+y^2)^2=x^2-y^2 using maple? Thanks.
Hi! PLEASE HELP ME.. I try to give a new name in my proc where it stops at the initial condition, ic. Somehow it gave me an output like
>Orbit:=proc(Map,ic,Nit)
local orbit,z,t:
orbit:=array(0..Nit);
z:=ic:
orbit[0]:=z;
for t to Nit (while z<>ic) ot t=1 do
orbit[t]:=z;
z:=Map(z):
orbit[t]:=z:od;
return[seq(orbit[t],t=0..Nit)];
end;
>Orbit (F,[1,0],20);
##I want to eliminate the orbit13 and so on. I tried to give a new name where for example per:=array(0..t). I want it stops at t and do not go until Nit. Can you help me?
Hello, everyone!
Last day I’ve discovered a strange behavior of the “optimization” tool:
Mostly it copes with the task – but there are cases (the data are the same) when the tool doesn’t return the opt. value: instead it returns the parameter name.
BUT if some of the previous calculations are re-evaluated (and the same input values are received) the “optimization” tools works quite well.
The question is: how to tackle the problem?
P.S. The way to force re-evaluation of previous functions in the body of this procedure (if the optimization failed) doesn’t help: it returns the optimizing parameter name once more.
Windows 8 (64-bit)
Maple 17.00
I have
a(t):= (0.4292960410)*(t^3+20.0*t^2+105.0*t+138.0)^5/((t+1.881246817-0.5978370144*I)*(t+2.472494183-0.1946676251*I)*(t+5.550661347)*(t+5.496908401)*(t+12.46933729)*(t+12.44618893-0.9642646277e-2*I)*(t+0.5725282710)*(t+5.589440415)*(t+12.49222265)*(t+12.44618893)*(t+12.46933729)*(t+5.496908401)*(t+5.550661347)*(t+2.472494183+0.1946676251*I)*(t+1.881246817+0.5978370144*I))
b(t)=(1.8*t^2+34.1*t+138.)/(t^3+20.*t^2+105.*t+138.)
F(t):={0.5738910678*a(t)*[1-b(t)]}/t*0.5137681159
I have expanded F(t) in series form using taylor series expansion formula in terms of t.
My question is
                           Can it be expanded in series form in terms of b(t).
I have 2 questions about the resolution of a ODE for the simple pendulum equations.
1) I need to add 'maxfun'=10^7 in the dsolve function. With this option, dsolve works. Can you explain me in a very simple way the principle of this option ? It's just to feel better how this option runs.
2) gamma(t) is a angular parameter.
With
tgammax:=odeplot(sol,[gamma(t),x(t)],0..10,numpoints=200,color=blue,legend="z"):
display(tgammax);
I manage to plot x(gamma) but with gamma in rad.
How can i do to x(gamma) but with gamma in degree? I should do gamma_deg=360/(2*Pi)*gamma(t) but as gamma(t) is defined numerically, this lign doesn't work.
Thank you for helpe
Here some ligns of my code :
Cinit:=D(psi)(0)=0,psi(0)=-0.93,D(x)(0)=0,x(0)=1.13,D(gamma)(0)=0,gamma(0)=0.79;sol:=dsolve({sys,Cinit},numeric,'maxfun'=10^7);
tx:=odeplot(sol,[t,x(t)],0..10,numpoints=200,color=blue,legend="x"):
display(tx);
tgamma:=odeplot(sol,[t,gamma(t)],0..10,numpoints=200,color=blue,legend="gamma"):
display(tgamma);
display(tgammax);
I am on windows 7, 64 bit, using Maple 17.02. When opening the command line Maple, and typing:
But on the GUI, it works:
?index,packages;
and I get a new window open with the list of package.
In the command line, it works if I use ?index,package;  i.e. without the extra `s` at the end.
On a side question, I was looking at a Maple book, where it said to use ?index[packages];  but this no longer works, even in the GUI, and had to use ?index,packages;  syntax. I wonder when this change happens. The book is old, using Maple 7.
Hi, I am trying to plot these two curves:
I tried:
with(plots);  A := Array(1..2)  A[1] :=plot (0.199563349672261+0.0178636902277546 x^1.14406289706794-0.0182070811144750 x^(1.13867380551454),x=50..2050,  color=red);  A[2]  := plot(0.298910542599302+0.0117459591500434 x^1.00390277106937-0.0137065176395662 x^0.970667551759677, x = 50..2050, color = blue);  display (A);
and I got:
Error, (in plot) unexpected option: .298910542599302+0.117459591500434e-1*x^1.00390277106937-0.137065176395662e-1*x^.970667551759677
so I tried
so I am not sure how I would graph these two functions...
I am coming back to maple after being years out of it (Maple 9). I am writing a paper in class of how to use Maple with Algebra. I would like to create a document so that students can manipulate the graph of a(x-h)^2+k and se how parameters a, h and k effect the function.  However, I can't seem to figure out how to create a slider linked with each parameter so students can manipulate it.
Is this possible? Any help wold be great!
Nicholas
First 1512 1513 1514 1515 1516 1517 1518 Last Page 1514 of 2429
