@Carl Love  Thanks for your reply. Composition breaks down into  distinct ordered  k-tuples . Partition breaks down into all possible sums with no regard to order.
Example: composition (4, 2)    {[1,3], [2,2], [3, 1]}   allstructs (Partition (4) ,size = 2)     [ [1, 3], [2,2]]
For the allstructs ( Partition (n...
Find all prime numbers from 500 to 600.
Good afternoon
I request you to help me out to input a column vector matrix of dimension 80x1 whose entries are 0.
would like to use point graph and line graph to show the graph
test1r3 := (1/2)*(-x+sqrt(x^2-4*y^2))/y;
n := 100;
for j from 1 to n do
aa[j] := subs(y=RandomTools[Generate](integer(range = 1 .. 10)),subs(x=RandomTools[Generate](integer(range = 1 .. 10)),test1r3));
od;
plot(<seq(1 .. n)>,<seq(aa[i], i = 1 .. n)>, style = point);
How do i "show region ranges" on mac. on windows you just press F9 but you cant on mac??
Find \lim_{n \to \infty}(\frac{1}{n+1}+\frac{1}{n+2}+\frac{1}{n+3}+\dots+\frac{1}{n+n})
A travel agency is planning a one-week trip to Italy that has an initial cost of $2,000 plus $1,140 per person. At a price of $1,400, 13 people will sign up. Past experience suggests that for each $20 decrease in the price, an additional person will sign up. Also, for each $20 increase in the price, one less person will sign up. What price (in intervals of $20) will maximize the profit? (Make a table and guess and check.)
I don't get how to solve this problem...
Find \lim_{n\to\infty}{\frac{\sqrt[n]{n!}}{n}}
In a pocket, we have 5 balls number from 1 to
Hello all,
I want to plot shapes, like circles, lines or elipses, and to shade some areas, for example, let's say I have an inequality, indicating a domain of all points above a line, or inside a circle, outside an elipse, and I want, for demonstaration for studetns, to shade with dashed lines or color these areas, how do I do that ?
Thanks !
I am using the ExportMatrix command to save matrices to .txt files. Is there a way to use a variable to automatically create the text file name?
For example (I know this doesn't work):
In maple 17,
solve({b-a*sqrt(1+a^2+b^2)=a^2*(a*b-sqrt(1+a^2+b^2)), a-b*sqrt(1+a^2+b^2)=b^2*(a*b-sqrt(1+a^2+b^2))});
outputs
a=a , b = -a/(1+a)
If you set a =1  and b = -1/2 you will see this is not a correct solution.
Good afternoon sir,
I am M.Anand working for SRIIT, as Assistant Professor in Mathematics.
I request you to provide me the correct Maple commands to generate large matrices whose elements are defined in terms of i & j in piecewise function pattern for example
How to generate the matrix A where the elements a(i,j) are defined as
a(i,j)=2i    when j=i   and i=1,2,...,80
a(i,j)=0.5i  when j=i+2 and i=1,2,...,78...
Maple_-_Upload.mw
See the upload for my worksheet.
When opened: Combine the first picture with the second picture and you will get the third picture, where the green filled box is a 'safe zone'. Now what I want is to find the intersection between the green line (=0.7) and the red line (the curve), which gave me two answers, as I wanted! No problem at all.
Now when the fourth picture is combined with the fifth picture this results in the sixth picture. So again I tried to find the intersection between the two lines (this time the green line with the blue line; I just name it to be sure that the idea is clear). But this time Maple doesn't give me the points of intersections. How come? I think it has something to do with the procedures, but I can't figure out what it exactly is.
I hope someone can help me out on this.
Frank
Find all prime numbers from 1 to 300.
First 1541 1542 1543 1544 1545 1546 1547 Last Page 1543 of 2429
