Hi, Everybody:
It is possible to fin this result with Maple:
Factor[18*R*r - 3*s^2 + 9*r^2] - >  3*(3*r^2 + 6*r*R - s^2)
i.e. factoring at least integers terms?
C.L.
I need to model universal joint and spherical joint with spring elements.
Contrary to the revolute joint where there is an option to put spring element, i don't find this option in the universal joint and the spherical joint. So is there a simple solution to model spring in this kind of joint.
I hope that i shouln't have to build the joint with several revolute joint in serial.
Thank you for your help.
next_fib.mw
I want to find the next fib number in the sequence given an input number.
I know there are previous posts using a recurance formula...i don't want to do that.
I want my code to work like the nextprime command. but i have problems..
If the number i/p is not a fib no. .....error.  it needs to find the next actual fib no.
there is also the problem that because the...
silver_coin_braintea.mw
Experts. This is something like the subset sum problem with a twist.
Jane has some Australian silver coins in her pocket. When buying an apple, she
realises she has more than $1 in silver coins, but can’t make exactly $1 with
her coins. How is this possible? (Silver Australian coins come in 5c, 10c, 20c,
and 50c.)
answer: obviously, you can't...
Hello folks,
simplify(max(x[1],y[1])) assuming x[1]>y[1] produces thr correct result but if we do f:=k->max(x[k],y[k]);
and try simplify(f(1)) assuming x[1]>y[1] we do not get any result.
I suspect that is something related to global versus local variables, any ideas?
I have a little question concerning the definition of the rotation matrix in the rigid body frame.
The rotation matrix is defined like that in the help menu : "The rotation matrix that transforms a vector expressed in the outboard frame to the inboard frame".
Consequently, we have :
I would like to define my model with symbolic parameters. Consequently, i have to define the symbolic parameters and theirs values in main folder.
To illustrate, i define my parameters a1, a2 like this.
After, i need to define a frame by using the parameter a1. This frame is define like this :
Solve the system of equations:
\begin{cases} x+y+z=6\\x^2+y^2+z^2=14\\x^3+y^3+z^3=36\end{cases} ,
Find
Good afternoon Professor.
I am M.Anand working for SRIIT, as Assistant Professor in Mathematics in Hyderabad, INDIA.
Is there any direct approach like Jacobi,Gauss-seidel, & SOR methods in Maple to solve a given linear system of equations by using Conjugate gradient method & Preconditioned Conjugate method.
I request you to help me out to generate Maple commands to solve.
If x_{1},x_{2},x_{3}>0 are the roots of the equations ax^3+bx^2+cx+d=0.
Prove that min
When executing "P, k := LyapunovSolve(A, C)" command, I got the following warning:
"Warning, Matrices have common or very close eigenvalues; perturbed values were used to solve the equation"
Although Maple can give the solution, P and k don't satisfy the equation:
A.P+P.A^%T-C = 0        (1)
Are there any other ways to solve the Lyapunov equation (1)?
Using ScientificConstants[GetElement] I'm supposed to get all the element constants, but I don't see the molar mass and have trouble believing that it isn't defined.
Question how do I get the molar mass of an element?
Hi everyone. Someone should pls. teach me how to plot a graph in maple. i've never done this before and I hope what I'm about to do is very much feasible. I don't have a function to plot, I'm plotting the errors from my computation against time(t) at interval 0 t 1. Someone shoukd pls. explain this for me with random values or use the sample values below .
  time           error1         error2
Good morning Professor.
I request you to help me out to create an Augmented Matrix of a given system of linear equations with more number of variables.
With thanks & regards.
M.Anand
Assistant professor in Mathematics
SR International Institute of Technology
Hyderabad, Andhra Pradesh, INDIA.
First 1539 1540 1541 1542 1543 1544 1545 Last Page 1541 of 2429
