I work with Maple as professional and I want to buy one tablet for convenient . Is there Maple for Tablet? which operating system? Android, ios or windows 8 tablet?  which one is better?
If I have spreadsheet data, x and y (velocity and time), I need to find distance.  I see numbers of ways to do this, however, I wonder what people would suggest as the fastest / easiest way.  I'm not needing a function really, just results.  Does Maple have tools to simplyify this process, and if not, what process(s) might yield results of determinable or selectable accuracy.  I will have many sets of data in the future that need to be manipulated...
How can I draw following piecewise closed function t in  3-dimensional cartesian space
D124:=max(-x+y+z,x-y+z,x+y-z)=1;
D134:=max(-x+y+z,x-y+z,-x-y-z)=1;
D123:=max(-x+y+z,x+y-z,-x-y-z)=1;
D234:=max(x+y-z,x-y+z,-x-y-z)=1;
t:=piecewise(x>0 and y>0 and z>0,D124,x<0 and y<0 and z>0,D134,x<0 and y>0 and z<0,D123,x>0 and y<0 and z<0,D234);
Is it possible to install a 64-bit edition of Maple 17 linux version into a Windows 8 machine throughout the Cygwin64 interface?
When defining a polynomial as follows
p:=x->x^(r+1)-(r+1)*Sum((-1)^(r+k)*(r+k)!*(r+1)!*r!/((k!)^2*(r-k+1)!*(2*r+1)!)*x^k,k=0..r);
the result of
simplify((eval(p(1),r=1)));
is given as 1 whereas hand evaluation and also plotting the polynomial clearly shows that the result is 0. How can this behaviour be explained?
How do I get ride of these Rootof?
I tried simplify,evala,value,Simplify and ect. Didnt really find anything useful.
Download rootof.mw
I dont care which root they actually take, all I want is one of the roots. So I can then use subs for substitution.
Casper
How can I draw following piecewise closed function in  3-dimensional cartesian space
         max(-x + y + z, x - y + z, x + y - z) = 1 ,  0 < x and 0 < y and 0 < z
         max(-x - y - z, -x + y + z, x - y + z...
Another (hopefully) simple question that I can't work out the answer for. How can I write an if loop for which n things must be true? I need to have:
if thing[1]=true and thing[2]=true and thing[3]=true and ... and thing[n]= true then
fi;
n will change for different inputs, so I can't write out explicitly.
Hope that makes sense! Thanks.
Good day.
Reading the documentation on Physics package in Maple, I did not find information about how Maple handle dummy indices of tensorial expressions. For example, suppose I have the following tensorial expression in Maple:
    A[mu] * B[~mu]
with dummy index mu. Then I want to apply the following simple substitution rule:
    A[alpha] = C[alpha]*C[mu]*C[~mu]
Here, free index alpha should be...
I would like to plot the following expression that I call W
>W:=tau*exp(C4)/C1-exp(C4)*(exp(C3-C3*eta)/C3^2-exp(C3)/C3^2+tau/C1+eta/C3)+exp(C4-C3*eta/2)*Sum(16*beta[m]*sin(beta[m]*eta/2)*exp(-(beta[m]*beta[m]+C3^2)*tau/(4*C1))/((beta[m]*beta[m]+C3^2)*( beta[m]*beta[m]-C3^2)^2),m=1..n)
Where C1, C3, C4 are constant, and  beta[m]satisfies the relationship
C3*sin (beta/2) =beta*cos (beta/2)
I want to plot the W-eta curve and W-tau curve (eta at [0, 1...
Dear sir i  want the contour values  automatically display on the contour.
Hear is the code and sample contour plot.
contourplot(x^5-y^3,x=-5..5,y=-4..3,axes=boxed,contours=10);
What else could I try if I encounter this error?
Warning:  Incomplete separation.
I read the pdsolve help page, where it says I should have a solution with this warning, but I got nothing but the error.
Dear Maple users
I am working on a problem, which basicly is dealing with putting n identical marbles in k different boxes. I need to run through all possible combinations and do something with it. The latter is unimportant. Mathematics say there are binomial(n+k-1,k-1) different combinations. I have already produced a recursive procedure to solve the problem and it is displayed below. I have placed a counter in the procedure to control if the procedures get through...
I would like to assign a value I got from using the command 'Maximize'. What I gained as an answer is of the following form:
test:=[1234124, [t=124124124]]
Now my point is to assign both these values to variables, which I can do for the first like:
first:= test[1];
But I just can't find out how to assign the second value.
I was trying it out by using the command 'rhs' but that doesn't work (although, not for me).
Probably a silly question, but yeah..thanks for a reply.
Frank
I'm trying to substitute a combination of variables in an equation that is partly covered in a summation.
For example consider the equation with two variables A and B, and two function W(t) and q(z):
eq1:=A*B*(sum(W[n](t)*q[n](z), n))
now I want to do the substitution:
First 1555 1556 1557 1558 1559 1560 1561 Last Page 1557 of 2430
