i had 3 nonlinear equations and i want to convert them to the form of multiplications of a MATRIX in a VECTOR, but none of these two methods give me the right answer,what should i do?
#method one#
eq1:=a[1]+a[2]*a[3]^2*a[1]+a[2]*a[3]-a[1]^2:
eq2:=a[3]+a[1]^3+a[2]*a[3]+a[2]^2-a[1]^2:
eq3:=a[1]^3+a[2]^3+a[1]*a[2]*a[3]+a[1]*a[2]-a[3]:
for i to 3 do
B || i := eq || i ; K || i := Vector[row](3):
for j to 3 do
I found the plotted phase portrait strange and i verified it with phaseportrait
With plot :
Dear guys!
I have two expressions in terms of one variable. For example A(t) and B(t). Now, I want to plot A in terms of B. What should I do?
I cannot obtain this relation analytically because both expressions in terms of "t" are very complicated. But I can plot both of them. Now, I need to plot A in terms of B.
Thanks a lot.
hey friends am stuck with some code. My code is correct and am trying to find exact solution but not able to see output. Please kindly check it and let me know exact_solution.mw
> test1r := dsolve((Diff(f(x,y), t, t))*x+(Diff(f(x,y), t))*y = 0, f);
Error, (in dsolve) expected an ordinary differential equation. Received: 0 = 0
another question is
i do not know whether can
 dsolve((Diff(f(x,y), (x,y), (x,y)))*x+(Diff(f(x,y), (x,y)))*y = 0, f);
I want to report a strange behaviour when working with bras and kets from the physics package. Working in a discrete basis, Ket(Phi,m) and Ket(Phi,n) should be orthogonal as long as m neq n. At least this is said so in the Physics-Example document.
However when I enter Bra(Phi,0).Ket(Phi,4) Maple returns 1! Just with 4 - all other integer values n > 1 give zero, as it should be! Maybe I am completely misunderstanding something here or this result is...
hello maple support,what is the best way to solve for multiple numbers, ie the equation isx/x+1 i can plot it but i want to solve for .5.9.99.999 and 1.5,1.1,1.01 and 1.001.i have tried a number of ways and browsed tutorials on you tube and some pdfs.it is time for help on solving for multiple quantities.thanks,craig
I consider a PDE system (?pdsolve,numeric)
PDE := {diff(u(x,t),t)=-1/20*diff(v(x,t),x,x),
diff(v(x,t),t)=diff(u(x,t),x,x)}:
IBC := {u(x,0)=sin(Pi*x), u(0,t)=0, u(1,t)=0,
v(x,0)=1-x, v(0,t)=1, v(1,t)=0}:
pds := pdsolve(PDE, IBC, numeric, spacestep=1/50);
Suppose, I need to use the data diff(u(x,t),x,x)  or diff(v(x,t),x,x) at x=0.
Hi, i wouls lij=ke to see the consequences of damping on coupled oscillators.
I encounter no problem with
restart; m := 1; k1 := 1; k2 := 1; lambda := 0;
eq1 := m*diff(x1(t), `$`(t, 2)) = -k1*x1(t)+k2*(x2(t)-x1(t))-lambda*diff(x1(t), t);
eq2 := m*diff(x2(t), `$`(t, 2)) = -k2*(x2(t)-x1(t)); ICS := x1(0) = 1, x2(0) = 0, (D(x1))(0) = 0, (D(x2))(0) = 0; sol2 := dsolve({ICS, eq1, eq2}, {x1(t), x2(t)});
plot(eval(x2(t), sol2), t = 0 .. 20);
Really, can't understand why there's a problem in the line desolve
eq1 := m*(diff(x1(t), t, t))-f = 0;
f := -k*x1(t)+k*(x2(t)-x1(t))-lambda*(diff(x1(t), t)) ;
g := -k*(x2(t)-x1(t)); eq2 := m*(diff(x2(t), t, t))-g = 0;
fcns := {x1(t), x2(t)};
ICS := {x1(0) = 1, x2(0) = 0, D(x1)(0) = 0, D(x2)(0) = 0};
sys := {eq1, eq2}; m := 1; k := 1; lambda := 1; sysdiff := sys union ICS;
hi dear
i am a student of m.phil in maths.
i am doing my research in numerical solution of fractional derivatives but
i am facing a little problem in writing the code for fractional derivatives by hpm
in mathematica software if you are having any code kindly sent it to me
1st, sorry, i did'nt find the "question" forum so i post here
2nd, difficulties in converting the maple code in text here
3rd : my problem of the day
retart :eq1 := m*(diff(x1(t), t, t))-f = 0; f := -k*x1(t)+k2*(x2(t)-x1(t))-lambda*(diff(x1(t), t));
eq2 := m*(diff(x1(t), t, t))-g = 0; g := -k2*(x2(t)-x1(t)); fcns := x1(t), x2(t);
ICS := {x1(0) = 1, x2(0) = 0, (D(x1))(0) = 0, (D(x2))(0) = 0};
sys := {eq1, eq2};...
I want to print     an   is  in  S .
Here are what I tried.
So here is what I need to do within Maple.  I have to define a piecewise function and then determine left and right hand derivatives at a certain x value.  Then determine the whole derivative and graph both parts.  I am just pretty new to Maple so it is still fairly confusing and I cannot determine the exact commands that I need.
hi,look at that. I obtain a curve. But when i do it again
First 1570 1571 1572 1573 1574 1575 1576 Last Page 1572 of 2430
