How to use maple to compute the intersection of two permutation group
I have a matlab file and i want to use this one in Maple.
Is there a way to convert a m.file to a maple file?
The matlab code is this:
%Parameter values
lambda=0.00755834; %Sheath loss factor
Re = 26.5 %Outer cable radius [mm]
Delta = 5.9E-7 %Thermal diffusivity of soil[m^2/s]
alfa = 0.00403 %Temp coefficient of conductor material [K^-1]
R20 = 0.321 %AC resistivity of conductor material at 20 °C [Ohm/m]
RHOs = 0.8 %Thermal resistivity of soil [Km/W]
Hi every body
I want to solve a differential equation y'(t) = sqrt((f-1)/(t^f-t)) and get an answer in terms of ordinary function.is it possible. thanks
Hi there,
In the attached PDF I have a system of 16 equations with 16 unknowns (the unknowns are a_i, b_i, c_i, d_i for all i = 1..4). The x_{ijkl} represent known (arbitrary) values.
Can someone solve this system and tell me what the solutions are? If there is more than one solution, then I only want one solution.
Qn.pdf
hello, i'm using maple, in order to draw a graphic in wich, different functions are plotted,
these functions came from one with 4 variables, wich represents losses in a phenomenon (extraction) depending on diffenrent variables, so my objective is to varry only one parameter and then draw its curve, and this for each parameter ; i had 4 functions.
f1:=plot((n-1)/(-1+n*10^(6.77*((n-1)/n))), n=1.0537..1.2688):
f2:=plot(0.2365/(-1+1.2365*10^(0.0155*O)), O=76.42..99.92):...
I want to create a package.  I want to be able to load it using the usual with(Accellib); construct.
how can i do it?
hi,
how can i solve the following ode
u'' + 3.4/ (u(0.25)*2+u(0.16)+2) + uu'=0
boundary conditions   u(0)=a  , u(0.5)=b
a and b are constants. for example a=0.1 and b=1
hi
please help me to solve the following system of ODE
diff(u(eta), eta, eta)+.5699919300/(0.9930000000e-3+0.3883623000e-1*phi(eta)+.5301627000*phi(eta)^2)+1/(eta-1)+(0.3883623000e-1+1.060325400*phi(eta))*(diff(phi(eta), eta))*(diff(u(eta), eta))/(0.9930000000e-3+0.3883623000e-1*phi(eta)+.5301627000*phi(eta)^2) = 0;
diff(T(eta), eta, eta)+(5.05659*((-1.1752324*10^6*phi(eta)+4.1744724*10^6)*u(eta)/(int((1-eta)*(-1.1752324*10^6*phi(eta)+4.1744724*10^6)*u(eta), eta = 0 .. .5))+7.47*(diff(phi(eta), eta))/(1+7.47*phi[0])-(.1977617327*(.597+4.45959*phi(eta)))*(diff(T(eta), eta))/(1-eta)))/(.597+4.45959*phi(eta))=0;
diff(phi(eta), eta)-5.000000000*phi(eta)*(diff(T(eta), eta)) = 0;
with following boundary condition
u(0)=0,u(0.5)=0,phi(0)=1,T(0)=0,D(T)(0)=0
thanks for your attention in advance
hey firends please help me for the following matrix code in maple for m x m order and for m x 1 order
I want to check this inequality (check below) for the set of parameters that holds, and I also want to restrict my variable to be real and non-negative (i.e k>=0), I am getting the usual message that "Solutions may have being lost". Can somebody please help me on how i can handle this ? Thanks
alpha*beta*(1-alpha)*k^(alpha-1)/(1+beta)-1-(2*alpha-1)*alpha*(1-alpha)*beta*k^(2*(alpha-1))/(1+beta)+alpha^2*k^(alpha-1)
I obtain  curve pH = f(Vb) with following code
restart;with(plots);
 Vtot := V0+Vb+Vind;h := 10^(-ph);C0 := 10^(-2);Cind := .83;Vind := 0.1e-1;V0 := 10;Ka1 := 10^(-4.8);Ka2 := 10^(-9);Cb := 0.1e-1;Kaind := 10^(-8);
eq := h+Cb*Vb/Vtot = 10^(-14)/h+C0*V0/(Vtot*(1+h/Ka1))+Cind*Vind/(Vtot*(1+h/Kaind));
 implicitplot(eq, Vb = 0 .. 40, gridrefine = 3, ph...
I installed Maple 17 on Slackware Linux 14.0 today and everything seems to work except that when I want to search for something through Maple Help my mouse doesn't seem to activate the text search field. Is this happening with anyone else or is this just because I am running under Slackware?
Jovan
hi
I have some equations like these:
I obtain  curve pH = f(Vb) with following code but now, i would have tangent for two points near Veq. I don't know the procedure with implicitplot.
I think the best way is to attribute the points to a function but dn't know how to do
eq := h+Cb*Vb/Vtot = 10^(-14...
i have 6 non linear diff equation. for the quad copter i want to get its state space representation and its done in a master  but they didnot say how they did it ???
soo any one can help me?
First 1569 1570 1571 1572 1573 1574 1575 Last Page 1571 of 2430
