I am reading a book "The Foundatiosn of  Celestial Mechanics" available to download here http://ads.harvard.edu/books/1989fcm..book/  in pdf. There some excerise questions to do at the end of each chapter. I'm at the end of Ch 1! I haven't used the VectorCalculus side of Maple (16) and am rusty on the subject, (read as did 30 years ago)
How would i do this question?
with great interest and surprise I read the post
"Converting Half-Angle Trig Formulas to Radicals".
Isnt it possible to evaluate cos(arccos(13/14)/3) also
to an exact expression in radicals ?
I simply do not succeed with my humble knowledge of
the Maple commands/internal workings...
Would be great if someone finds a solution ( of an
unsolvable problem ??? ).
[Edit: Excess white space deleted.---Carl Love]
Good afternoon, to successfully complete my study on beam vibration i wrote a matlab code to produce all my calculations. This is the beginning of the ocde and shows the point were i get stuck:
prod2=5/2*  3200/4507*sin(pi*alp)*sin(pi*bet)/s*sin(pi*x)*pi^4*sin(pi*y)+19200/4507*sin(pi*alp)*sin(pi*bet)/s^5*sin(pi*x)*sin(pi*y)-6400/4507*sin(pi*alp)*sin(pi*bet)/s^3*sin(pi*x)*pi^2*sin(pi*y))*pi*exp(-5*(x^2-2*x*alp+alp^2-y^2+2*y*bet-bet^2)^(1/2))
heya,
i got a problem. I got a list "L" of 3d points [[x1,y1,z1],[x2,y2,z2],..[xi,yi,zi]](in maple), i can easily plot the with pointplot3d(L, axis=normal) but i would need to have them plotted in a contourplot (not the 3D one but the 2d) with contourlines at every full number (1,2,3..highest z value) (well i wont get higher z values then 20)
could you plz tell me how to do that ?
thanks michael
I am working on a program to calculate steady-state probability in a given Markov chain. My code is pasted as bellow:
CalculateSteadyStateProbability := proc (m::integer, r::integer, CV, ROU)
local P, solutions, pai, l, eqns;
P := CalculateMatrix(m, r, CV, ROU);    #here we calculate a (m+r)x(m+r) transition martix
eqns := {`$`('pai[i+1] = add(pai[j+1]*P[j+1, i+1], j = 0 .. m+r)', i = 0 .. m+r)
http://www.mapleprimes.com/questions/144384-Polynomials-Not-In-The-Correct-Indeterminates
above link's comment said eliminate will NOT generate a polynomial in all cases
make me think that eliminate in above link can not return correct one.
what is the correct way to convert groebner basis of kernel into kernel?
I've created som Maple-code to determine if for all entrances in a quadratic matrix, D, the inequality di,j <= di,k + dk,j is true.
I have a 12 vectors represented by magnitude and phase, written in two separate columns in an excel file. First column is the magnitude and the second one the phase. And I want to plot this vectors in a polarpolt..Any ideas?
Hey,
I have currently encountered a problem that I am not sure if is a mathematical problem or a problem with Maple itself. I want to find the eigenvalues and eigenvectors of the following matrix:
[[2.460*10^9*sin(theta)^2+8.970*10^6*cos(theta)^2, 0, 2.449*10^9*sin(theta)*cos(theta)], [0,8.450*10^6*sin(theta)^2+8.970*10^6*cos(theta)^2,0],[2.449*10^9*sin(theta)*cos(theta),8.970*10^6*sin(theta)^2+2.530*10^9*cos(theta)^2]]
Maple is able to conjure...
I am trying to create a vector like
Nr:=5:
p:=2*Vector[column]([$0..Nr])+ConstantVector[column](1,Nr+1);
this one works fine but when I want descending order, i.e,
p:=2*Vector[column]([$Nr..0])+ConstantVector[column](1,Nr+1);
it is not working. I would appreciate the suggestions.
Hi there,
I have
x[i]=sum(sin(theta[j](t)), j = 1 .. i-1)
assuming i is integer and  i>=1 can Maple help me to differentiate with respect to time t ( for example diff(x[i],t) ) so
Has anyone used this product
Maple IDE is the only Eclipse™ based efficient development toolkit to rapidly build standout applications for one of the most powerful Computer Algebra Systems.
http://www.digi-area.com/CasStudio/Maple/
Use RSA with the modulus n=119 and the exponent e=7, with the 95-character alphabet consisting of the printable ASCII characters to encrypt the word "Yes". Recall that the alphabet is given by
Alphabet:=cat(Select(IsPrintable,convert([seq(i,i=1..255)],bytes)));
so that Y=57, e=69, s=83. Give your encryption as a list of three numbers.
I have an excel file with 10 columns by 10008 rows, the first one represent the time and the others represents some measuremts. And I would like to plot the columns which represent the measurements versus the first column which represent the time in Maple.
Do you have any idea how I can do this?
I have been having difficulties getting the Maple Player to start on my laptop.  PIII 933 Mhz Win XP 752Mb RAM
Initially didn't work so I tried to uninstall (not an option in the program files list - needed to be run from the folder) at which point I came across JVM not detected.  So I had to download and install the latest Java.  At that point the uninstall process was okay.
I re-installed and still was unable to start the player. ...
First 1614 1615 1616 1617 1618 1619 1620 Last Page 1616 of 2430
