sometimes Maple gives me the result in strange form, for example:
(2.*I)*q*r
I is the complex number. why is there a dot behind 2 ? How can I simplify it to
2*I*q*r ?
Many thanks,Kyle
hello friends am working on 2d heat equation and i have writen maple code for it but its not running because my scheme is having fictitious points which are removed by using boundary conditions but in this code which i have written the line in bold is not using boundary conditions due to which my fictitious points are still in programe and its not working am attaching my worksheet
trytimg.mw
please let me know where am wrong thank you...
Why isn't android maple for open mw files? In the world peoples are using android mobile or android tablet. Maplesoft please build a software for maple and use it on android. It will moneymaker for maplesoft. Please build it. Thanks.
I try many ways to solve the below DAEs, for example stiff=true, method = rkf45_dae, method=rosenbrock..., but my DAEs can't be solved. In different ways, there are different errors, such as "Warning, cannot evaluate the solution past the initial point, problem may be complex, initially singular or improperly set up", ""
Would you please show me how to solve the below DAEs and plot their solutions?
I really appreciate your help.
I think I have quite simple problem, I can´t solve.
I have the following fraction:
-z/(x-z)
and want to show it this way:
z/(z-x)
Multiplying the first fraction with (-1)/(-1) doesn´t work as expected.
Is there anyway to prevent Maple from converting a log10 function to a ln function when it displays a result?
Bonjour,
Qui peut m'éxpliquer l'algorithme de division d'un polynôme P(X,Y) sur un polynôme Q(x,y) ?
Avec mes plus vifs remmerciements,
Raymond Gérard.
after union ideal I and J, how to remove the intersection of I and J in order to do primedecomposition?
G1 := [v*y-w*x, r*y-u*x, -v*u+w*r, u*y^2-v*x^2, u^2*y-v*r*x, u*w*y-v^2*x, u^3-v*r^2, u^2*w-v^2*r, -v^3+u*w^2, x^4-r, x^3*y-u, x*y^3-v, y^4-w, w*y^2*x^2-v^2];
TypeTools[AddType](`w`,typefunc(string, symbol));
L:= `if`(G1::`w`, [op], '[]')(G1);
it seems above code incorrect.
Dear friends,
I wonder how I would go about calculating the asymptotic expansion of
sum(5^j/j, j=1..m+1)?
The motivation for this calculation can be found here. The correct answer is
5/4 5^(m+1)/(m+1).
The classic asympt and the one from multiseries both fail on this one.
Marko Riedel
i need your kind sggestions for this. i wrote the function w:=(xi(t),eta(t),diff(xi(t),t),diff(eta(t),t))→value.
but i cannot get the output, it wrote error in argument name. here value means the expression of the function.
best regards
Hi, I've got  a worksheet to do for my homework. I answered the first question, and then an error message appeared in the part of the code written by the teacher. At the following part,
Normalisation and expectation values of the superposition state
Lets consider the normalisation of, say, the mixed state Psi represented by the superposition of 1st and 2nd levels at an arbitrary time t.
int(evalc(conjugate(Psi(1,x,t))*Psi(1,x,t)),x=-infinity..infinity);
If Z is N(0,1) find
a) P(0<=Z<=.87)
I understand how to get to 0-0/1<=Z-0/1<=.87-0/1
which ends up being OI(.87), but am not sure how to get this to calculate. Plus I ant use proper functions here becuase I dont have the pallette, but OI is an O with the I through it... Φ(.87) I beleive....
I dont know how to have Maple calculate ths to give me the correct normal distribution value.
I have a differential equation as follows:
x(t)^2+cos(x(t))+diff(x(t), t)+diff(x(t), t, t) = 100
x(0)=2, D(x)(0) = 3;
After using "dsolve" to solve this equation, the solution x(t) is obtained.
How can we obtain the following function?
g(k) = 0kx2(t)dt
How can we plot the function g(k...
hi,
i have one equation (like equ1) wich this equatioin is a function of x. i want to find x in such a way that the equ1 minimizes. unfortunetly the equ1 is large and when i want to use NLPsolve it takes several time. is there any quick method to find the minimum x?
thanks for your attention in advance
First 1622 1623 1624 1625 1626 1627 1628 Last Page 1624 of 2430
