I'm filling an array of functions like this:
below code is calculate basis of kernel and kernel
i guess basis of image is
remove(has, Ga, [r,u,v,w]); if this correct, i eliminate this, i can get the image
however it include variable 'a'
is it correct? if not, how to calculate?
my final goal is to make unexact sequence into exact sequence
Hello, I have a problem in plotting the vector field of dx/dt=sinx/sint
It shows me an error:
Error, (in DEtools/dfieldplot) unable to evaluate function `sin(x)` in evalhf
Dunno how to fix it
Here is my code:
DE := [diff(x(t), t) = sin(x)(t)/sin(t)];
with(DEtools):
DC:=[sin(x)/sin(t),.1]:
dfieldplot(DE, x(t), t = -2 .. 2, x = -1 .. 2, arrows = medium, title = 'Diff', color = DC);
I have an awfully complicated expression depending on three variables m1, m2, m3 and a lot of parameters. When I try to substitute m1, m2 and m3 by 0, 0 and 1 respectively, m1, m2 and m3 are effectively replaced but lots of (0)s and (1)s appear after some of the parameters (and even 0(0), 1(0), 1(1), 0(1)...)
What does this mean and how to avoid it? Following is an example of the problem.
Instruction:
I am trying to do a phase plot of an autonomous system using DEplot command. However, no phase plot appears. Could you tell me what am I doing wrong? The same code worked for my professor in class, but it's not working for me. I am using Maple 16. The code is posted below.
> with DEtools
> sys := diff(x(t), t) = y(t), diff(y(t), t) = x(t)*(1-x(t)*x(t))+y(t);
> DEplot([sys], [x(t), y(t)], t = 0 .. 0.1e-8, x = -3 .. 3, y = -3 .. 3, color = black)
am trying to solve this code by changing boundary conditions but all the time it gives error that some points are not included i dont know what the reason is or may be my boundary conditions are not utilized please check it am attaching my file trytimg.mw
evalf(RoofOf(Z^6-3*Z^4+3*Z^2+Z-1,index=real[2]) fails to deliver a numerical value.
  1. I can use fsolve to compute the real roots but I need to replace all the occurences of RootOf by its numerical value in lengthy expressions.
  2. Also simplify(RoofOf(Z^6-3*Z^4+3*Z^2+Z-1,index=real[2],RootOf) does not work.
  3. I read the other posts related but could not find any answer.
Thanks for any help,
S.
  Hey,
 I am using maple to do some numerics (bound to use it instead of mathematica because of university guidelines) and my problem is that as the plotting options of maple are a bit unsatisfactory I need to export my data. This has worked fine so far using the writedata-command while I was working on normal (10 digit) precision. Now however I need to increase the precision and to my dismay writedata just cuts everything after the normal 10 digits away and...
Hi again!
Just a simple question...
Is it possible to i remove runits with a command? i know that i can right click on a value with units, and choose remove unit.
But it would be better if i could use a command like simplify
Hi I know this is a simple question but i have completely forgotten how to do it: I have the following equation,
h := ((A-B)^2*(A-4-B^2+4*B)*(A-4-B^2-4*B)-Q^2*(A-4-B^2+4*B))/(Q^2*(A-4-B^2-4*B))-1
how can I find what B is equal to?
hi friends am using maple 13 which is unable to find exact solutions for pdes
because for exact solution i should have maple 15 but am not able to install that so please can anyone of u can find exact sloution for me of the pde
pde := diff(U(x, y), x, x)-3*(diff(U(x, y), y, y))+16 = 0 where boundary conditions are
U=0 on x=1,-1
U=0 on x=1,-1
diff(U(x, y), y) = -U on y=1, -1< x
diff(U(x, y), y) = U on y=-1, -1< x
Hi everybody,
I have a follow problem:
Maple offers generate graph (network) for example in this way:
G:=Graph({{1,2},{1,3},{2,3}})
where {{1,2},{1,3},{2,3}} is a list of edges.
In my study I need to generate a big graph (network), where list of edges is very long
(contains more than 100000 edges).
Can I import from my directory (for example C:\\Desktop\) file, contains edges.
Now I copy from txt file all list of...
with(ScientificConstants):
GetElement(Ra,atomicweight);
I want to pick 3 random(ish) points from a 3D plot for using in an iterative scheme.
Is there a way of doing this by just clicking the plot and getting the (x,y,z) values for the specific point or is it something more complicated?
Rachael
We have a set S of 30 elements and choose its subsets A, B, and C such that nops(A union B) = 5,
nops(A intersect B intersect C) = 3. How many ways are there to produce that?
How to count this number  with Maple?
First 1621 1622 1623 1624 1625 1626 1627 Last Page 1623 of 2430
