Kindly help me plotting the following equation:
beta = 0.25
alpha0 = 0.2580   or 15 degrees
alphad = 0.545    or  31 degrees
Bmax = 0.7
alpha = 0 to Pi/2
B(alpha) = (1-beta-beta*cos((Pi*alpha)/(0.8*alpha0)))*Bmax      for interval     0<alpha<0.8*alpha0
B(alpha) = Bmax       ...
Hi, i am trying to create a breakpoint on my worksheet. But i cannot press the debug current operation icon. Is there some other settings that i must press before using the button? Please help. Thanks.
Hi, may I know how do i rearrange the matrix by shifting them please?
For example, i have a 9x9 matrix. I would like to shift the first column to the end (1..9,1) becomes (1..9,-1), and the rest of the matrix (1..9,2..9) becomes (1..9,1..8).
Hi; I am working on a package where the data mostly come in Maple records with a varisble number of fields with different names. At least one field in each record has a 6 by 6 matrix, the expressions of which involve the values associated with at least some of the other fields.
Occasionally I have the need to, say, apply a function to each of these fields. E.g., I want to substitute a value for a specific name; this name may show up in several fields and also will show up in the matrix.
ode1 := Diff(y(x),x$2) + (lambda-x^2)*y(x) = 0;
After put y = exp(-x^2/2)*y1(x) into above ode1
would like to find the solution of ode in terms of integration
in this example, it use z^(-lambda/2-1/2) = expa(-lambda/2-1/2)*log(z)
the example solution should be int(exp(...),z)
linearsol(ode1, y(x)); but return {}  nothing
Photobucket
Thanks a lot
Hi all. I am trying to use the Weyl character formula to evaluate some traces of Hecke operators on algebraic modular forms. This involves me having to substitute certain eigenvalues of 4x4 matrices into a polynomial of arbitrary degree (my choice).
I have created procedures that do this given the eigenvalues. Unfortunately I am having problems generating the eigenvalues.
The problem is that the matrices I am using are formed from products of matrices from two...
Assume having to solve an ode with dsolve and plotting with odeplot. Further, markings at specific parameter values of the solution should be plotted, i.e. if p is the solution of the ode, the points p(t1), p(t2), ... should be plotted. Since the ode is complicated and computation takes a lot of time, is there a way to extract the values p(t1), ... from the odeplot result directly without invoking calls like subs(p(0.5),b(s)) again?
Fine $a_{n}$ of sequence  2 , 3 , 6 , 7 , 10 , 11 , 14 , 15,...
Why do the statements eval(sign(x),x=-2) and subs(x=-2,sign(x)) both give plus one while sign(-2) gives -1 as expected?
eval(sign(x), x = -2)
Hello every one,
I got an error while trying to solve numerically a nonlinear system of odes using
the dsolve command. This error is very common,
"Error, (in dsolve/numeric/bvp) initial Newton iteration is not converging".
I tried the different technique explained in
http://www.maplesoft.com/support/help/Maple/view...
I want to graph the portion of the plane 2x + 3y + z = 6 that are located in the first octant of a xyz coordinate system. The following implicitplot3d should in principle do it:
Regards, I am conducting independent research in my university and I was recomended to use this software but since I am more familiar with matlab it feels harder to use maple and I'm making many mistakes.
My question is how to solve the following equation w(xi) = a_0 + a_1 * xi + a_2 * xi^2 + a_3 * xi^3 + a_4 * xi^4
So I defined xi = x/L
and gave some boundary/initial conditions for this equation(don't know if this is right)
w(0) = 0 : w(L...
Trying to create multi-dimensional geometric brownian motion by using:
W := GeometricBrownianMotion(Vector(N, 1), Vector(N), B.B^%T);
but receive the following error message:
Error, (in Finance:-GeometricBrownianMotion) invalid input: ProcessOptions expects its 1st argument, x0, to be of type realcons, but received Vector(2, {(1) = 1, (2) = 1})
The vectors and B.B' matrix are fine, because
W := BrownianMotion(Vector(N, 1), Vector(N), B.B^%T);
First 1682 1683 1684 1685 1686 1687 1688 Last Page 1684 of 2430
