This thread stimulated me into playing with a few ideas,
I pieced together this little newton-raphson procedure...
> newton := proc( f, # the function x0 # the initial guess n, # step count limit tol # error tolerance)
local x, g, k;
g := D(f); # the derivative f’(x)
x[0] := evalf(x0); # initialize the iteration
for k from 1 to n do # loop for newton’s iteration
# Newton’s iteration formula
I can not get any subscription in the forum for any topic. Activating the subscription link directs me to the page:
http://www.mapleprimes.com/controls/#
Without the subscription validity.
The goal is to find generating function of Hermit
Before i try, i try the gFun's paper's example, got error
with(gfun):
eq := {z^2*diff(y(z),z)+y(z)=z, (D(y))(0)=1};
eq2:=borel(eq,y(z),Y,'diffeq');
Error, (in gfun:-borel) invalid argument, Y
When try Hermit,
with(gfun):
eq := {t*diff(y(z),z$2)-z*diff(y(z),z)+y(z)=0,y(0)=1,y(-z)=y(z)};
dsolve(eq);
but have unknown constant coefficient, do not know whether missing initial condition
I am trying to solve the system of equation by maple but its not giving the correct answer.
> e1 := (1/2)*alpha*alpha[3]^2*q[2]^3-V*alpha[4]*q[2]^2-V*alpha[0]+(1/2)*alpha*alpha[0]^2+(1/2)*alpha*alpha[1]^2*q[2]+(1/2)*alpha*alpha[2]^2*q[2]^2+(1/2)*alpha*alpha[4]^2*q[2]^4-V*alpha[2]*q[2]+C+alpha*alpha[3]*q[2]^2*alpha[1]+alpha*alpha[4]*q[2]^3*alpha[2]+alpha*alpha[4]*q[2]^2*alpha[0]+alpha*alpha[2]*q[2]*alpha[0];
> e2 := -gamma*alpha[2]*q[3]*q[2]^2+2*beta*alpha[4...
I was using "eliminate" to combine a set of equations removing some variables and getting a clearly wrong result. So I looked at the docs and the first example, and I find I don't understand its result either. Here is the example:
sol:=eliminate( {x^2+y^2-1=0, x^3-y^2*x+x*y-3=0}, x); # eliminate x from this set & leave one eqn of y
This returns:
I am trying to fit some data to a model.
The model is given by this equation.
y=a*(1-exp(b*x^c))
When I enter the command
Statistics[Fit](a*(1-exp(b*x^c)),X,Y,x);
this error message appears:
Error, (in Statistics:-Fit) SVD of estimated Jacobian could not be computed
 Does anyone know, why it appears? and why Maple cannot compute the SVD of the estimated Jabobian Matrix?
Please help me with the next problem in Maple. When I try to find roots using solve command but
it throws the next message:
Warning, solutions may have been lost...
The procedure is performed as follows:
fx := (-(1/2)*(sqrt((x-x1)^2+(y-y1)^2)-m1)^2*(2*x-2*x1))*(1/(s1*sqrt((x-x1)^2+
(y-y1)^2)))+(-(1/2)*(sqrt((x-x2)^2+(y-y2)^2)-m2)^2*(2*x-2*x2))*
(1/(s2*sqrt((x-x2)^2+(y-y2)^2)))+(-(1/2)*(sqrt((x-x3)^2+(y-y3)^2)-m3)^2*...
I have a table T where the indicies are pairs (a,b) of integers with 0<a,b<50. Is it possible to make a 3D plot with a point (a,b,T(a,b)) for each (a,b) in the domain of T?
eq1:=diff(f(eta),eta,eta,eta)+f(eta)*diff(f(eta),eta,eta)+beta*(1-diff(f(eta),eta)^2)=0;
eq2:=diff(theta(eta),eta,eta)+pr*f(eta)*diff(theta(eta),eta)+pr*Ec*(diff(f(eta),eta,eta))^2+(2-beta)*pr*Q*theta(eta)=0;
bc:=f(0)=gama,D(f)(0)=lamda,D(f)(N)=1,theta(N)=0,D(theta)(0)=-Nc*(1-theta(0)):
gama:=-1.5:Ec:=0.5:
lamda:=1:
Nc:=3:
pr:=5:
beta:=1:
N:=5:for Q from -1.5 to 1.5 by 0.1 do A[Q]:=dsolve({eq1,eq2,bc},numeric,
How can I archive color coding? The two plots are colored the same, but I want them to be colored according to one common color scale, which means that each z value is assigned to a unique color for the 2 function plot.
f1 := proc (x, y) options operator, arrow; sin((1/2)*y+(1/2)*x) end proc;f2 := f1+2;
p1:=plot3d(f1, 0..10, 0..20, style=patch, color=proc(x,y) x*y end proc);p2:=plot3d(f2, 0..10, 0..20, style=patch, color=proc(x,y) x*y end proc);
plots[display](p1,p2);
I have .dat files that I want to use in integrating some function, say
f(x)=int(1/a(x),x),
where I have the numerical values of a(x) as "avalues.dat" file.
I am wondering if there is a command that does the integration numerically...
And also for  differentiating numerically: g(x)=diff(a(x),x)
In geom3d, how can i make a triangle which coordinates of the center circle circumscribed triangle are integer numbers? Please help me. Thank you.
hello every one!
i have a pde problem( heat problem) i wanna plot it with maple and i know how can i solve it with maple but i wanna plot it and solve it with my boundry condition and initial condition then plot it
here my problem:
> with(PDEtools);
> PDE := diff(F(r, t), t)-.102*10^(-6)*(Diff(r*(diff(F(r, t), r)), r))/r = 0
I am using Maple 11.  When I set up an equation, I can see an easy solution by visual inspection but when I have Maple solve the equation then use real numbers the results are different!  What is going on??  I have uploaded my worksheet which shows the discrepancy.
Using export to obtain fugures from maple the resolutin is poor. How can I get images with 1000dpi resolution?
First 1690 1691 1692 1693 1694 1695 1696 Last Page 1692 of 2430
