please a need help
i try to organize the matrix by indice , i.e
B := Vector[row]([1, 4, 13]);
 ind:=indices(B);
A := Matrix(3, 3, [1, 3, 4, 2, 4, 1, 2, 3, 2]);
#i try to do that
A:=B(ind,..); # and didn´t work
#this is what i wont,
A := [1, 1], [1, 2], [1, 3], [3, 1], [3, 2], [3, 3], [2, 1], [2, 2], [2, 3]
help
What are all the maths that are on this program?
Hello All ,
I have attached my workseet for reference.
I find it strange that the solutions calculated in optimization shows a value "X" but when i try a value greater than "X" , there is still a solution available which is very irregular.Since the optimization finds the value beyond which the solution for a6 is zero/negative.
I am not sure what is causing this problem or is it just the problem with the optimization.
Hi all!
I have declared two vector valued functions
G1:=(x,y,u)->(x/(1-a*y) , y/(1-a*y) , u/(1-a*y));
G2:=(x,y,u)->(x/(1-b*x) , y/(1-b*x) , u/(1-b*x));
And composed them, so far so good
G1G2 := G1@G2;
But now I would like to simplify G1G2, how can I do this? With simplify(G1G2) I get an error.
Any idea how I can fix this?
Thanks in advance,
Arta
Hi everyone, Im trying to solve a catenary problem. x is defined in terms of y1, y2, and a. But in my case a is the only unknown. I try to express a in terms of x, y1 and y2 by the following script:
> x := a*arccosh((y1+a)/a)+a*arccosh((y2+a)/a);
/y1 + a\ /y2 + a\
a arccosh|----------| + a arccosh|--------|
\ a / \ a /
> solve(x, a);
Using Maple for Functions of a Random Variable
How to make a query is made to F (t) at each iteration of the dsolve command?...
de:=m*diff(x(t),t$2)+b(t)*diff(x(t),t)+k*x(t)=F(t);
a random force :
nd := Statistics:-Sample(Uniform(-100, 100)):
F:=proc(t) ;
if not type(evalf(t),'numeric') then
  Excuse me, I have a code
for i from 1 to 5 do
  f[i]:=i*2;
print(i,f[i]);
  In windows, the output is
                              1, 2
I am a programmer (not a real mathematician, scientist or engineer) who wishes to insert just dx into an expression and have Maple recognise this as an infinitesimal difference in x rather than just a symbol named dx with no relation to x.
Is this possible in Maple?
I ask as I want to include dx as a normalising term in a derivation and hope that it will 'drop out' at a later stage.
Will Furnass
I want to solve this differential inequation in maple please help me.
diff(N(t),t)-mu*N(t)<=Pi;
How do i find coordinates of the vertices of a square in Maple which coordinates of the vertices are integer numbers? Please help me. Thank you.
I want to animate the display of a polygon. It's the platform of a stewart gough rig. Have 200 poses stored as Platformi i i=2..200. the Base is static( obiviously). Haven't been able to figure out how to get    animate(display .....) to work. The work sheet just contains copy/pasted commands. The time period for the animated display is about 10 seconds but real time is not that important. How do I get this to work?
Hi, I have variables and would like to assign different values to them and later on combine them for the final calculation. How do i do it? For example:
I have 5 variables in each file. (a,b,c,d,e).
It contributes to my Force, Amplitude, MatrixAA and MatrixBB
How do i put it in a way where i can have 3cases?
Case1:= a=1,b=2,c=3,d=1.5,e=6 ; And It shall give me Force1, Amplitude1, MatrixAA1, MatrixBB1
Case2:= a=3,b=3,c=1,d=3,e=8 ; And It shall...
Suppose I have a matrix M, with rational entries. I need to go row by row and scale each individually by the smallest possible integer such that the entries in each row are integer-valued - anyone have an easy way to do this? It's a large matrix.
i do have two equations containg two pararmeters, i need to exclude one parameter, then substitute it in the second equation and then differentiating the first equation which contains now one parameter, then solve it for that parameter.
i actually did it, but fsolve function does not work with me , can you help me please
Hi, whenever i save the worksheet, all my previous calculated solutions are missing and I need to execute it all over again. Is there a way to keep the previously run data because it is a long worksheet and takes quite sometime to run it. Please advice. Thanks.
First 1699 1700 1701 1702 1703 1704 1705 Last Page 1701 of 2430
