I want to solve the position of a bal with a variable angel of the start velocity. I want to know which angle I have to take when the ball must be in a fully known position (5.44 , 1.60).I must also take the friction into account.
Therefore I have a system of equitations that I can solve with dsolve if I fill in the angle (in degrees).
> dsolve(eval(stlsl,angle = angeltest), numeric);
It gives me back values in x(t) and y(t). But know I want to make...
I need to plot a discontinous function based on a previous discontinous function described by the picture:
Hi Mapleprimes,
The nextprime(n) function will give the next prime, given n.
Suppose I want the 8th next prime so how can I find the 8 th next prime quickly?
I guess I could find the ones in between, but maybee there is a better way.
n  nextprime(n,8)
2          23
3          29
5          31
Hi.
I need something to use Maple for solving Finsler equations and I heard mathematications use Finsler package based on Maple but I couldn't find any information about it? Who can help me
Does anyone have experience of this?  I am trying to figure out how to tinker with a x3d file exported from Maple so it can be printed on a 3d printer.  Here is an example of something that was printed from a Mathematica file.
http://www.shapeways.com/model/503264/hyperbolic-paraboloid.html
Is there some way to do this?  I am hoping to export the plots to x3d files with the ultimate goal of sending the files to a company that can print them on a 3d printer.  (for example, Shapeways http://www.shapeways.com/  )
Attached are results I obtained in MAPLE 12.  Can anyone explain the contradiction?
In short, if I sum from n = 0 to some integer I get a FALSE when testing the equality, which is what I would EXPECT.  However, if I change the integer to a variable to represent that integer such as m--> the result is TRUE?
Note the change in the variable of beta to alpha inside the series expression within the parentheses.
regards
I would like to know if there are any command that can generate the first n terms of the fourier series expansion of a piecewise continuous function ( and/or its odd/even extensions). I am looking for a command similar to what the taylor( ) command does for Taylor series.
I found some references on packages such as "OrthogonalExpansions" and "Fourier" none of which are avaliable with a standard Maple installation. If user-defined packages are my only option,...
I am trying to extract the underlying equation for a simple operational amplifier circuit in MapleSim 5.  The same process that I had used earlier for a simple resistor circuit (without opamp) worked fine and yielded equations.  However, when I try to do the same thing with an opamp (configured to do a simple amplification of an input voltage) I get a blank "View Core Equations" box in the Equation Extraction attachment.
I have a problem with "subs" command in maple. When I use it the outcome does not show only the final result. It shows the (middle operations=final result).
For example, suppose that v(t)=x^2+1 is a function obtained from some calculations and L:=h*u(t). WhenI use: f:=subs(u(t)=v(t),L); it shows: h*u(t)=h*v(t)=h*(x^2+1). I want to show only the final results: h*(x^2+1). It make a problem in my next calculation in solving some differential equations.
y = 0;
0 = 0
`\`if'`(0 = 0, x, 0 = Float(infinity))
0, 0
`\`if'`(1 = 0, x, 0 = -1.)
1, 0
`\`if'`(2 = 0, x, 0 = .5000000000)
2, 0
0.
Download lattsum1.mw
Write a procedure that determines the solutions of a quadratic equation from inputs a, b and c by using the discriminant and the quadratic formula. The quadratic equation procedure should be able to solve all cases: invalid input, linear case, real and complex roots. The procedure should also plot the given equation.
I am bothered by an error that I don't understand. I am trying to write a procedure to solve numerically a delay differential equation "step by step" (for example y'(t)=y(t-1))
here is my code
y[0]:=t->t; #my initial condition on [-1,0]
p:=dsolve({D(x)(t)=y[0](t-1), x(t0)=x0}, x(t), numeric, parameters=[t0, x0]);
p(parameters=[0,y[0](0)]);
y[1]:=t->op(2,op(2,p(t)));  #y[1](t) is the value of p(t) but in a "readable" format
Hello, I am new to maple and trying to teach myself as i go along. I am trying to plot a paramteric for a puck on a fristion less table that spins for differnt vo values. Here is my code: puckontable.mw
Hi, I am trying to the following. When my DizLambda value is 0, I would like it to show "a" and if it is not 0 but smaller than 1.5 to show "9", otherwiese, it it is not 0 and bigger than 1.5, to show its original value. How do I do that please in its own matrix position?
interface(rtablesize=infinity):
node:=9:
Lambda:=DiagonalMatrix([3,6,4,2,5,2,3,5,3,7,4,7,4,6,8,9,2,1]):
dizLambda:=Matrix(node*2):
for i from 1 to (node*2-1) do
First 1723 1724 1725 1726 1727 1728 1729 Last Page 1725 of 2430
