I'm currently running a parameter space search via Maple scripting. The pseudo-code goes something like this:
fopen text file to write data to;
initialize parameters (variable) x, y, and z;
for x number of iterations
   A:-Simulate(model.msim, with [parameters]);
   Update parameters with new values;
   Write to text file;
fclose(text file)
I use Maple 15 and I want to take the real and the imaginary part of a simple expression e.g. 5*Dirac(x)+3*I, having already assumed x a real value. However, Maple seems to have problem with the Dirac function. The output looks like this:
> assume(x, 'real');
> Re(5*Dirac(x)+3*I);
5 Re(Dirac(x))
> Im(5*Dirac(x)+3*I);
3 + 5 Im(Dirac(x))
Any thoughts on how to overcome this are welcomed.
Hi I'm new to maple and have to solve this:
Find the transferfunction
I beleve the answer should be:
H(s) = Y(s)/G(s)  =  1/(s^2+(1/4)s+1)   (correct me if I'm wrong)
but i have to show how to do it in Maple in a scool project
please help me have tried for several hours now, but cant get it right
Can someone please tell me why I am getting this error (in bold):
> ODE := diff(y(x), x)+3*y(x) = x^2
> ics := y(0) = 1
> dsolve({ode,ics})
Error, (in dsolve) not an ODE system with respect to the unknowns {y(0)}
restart; with(plots); Eq1 := diff(f(eta), `$`(eta, 3))-(diff(f(eta), eta))^2+m*f(eta)*(diff(f(eta), `$`(eta, 2)))-(M^2+lambda*P)*(diff(f(eta), eta)) = 0; Eq2 := diff(theta(eta), `$`(eta, 2))+m*pr*f(eta)*(diff(theta(eta), eta))-lambda1*pr*theta(eta)*(diff(f(eta), eta)) = 0; bcs1 := f(0) = s, (D(f))(0) = -1, (D(f))(10) = 1; pr := .72; M := 1; m := 2; lambda := 1; lambda1 := 1; bcs2 := theta(10) = 0, theta(0) = 1; L := [0.5e-1, .1, .2, .4, .6, .8, 1, 5, 10, 20]; for k to 10 do R := dsolve...
Hi everyone, I am getting this error message in maple can i get any help
Error, (in DynamicSystems:-RouthTable:-RouthTable) the polynomial must not contain complex values
Hi all
Can anyone suggest ways of speeding up this code ?
div_vec := proc(a::Vector,b::Vector)
# procedure returns the element-byelement
# division of vector a by vector b
local i,c:
c:=Vector(Dimension(a)):
for i from 1 to Dimension(a) do
c[i]:= a[i]/b[i]:
return c:
LR
Let G be an undirected graph having the vertices V={1,...,n}. A subset {i,j,k} is said to be a triangle of G if the complete graph with these vertices is a subgraph of G.
How to find the number of all triangles of G in an optimal way? The code should work with RandomGraph(400,1000).
I am plotting a curve generated from odeplot and I would like to fill the area under this curve.  I have tried filled=true and filled=[color="Blue",transparency=0.5] in the call to odeplot but it only plots the curve with no underfill.  Please advise on how to shade the area under a curve generated from odeplot.  Thanks very much.
Is there a simple way to have Maple re-formulate an expression like:
  r^2 * sum(A(j)*r^(n+j))
to :
  sum(A(j)*r^(n+j+2)
simplity, collect doesn't seem to do it.
Is there a simple function, or does one have to revert to the subsop procesure reported in a 2008 post.
I am working with mapleSim in two different computers, one in my school and another that is mine. I am using dropbox to keep the mapleSim documents and the costum component that i am creating synchronized in both PC´s. But i have noticed that mapleSim store the file that i attacht in another folder, so when i change the components equations in one document, on the other PC there are no changes. Is it possible to change the folder where the...
I want maple 15 to show me how it works out the formula (transposition) from N = 40^(1.5t) to t = 0.666..7(ln(1/40)*N)
I want to know how it transposes this formula from N to t I want the steps the actual working, I can't seem to figure it out as I'm using maple 15 as a learning tool, I have all the student modules installed but have no idea what I'm doing here
> N = 40*exp(1.5*t);
N = 40 exp(1.5 t)
I need some help on a problem which seems simple...
I'm doing as follows:
restart; with(LinearAlgebra); with(plots):
II[C] := proc (delta) options operator, arrow; 230/(84192.96489-230*cos(delta)+(-1)*4128.950345*sin(delta)) end proc
(sorry for the formatting)
plot(II[C](delta), delta = -Pi .. Pi)
(This works just fine and produces a nice plot, then I continue)
f1 := plot(II[C](delta), delta = -Pi .. Pi)
Hi guys,
I tried many days but cannot find where to download or buy MapleNet 15. Please help me I am so appriciated.
I wonder if it makes sense to use tables as datatype for efficient maple code. I need this datatype to pass parameters to a procedure which is called many times.
In particular, I have the following criteria:
* efficient (fast) to access for read and write.
* potentially thread save ( I can also imagine having individual copies for each thread)
* present in future Maple versions
* easy to transform into C-code later
First 1755 1756 1757 1758 1759 1760 1761 Last Page 1757 of 2430
