Hi, I try to integrate the following but it is giving me more than i want, how do I fix that ?
The answer should be just [0.1745329,0.6981317,0.1745329]. The answer with power of minus 9 and minus 10 is insignificant.
Please help. Many thanks
If I have a function defined as
                                             F[i]:=x[i]^2 +x[i]*y[i]+y[i]^2    where  x[i]:= (i-1)0.1  and y[i]:=(i-1)0.2 ,    i=1..100
I have the following problem. Two formulas in three variables represent the costs of algorithms. I want a visual of their ratio, so that I can "see" how their relative performance varies. Here is a simple example. I can analyze this example analytically, but you can't always do that.
R := sum(binomial(n+i*d,n),i=1..k-1);
S := binomial(n+k*d,n);
f := unapply(R/S, n, d, k);
A := Array(1..10,1..10,1..10,f,datatype=float[8]);
I want a 3-dimensional rendering...
hi
I am a mechanical engineer student and i am trying to learn mapleSim, but i am having some dificulties.
I am first trying to model an heat exchanger from a domestic water heater. I have found on maples website a costum component and i am trying to do a similar one to start.
The component that i am talking about is this one:
http://www.maplesoft.com/applications/view.aspx?SID=35160
The problem is that after i put my own equations, parameters,...
Hi, I tried to export my answers into an excel file, but my numbers are all complex numbers.
It says "cannot export an rtable with complex values". How can I go about it?
Please advice. Many thanks.
How can several expression statements be not displayed during and after an execution process of "then"conditional statement (I mean "If.....then...")?
For example:
if .... then
exp1:
exp2:
exp2:
each expression above can consist of various commands in its body.All my exp statements were finished by ":"
but, they...
I just noticed something rather peculiar (well, to me, at least). When I compute the limit
limit((1-1/x)^(-x),x=-infinity)
as is, I get the expected result of exp(1).
However, if I load the RealDomain package prior to computing the limit,
with(RealDomain):
I get that the limit is undefined.
Any ideas as to why that is the case? Thanks!
I'd like to take the second derivative of the following function (see below), but I keep ending up with an
Error, (in content/polynom) general case of floats not handled
The range of the equation that I want to look at is from 0 to 1 and I know that it "blows up" around 0.09 for EQ1 but not EQ2.
The commands that I've tried are diff(%,FIO2) and Diff(%,FIO2).  I'm probably missing something obvious, so hopefully someone can tell me...
Can anyone explain the rationale behind plot command, which generates the same graph differently for an identical function?
> restart;
> with(plots); with(plottools);
m := 4;
k := 20;
omega[n] := sqrt(k/m);
T[n] := evalf(2*Pi/omega[n]);
td := 0.5*T[n];
ratio := evalf(td/T[n]);
p3 := 4*sin(Pi*t/td);
dur := evalf(2*Pi);
enc := u(0) = 0, D(u)(0) = 0;
eq := m*(diff(u(t), t, t))+k*u(t) = p3;
sol := unapply(rhs(dsolve([eq, enc])), t);
I have a function
f:=x->(x^2 + 2*m*x + m + 1)/(x -1);
Now I want to define a function as simplify(diff(f(x),x)), i did
g:=x->simplify(diff(f(x),x)). Then, i could not calculate g(3). Please help me. Thank you.
http://aw.twi.tudelft.nl/~koekoek/askey/ch3/par28/par28.html
Which function represent phi in 3.28.1
I would like to ask, what is the way to use the Direct Search (or other similar package) to solve not a static optimization problem for, say f(x_1,x_2), but the dynamic one, say for f(x_1(t),x_2(t),t)?
I think there must be the way of adapting the algorithm for that.
Any ideas welcome.
Best
Want create my own geometric distribution with rather only natural values i.e. without zero:
c:=Distribution(PDF=(t->PDF(Geometric(p),t-1)));
But such form is luck to calculate even Mean value:
simplify(Mean(c)) fails. How to apply to get even Mean(F(c)) for complicated enough F?
In which context runs subj? Why all time when i start debugging with 'stoperror' it stops at 'interface' call i.e. in debugger
interface('prettyprint')
doesn't return 3 as worksheet returns. It return interface('prettyprint') i.e. symbol.
I have a matrix with values of interest from .04<4 and I want to round all the terms that are ~10^-10 and lower to zero.  Is there an easy way to do this?  fnormal only works for lists!
First 1759 1760 1761 1762 1763 1764 1765 Last Page 1761 of 2430
