if the tolerance can only accept gamma function, rational function
How to convert Kummer expression into other simple formula?
i have calculated a generating function, but the actual answer is much simpler than this
Gen := {p(z) = exp(-I*z/sqrt(c))*KummerM(-(-(1/2)*sqrt(c)*beta+(1/2*I)*beta*c+I*(-1/2+c)*x)/sqrt(c),
beta,
(2*I)*z/sqrt(c))*(-KummerU(-(1/2)*(-sqrt(c)*beta+I*beta*c-I*x+(2*I)*c*x)/sqrt(c),
beta, 0)*_C1+1)+exp(-I*z/sqrt(c))*KummerU(-(-(1/2...
Sorry for this noobish question but I have problems solving this 2-dimensional Integral:
int(x*y(x^2-y^2)/(3*(x^2+y^2)^3), [x = 0 .. 2, y = 0 .. 1])
Maple 14 does not solve it. Mathematica did solve it but I was hoping for Maples Integration tutor (great thing) to help me solve this on my own.
Im not sure if anyone can help but whenever I plot a graph maple freezes. It looks like the program just refuses to plot it and repeats the command until i get to past where the graph should be at which time it goes back to working fine.
Another way of describing the error is, whenever i...
rsolve({c*(n+beta)*P(n+1)/(-1+c)+(c*(x+beta)/(1-c)-x)*P(n)+n*P(n-1)/(-1+c)=0,P(0)=1}, P(n));
return rsolve({c*(n+beta)*P(n+1)/(-1+c)+(c*(x+beta)/(1-c)-x)*P(n)+n*P(n-1)/(-1+c)=0,P(0)=1}, P(n));
Any other method besides rsolve to solve genfun?
i discover it can solve variable coefficient and n coefficient too.
but sometimes n*P(n+1) make it can not solve, i have to remove n to P(n+1)
any paper describing the mechanism of rsolve, where it store the maple code of rsolve in maple 15?
Please write for me another code for the following problem:
Write the equation of the plane (P) passing through the line (d): x = -t -1, y = t + 3, z = 2*t + 2, (P) cuts the axis Ox at A and the axis Oy at B (A, B different form origin O) so that OA = 2OB.
This is my code
f:=(x,y,z)->a*x+b*y+c*z+d:
A:=f(m,0,0):
B:=f(0,n,0):
C:=f(-1,3,2):
When one equation has no exact solution. I use rkf45 to solve it.
How can I plot the error figures. Can I use the order:s1 := seq([tt[p], Xrre[p] - Xrre[p - 1]], p = 2..N):
Digits:=15:
w := 500:
k1 := 1:
k2 := sqrt(2):
k3 := -1-sqrt(2):
u1(t):= t/(t + 1)*exp(I * k1 * w * t) + cos(t) * exp(I * k2 * w * t) + exp(I * k3 * w * t):
u2(t):= exp(I * k1 * w * t) + exp(I * k2 * w * t) + t * exp(I * k3 * w * t):
That's the question... 'cause I've tried to open it using
./maple14/bin/maple -cw
like a thousand times and nothing happens...
In status box between "Evaluating..." and "Memory, Time, Mode" there is enough space. Would be nice to have there smth like "user-defined status" of ~100 symbols (or so). Instead of long printed log you could see status of current stage of long-term process.
Hi, I have a question about LPSolve. I definately have a linear polynomial as objective function, but LPSolve seems to think otherwise. My best guess is that it has to do with that my variables are indexed like that? Here is the code, I attached it as well.
I have a question. I need to rewrite the following function
Vo:= (1/((1/R2+1/(1.5*10^6))*(1/(1/R2+1/(1.5*10^6))+2.45*10^3-R2)));
To this form
R2:= ....Vo....
How can i do this in maple?
Re random is it possible for man or machine to create any two objects the same i suggest not,we may be only talking about such small differences that are possible undetectable (number of atoms per object) however a difference and if there is then each object will have it's own characteristics ie two lottery balls if you could study trillions of thows i'm suggesting you would see a pattern it may be so slight but not totally truly radom
It is never a good error message but I have not been able to find out whatit means.
Is there a way to plot a function in a multithreaded way?
I have a computing-intensive function (eg. integral over Hermitian-Polynoms), which I want to plot. I couldn't find a way to do this such, that all my cpu-cores are used.
Any suggestions?
Thanks for the previous support and help.
I am trying to solve a poisson equation, but I am getting Bessel function in the solution. Derivation of this equation with respect to 'r' gives more complex form of Bessel function.
Actually I am not sure should I continue with the problem and Maple will take care of everything or I have to modify in the solution.
Equation 9 and Equation 11 needs to...
First 1761 1762 1763 1764 1765 1766 1767 Last Page 1763 of 2430
