We have the following sequence of natural numbers 1, 4, 9, 13, 11, 27, 25, 37,.. . What is the next term?
Is it possible to find it with Maple? The approach
> with(gfun):
>l:=[1, 4, 9, 13, 11, 27]:
>rec:=listtorec(l,u(n));
fails because it produces a noninteger value of u(n) for some natural values of n.
Hello all,
I'm familiar with using _ and ^ to enter subscripts and superscripts in document mode. However, the only way I know of moving out of those modes is to use the arrow keys. I was wondering if there was an alternative shortcut that wouldn't require me to move my hands from the home row?
Amr
EDIT: I have figured it out (somewhat), so nevermind!
I wrote this in my AddSystem:
However for output that should be unitless, I still get units (which can be cancelled), like this:
hi
i want to export figures in maple to word. in other software like Tecplot when we use WMF format, the figures saves like a vector and when magnifiyng picture , quality remains good. but in maple when i export figure as WindowsMetaFile the quality of figure decrase and decrases with magnifing. i want to know how i export figures in maple to keep quality high. thancks
In my Maple program results are exported to a file. But the problem is that I should write a path every time manually that complicates a work. Moreover, I often forget to change a path and correspondingly new results would often rewrite previous results stored in other directory. The reason is that the path of stored results folder have to be the same as the path of Maple code run.
How can to do it automatically? How to make that Maple knows a path from where Maple...
Hello. I'm studying engenieering mathematics at DTU and I just started working with Maple. When I tried to open my work in progress I got the following message: "
There were problems during the loading process. Your worksheet may be incomplete".
Some of my colleges are experiencing the same problem...
opgave_1a.mw
I am trying to solve a differential equations with the periodic coefficients, which have the following form:
where
In the attached workbook I define a function that contains an if. This seems to confuse the plot function when I try to plot my function. How do I plot this function?
PlotFunctionWithI.mw
Is it possible to a plot,  shown in worksheet, insert vertical lines using the Builder plot ?
GRACIAS
What is a pulse height analyzer?
What math behind the PHA? DFT FFT?
Gracias
Hello everyone
Yes, im just another one with problems during loadingproces.
Just lost my assignment in advanced engineering mathematics, and I do not know what to do.
Anyone who can help a friend in need?
The file is attached.
- Patrick
Download Assignment1.5.mw
Download FLM.mw
Hey there in the file above, i have an equation with units, that maple dont seem to be able to solve.
Its the equation at the bottom on the box.
Can anyone tell me what i am doing wrong?
Rune Eriksen :)
I have a piecewise function which I require to be transformed to a fourier series.
The function to be transformed is:
         velocity:=piecewise(t<=6, 3*sin(t*Pi/6), t>6, 0);
How can I change this to a fourier series in a simple manner.
Thanks for your advice.
Is there a way to make the x, y and z axes thicker in 3d plots?
I want to do a Monte Carlo study with the following probability distribution:
P(X=x):=(x-1)*q^(x-2)*(p^2+(2*(1-p-q))*p)+binomial(x-1, x-3)*q^(x-3)*((1-p-q)^3+(1-p-q)^2*p);
with x = 2. 3, ... infinity and parameters p and q with 0 < p+q < 1. For the Monte Carlo study I ave to generate samples with specified values of p and q. For this I have yo do something similar to:
use Statistics in T:=[1/2,0,0,0,0,0,1/2];
d:=Distribution(ProbabilityTable(T));
First 1825 1826 1827 1828 1829 1830 1831 Last Page 1827 of 2430
