I want to use leibniz rule to differentiate the following Integral with variable domain:
A :=(t,x) -> int(Yt^2, x = 0 .. zeta);
Yt and zeta are defined as:
alias(zeta=zeta(t));
Yt:=(t,x)->diff(y(t,x),t);
When I want maple to derive D[1](A(t,x)), its answer is:
2*D[1](Yt)*Yt*Zeta+Yt^2*D[1](Zeta)
Although it uses Leibniz rule correctly, it dose not take Yt as a function of x by mistake. 2*D[1](Yt)*Yt*Zeta should had been derived as int(2*D[1](Yt)*Yt,x=0..zeta).
How can we draw a sequence of segments with a list data of column vector? Thanks
In Arfken(Mathematical methods for physicists,5-th edition,page 483),the asymptotic form of the Hankel function is approximated as
H1(t,s)=
sqrt(2/(Pi*s))*exp(I*(s-t*(Pi/2)-Pi/4))
Is there any simple/direct way in Maple(using HankelH1(),or otherwise) to achieve this?I don't want to assign numerical values to t or s.
I'm using Maple 15.  It seems to me this worked in some previous version...
Consider the Lambert W function, y=LambertW(0,x) ... I want Maple to tell me the asymptotics for it,
something like this:
log(x)-log(log(x))+log(log(x))/log(x)
But I don't get that now.  Is my memory faulty that I got it in the past?
Maple 15:
  asympt(LambertW(0,x),x);
not very useful...
series(LambertW(0,x),x=infinity);
LambertW(0,x)
with(MultiSeries):
LambertW(0,x)
GDQM2.mw
Hi everyone,
I am facing a very complicated system of nonlinear equation. This cannot be solve by using normal fsolve in Maple. Anyone can help me?
Thanks a lot
The results I get from calcultion are usually not in compact forms, so I want to do some simplifying work. And I come up with some questions.
If I write the following expression, the factor command works:
> beta[c]^3/exp(I*omega[c]*tau)-beta[c]^2/(exp(I*omega[c]*tau))^2-2*beta[c]^2+2*beta[c]/exp(I*omega[c]*tau)+beta[c]*exp(I*omega[c]*tau)-1;
> factor(%);
However,when I write the above expressoin as following,  factor doesn't work
Hello everybody,
I would like to assign 349 different variable not already existing (w[i], i from 1 to 349) to 349 expressions from a list. Unfortunately I do not know how to write it. When I try anything like a:=w[33]->listevnouveau[33], it does not work.
With this a, I want to solve this : solve(listedd[33]*w[33]=a,w[33]); which is only possible by assigning variable to the expression.
Regard, Charbo
Is there a direct command to give the (first) index in a list,
for which the entry coincides with some given value (without
coding a loop, to run through the list)?
PS: when I enter that question I automatically get an info,
that similar questions exists. But clicking on those links do
not give usefull infos, they just lead to a page of old threads
(Page 529 of 569 for the first link ...)
Hi all
I am trying to draw a 3d plot from the data that I have created in excel, how do I import from excel to maple and then draw the 3d plot using array?
below is the link to my dataset in excel
Book1.xls
your help is appreciated
What Should I do to get the correct result-which is obviously not something like my answer.
> assume(a::(AndProp(NonZero, constant, real)));
> about(a);
Originally a, renamed a~:
is assumed to be: AndProp(real,constant,Non(0))
> is(a, constant);
> is(a = 0);
> is(a^2 > 0);
> assume(p::real, 0 < p and p < infinity...
How I can say that an object,say k, is a constant(it may be positive or negative) inside assume()?
assume(k::??should I say)
pls also tell me what kind of help pages I should see for this kind of "type inside assume()" problems.
I'm working on a mecanic's problem and I need to solve a differential equation:
I want to determine x(t) and plot it...
This is the way I do it:
with(Physics):with(combinat):
comn := choose([u, v, mu, nu], 2):
def := seq(seq(seq(Physics[`.`](Dagger(Ket(aa, k)), Ket(bb, m)) = Physics[`.`](Ket(bb, m), Dagger(Ket(aa, k))), `in`(aa, comn[i][1])), `in`(bb, comn[i][2])), i = 1 .. nops(comn)), seq(seq(seq(Dagger(Physics[`.`](Dagger(Ket(aa, k)), Ket(bb, m)) = Physics[`.`](Ket(bb, m), Dagger(Ket(aa, k)))), `in`(aa, comn[i][1])), `in`(bb, comn[i][2])), i = 1 .. nops(comn));
Setup(def):
d1 := Physics[`.`...
I was recently browsing the Wolfram website, in particular the Online Integrator, and was very impressed that they are exposing a part of their product for free public use. I also noticed that they offer the option of submitting previously unknown anti-derivatives to them:
(From the FAQ page, http://integrals.wolfram.com/about/faq/#8)
“If you think you have a...
I have three different matrices, say A(3x6),B(3x6) and C(3x12) with the size of each matrix mentioned within parenthesis. I want to define a fourth matrix D (6x12) so that D=[A,B;C] (in Matlab notation). Can anyone please tell me how to define this D in Maple? Maple help seems not that helpful at least for beginners like me. Thank you in advance.
First 1861 1862 1863 1864 1865 1866 1867 Last Page 1863 of 2430
