I'm using Maple 11 and pdflatex. I'm trying to export Maple code to latex.  To this end, I've exported my maple file as a latex file and included the maplestd2e package in my tex document. However, from compiling the tex file I only obtain pdf output for those parts of the original maple file that represent output. For example, the following tex-code correctly produces the word 'true':
\mapleresult
\begin{maplelatex}
\mapleinline{inert}{2d}{true}{\[\displaystyle {\it true}\]}
hi
how we can design of experiment through maple?
Maple 11 did a reasonable job of breaking up long output being exported to LaTeX, but it wasn't always
perfect. I had hoped that Maple 15 would do better, but it seems to do worse.
I can't get it to split long output lines into anything reasonable. The latex command is even worse.
I've tried every "export" option I can think of, without success.
Here is an example (see below):
Does anyone know how to induce Maple 15 to export the following Maple result ...
Hey guys. Can you help me with this problem? I'm trying to plug in a snowflake equation in finding the perimeter of a snowflake on the nth step. The function is as follows:
p:=n->(3*(3/4)^k, k=1..n);
I'm trying to find the limit of this equation and it's suppose to give me infinity by using this command:
limit(pn(n), n=infinity);     but it's not quite giving me the limit. The limit is...
hello
I have a large data series and i need to get derivative (numerical derivative) of them. how can Ido it?
Hi there,
I want to know how I can animate a plot with more than one parameter? I can manage animating a plot with one parameter, using the 'animate' command, but this seems to be limited to a single parameter.
How could I do it? If it is not possivle in Maple 11, would such an option be implemented in Maple 15?
Also: If I would want to animate other things than plots, are there commands for that in Maple 11 / 15?
Thx :)
When I solve a certain equation I get a list of solutions t as below. I want to select some of the solutions and assign them to variables. In the program I am writing the number of items in the list of solutions will vary and so I cannot really select the list item by using t[3].t[4] etc. for example.
I want to be able to select only the list items with say a square root sign or another term such as Pi, beta etc that appears in the list of solutions. So...
As I did not upgrade to Maple 14 when it came out, I am interested to know the differences between v15 and v13. Obviously, it is easy to get a comparison between v15 and v14, as all I need to do is study the promotional advertising. But is there a way of getting a comparison list between v15 and v13 ?
thanks,
Andrew
How do I standardize the size of ALL plots in a document or worksheet?
If I use
plot(Im(arctanh(x)),x=-2..2);
for |x|>1 I get a constant imaginary part of -sign(x) Pi/2.
Is this correct and if so can anyone help me understand why this is so?
Hi there,
I'm looking to merge the following two lists:
L:=[[1,1,1,1,1],[1,1,1,1,1],[1,1]]
M:=[[],[],[],[],[],[0],[],[],[],[],[0],[],[]]
In the following way:
N:=[[1,1,1,1,1],[0],[1,1,1,1,1],[0],[1,1]]
Basically so it takes alternate terms (i.e. L[1], M[1], L[2], M[2] etc.)
Any help would be appreciated!
Thanks, Sam
I am trying to solve the following differential coupled system :
DN:=diff(N(x),x)=a/4*(x+8*(sin(F(x)))^2/x)*N(x)*diff(F(x),x)^2;
Du:=diff(u(x),x)=a/8*((x^2+8*(sin(F(x)))^2)*(1-u(x)/x)*diff(F(x),x)^2+2*(sin(F(x)))^2+4*(sin(F(x)))^4/x^2);
DDF:=diff(F(x),x$2)=1/(N(x)*(1-u(x)/x)*(x^2+8*(sin(F(x)))^2))*(-(x^2+8*(sin(F(x)))^2)*diff(N(x),x)*(1-u(x)/x)*diff(F(x),x)+(1+4*(sin(F(x)))^2/x^2+4*(1-u(x)/x)*diff(F(x),x)^2)*N(x)*sin(2*F(x...
I need to find the differential equation of the following situation:
There's is an epidemic in a city of a certain poupulation(P). The rate of the spread is propoptionnal to the to the number of people infected times the number of person who are not infected.
I need to find the differential equation of this situation where N(t) will represent the number of people infetected(N) bas on the time. The only information I have is the populaiont(P...
Hello:
I have Maple 13 and I get the following error message "Error, (in pdsolve/numeric) unable to handle elliptic PDEs" while trying to solve a set of PDEs.
Does Maple 15 solve elliptic PDEs?
Amit
First 1873 1874 1875 1876 1877 1878 1879 Last Page 1875 of 2430
