I tried to install a trial version of Maple on a notebook. After the selft extraction of the installer the rest of the proces is stopped without error messages. The notebook is a modern multi-proc.64-bit  Win 7 correspondent to the software version I tried to install. The question is what to do to solve the problem.
I would like someone to help me with this issue I have.
First after some operation I found the following equation:
> m := (x(q))^2 + x(q)
and then I'm creation a function like this:
> eq := q -> m
but then maple is not substituting the equation m inside the function I created, how can I do that, I must work with functions this way and I'll be working with bigger equations but I don't want to copy/paste or type them into the function.
How do you find the intersection of 2 subspaces of R4
v1= [x(1,2,3,4)+y(0,2,3,2)]
v2= [x(3,2,1,1)+y(3,1,1,3)+z(6,4,2,2)
I need to:
a) Find the equation of the sphere passing through the 4 points [- 8, 3, 11], [5, - 7, 1], [- 15, 4, - 6], [10, 2, 9].  Give the coordinates of its center and its radius.
b) Plot together the sphere of part a along with the 4 points of the dataset.
I can't seem to get maple to do this!  I am very frustrated as the sphere command doesn't even seem to work.  I am a total maple n00b...
Download 321.mw
There is a problem which I feeling very puzzling, it is not the codes, but about when running the codes. It seems that if I running the codes immediately (or use "run all the worksheet" ), an error returned unexpectedly, but if I wait a few seconds before rerunning the code which just causes the error, a correct result returned. I feel very...
When I am trying to write the data of the following program in a datafile
with(plots)
eq := (diff(G(eta), `$`(eta, 2)))/Pr-2*n*b*eta*G(eta)+(a+(1/2)*b*eta*eta)*(diff(G(eta), eta))
> A := {x=0, y=0}:
> B := {x=0, -y=0};
> {A} union {B};
{{x=0, y=0},{x=0, -y=0}}
How to get Maple to realise that A and B are actually the same so that "{A} union {B}" would return "{{x=0, y=0}}" instead of above?
How to join expressions in the set, for example to convert the set {y=0, x>-1, x<1} to {y=0, -1< x <1}?
Thank you in advance.
when drawing a geometry.line object by using geometry.draw, the default for each axis is -10..10, so that I cannot see in the plot, for example, the line y=11;
How can I extend this range?
Best regards
Ouba
I want to plot a bunch of straight lines with positive slope in one colour, and I want to plot a single line of negative slope in another colour.
I hope my code is self-explanatory:
restart; with (plots):
myEqns:=NULL:
for i from 1 to 5 do;
 myEqns:=myEqns,y-x=i;
myEqns:=[myEqns];
 [y - x = 1, y - x = 2, y - x = 3, y - x = 4, y - x = 5]
implicitplot([op(myEqns), y+x=0], x=-10..10, y=-10..10, colour=[red,blue]);
I am a beginner at Maple. A friend of me has told that Maple can solve analytical solutions.
In other words, I want to combine three equations ( a linear system)  in order to conclude to the final solution.
Has Maple the ability to solve analytically a linear system of 2 or more equations?
Thank you very much in advance.
Kind Regards
Thanos
I'm trying to have Maple work through ideas involving the Fundamental Theorem of Calculus, and am encountering a problem with the programming of Maple.
I begin by defining a function like:
F(x) := int(x^2,x)  (or equivalently, F:= x -> int(x^2,x)  )
Then I ask Maple to evaluate F(2).  I expect to get 8/3 but instead I get this error message:
Error, (in int) integration range or variable must be specified in the second argument, got 2
even if I use a simple x^2+y^2 plot I get these funny gaps at the botom of the plot. I have looked through the FAQ files and can't seem to find a solution to it... is there one ?? from what I have seen so far there does not seem to be an easy solution. with a graph like the type above to change to coords=spherical or cylindrical does not show the same graph due to that change.
I tried to implement an small example sheet for using the RSA algorithmen with small numbers. Unfortunatly, I get confused by my own program and have difficulties to figure out what I am doing wrong. My message can be decoded with both keys, the public and private key what is obviously not correct.
below is my code with some comments:
restart: with (numtheory):
p := 13; # my first prime number
q := 23; # my second one
n := p*q;
I am of interest about using StateSpace(de, invars
First 1878 1879 1880 1881 1882 1883 1884 Last Page 1880 of 2430
