would you please help me?
I have a big problem in differentiating with maple!
here is my equation.
L := (alpha, beta, theta,alpha(t),beta(t),theta(t))
how can I find diff(L, alpha) ?
L=(1/2)*I[a]*(diff(alpha(t), t))^2+(1/2)*I[b]*(diff(beta(t), t))^2+(1/2)*I[c]*(diff(theta(t), t))^2+(1/2)*m[3]*(b^2*(diff(beta(t), t))^2+(1/4)*C^2*(diff(theta(t), t))^2+b*c*(diff(beta(t), t...
Hi, friends
The physics package was provided a good tool to compute Commutator or anticommutator relations. Here, I met some problems.
Example 1:
      restart: with(Physics):Setup(mathematicanotaion=true):
      Setup (op={p[x],p[y]},p[z]):
      alg:=%commutator(p[z],p[x])=2p[x], %commutator(p[z],p[y])=-2p[y], %commutator(p[x],p[y])= p[z]
Why the "Mean" command of the "Statistics" package gives the correct result with MAPLE 12 and MAPLE 13 and not with MAPLE 14 ?
with(Statistics):
X := RandomVariable(('Uniform')(-1, 1)):
Y := RandomVariable(('Uniform')(-1, 1)):
pdf := simplify(PDF(sqrt(X^2+Y^2), rho)):
R := RandomVariable(Distribution(PDF = unapply(pdf, rho))):
The mean may be computed using (the answer is correct)
int(rho*pdf, rho = 0 .. sqrt(2)):
I'd like to numerically compute integrals of the forms:
int(exp(-t)/((-3+2*exp(-(1/10)*t))*(-3+2*exp(-(9/10)*t))), t = 0 .. infinity); evalf(%)
where there are much more terms in the denominator, e.g.,
Int(e^(-t)/(product(-3+2*exp(-.1*(1-.1)^i*t), i = 0 .. A)), t = 0 .. infinity); evalf(%)
for some positive integer A. Even when I have three terms it takes so long... So how do I compute such integrals numerically with maple; what's the efficient...
Hi everyone
I'm new to the forum, but I hope you can help me with a problem concerning import of pictures to Maple. I'm working with diffraction from a rectangular and circular aperture. I haven't made the experiment yet, but I've thought about taking some pictures of the diffraction pattern and then use Maple to calculate the intensity of the light to make a three dimensional plot (intensity as a function of position).
Right now I just want to import a picture...
Hi, everybody,
I am a newbie of maple. I used maple to draw some function image, it's work pefectly. For higher quality I want to set a thick line width of axis but I don't know how to do. Help me please.
Best regard.
You would have thought I'd have learnt to make sure I've saved my work by now.
I've spent the last 4 hours or so working on a worksheet on Maple, without saving it once (I know, I know). It started acting slow-- by which I mean it was talking a while to actually type things, as opposed to running calculations-- and then the screen suddenly went grey, froze, and now my cursor turns into an hourglass when I mouseover the window.
It's been this way for the past 10 minutes.
Question: Graph the 4th degree polynomial with realcoefficients whose zeros are x=-2 (a repeated root), x=3 and x=0. Following all the graphing requirements as shown below:
- show the correct shape of the function without distortion or wasted space.
-show all the maxima, minima, and intercepts
-allow to read (x,y) coordinates of all the x and y intercepts and all the maxima and minima on the graph easily and clearly.
-have a...
please help me to draw national emblem of AZERBAIJAN.
    I have this problem and I cannot find a way to perform this search that I want it to.
I have a set consisting of integers and fractions.  What maple code can I use to select only the integers out of this set.
For example:
A:={1,1/2,9,5/2,6/4,8,10,11};
I want to choose only the integers out of this set...so I need to obtain a set with D:= {1,9,8,10,11}.
How do I do so?
I'm teaching numerical analysis with Maple and then I started with fixed iteration method.
When I programed the method which is simple, I got the solution as:
restart:with(Student[NumericalAnalysis]):
f := x->2*tan(x)-x-1;
g := x->arctan((1/2)*x+1/2);   # fixed point method where the solution of x=g(x) is the the solution f(x)=0
x[0] := 0.2; for k from 0 to 20 do x[k+1] := evalf(g(x[k])) end do; this line give the solution
How can I plot on the same graph the Normal,Tangent and Binormal vectors from a Position Vector?
> restart;
> with(DifferentialGeometry):with(LinearAlgebra):with(JetCalculus):with(Tools):with(PDEtools): with(DEtools):
> declare(u(x(t),y(t),t),v(x(t),y(t),t));
u(x(t), y(t), t) will now be displayed as u
x(t) will now be displayed as x
y(t) will now be displayed as y
v(x(t), y(t), t) will now be displayed as v
> PDE_sys:={diff(u(x,y,t...
Was given the equations f(x)=x^3+3x+7 g(x)=tan(x^2+1)
Need to use maple to differentiate each of the following...
A. f(x) * g(x)
B. f(x)/g(x)
C. f( g(x) ) entered as f@g
D. g( f(x) )
How do i differentiate these, normally for its just D(f) but i tried D(f@g), D(f * g) but it doesnt look right. Please help!
THanks
Has anyone had any experience of using an eBook reader such as a Kindle to read/display any of the Maple manuals?
First 1880 1881 1882 1883 1884 1885 1886 Last Page 1882 of 2430
