Hey!
I am trying to simplify this: (a+b)(a-b). As we all know, this is a2-b2. Maple, though, returns this: a(a+b) - b(a+b) which is also correct, but not what I want it to show :D Any way to make it show a2-b2?
I tried simplify, factor, expand - they all give the same result. Am I doing it wrong? :D
I try to sketch and solve PDE
PDE:+diff(u(x,t),t)+2*diff(u(x,t),x)=0
with boundary condition
u(0,t):=piecewise(0<t and t<=2*pi, sin*t,0)
how to get the solution u(x,t) and sketch u(x,0),u(x,pi),u(x,2*pi),u(x,3*pi)?
the derivative of the improper integral int(cos(1/sqrt(u))^2,u=0..x) at the point x=0 with Maple?
As a new user I'm having some trouble using indexes in matrix and vector operations. For instance, I can declare three vectors from the 3 by 3 matrix E using index i:
for i from 1 to 3 do Eigenvector[i] := Column(E, i) end do
This creates 3 vectors with indexes 1 to 3 out of the matrix E as expected. However, Maple seems unable to transpose one of the indexed vectors:
Im trying the plot the roots of
(-t)^5=abs((t^2+t+1)/(-t))
on the complex plane but its not allowing me to do so, and when i just plot it only the axes come up and no points.
Any help is appreciated.
Using Maplets Elements I'm trying to program some inputs which I then want to use to solve a differential equation. My Problem is that my inputs are somehow in the wrong data type. I actually don't even know what data type they are, but it's not string and no number as I can't calculate with them.
I do have a little programming experience (php, Java, C++) but it's my 1st maple program which I need for school.
My code so far is:
________________
f:=x->x^3:
y[1]:=0.5:
y[3]:=subs(x=0.5,f(x)):
i := 2:
y[i] := y[i-1]-(y[1]-y[2+1])*(1/2):
i:=1:
g[i] := (y[i+1]-y[i+2])*x/(y[i]-y[i+1])+(y[i+2]*y[i]-y[i+1]*y[i+1])/(y[i]-y[i+1]):
g[i] := unapply(g[i], x):
h[i] := unapply(solve(y = g[i](x), x), y):
for i from 2 by 1 to 5 do
g[i]:=(f@h[i-1])(x);
g[i]:=unapply(g[i],x):
s:=solve(y=g[i](x),x):
h[i]:=unapply(s[1],y);
 for this code i got error "Error, (in kernels)...
I have a system of equations  AX=B where the matrix A from dimension 307x200, X from 200x1, and B from 307x1
How can I use Gauss elimination to solve these system of equations.
Can one find an integral representation of the solution of the following system of PDEs?
pde1 := diff(f(x,y),x) + A(x) * ( p11* f(x,y) + p12 + p13*x )
= p14 * B(y)/B(x) * diff(f(x,y),x);
pde2 := diff(f(x,y),y) + A(y) * ( p21* f(x,y) + p22 + p23*y )
= p24 * B(x)/B(y) * diff(f(x,y),y);
f(x,y) is the unknown function,
A(x) and B(x) are known functions,
p11, p12, etc. are real parameters.
If p14=0 and p24=0, the right-hand...
Dear All
I wonder if anyone can help me with something simple with odeplot.
Under some conditions that I can't pin down, Maple won't run the system for the whole time range I ask for, and it's not related to "maxfun". For example, in the simple lines of code below, Maple will only run out to t=3, no matter how I set the maxfun or stepsize. It is a general issue I have, for other systems as well.
Anyone know something? Thanks a lot, David.
(3 lines of code follow)
Hi guys please help me with the following.
When I evaluate the integral below
int(1/8*2^(1/2)*exp(-1/2*x^2/sigma^2)/(Pi^(5/2)*sigma)+1/8*2^(1/2)*exp(-1/2*x^2/sigma^2)*Q*exp(I*k*x)*exp(I*k*theta)/(Pi^(3/2)*sigma)+1/8*2^(1/2)*exp(-1/2*x^2/sigma^2)*Q/(Pi^(3/2)*sigma*exp(I*k*x)*exp(I*k*theta)), x = (-infinity .. infinity));    --------(1)
I get an expression with things like
csgn(conjugate(sigma)) and
Hi there....
I have a set P={4,5,6,7,12,14,15}
in order to create permutations of the numbers in set P into sets of 3 I did the following:
with(Statistics):
>P={4,5,6,7,12,14,15};
> O := combinat[permute](P, 3);
But this does not produce permutation of the same number in a set as the integers in P can be repeated more than once....for example {4,4,4} or {15,15,15}?
How can I do so?
Any help will be appreciated
How can I solve the following problem using Maple:
Determine the special solution u(x,y) of the PDE
(  diff(u(x,y),x) )^2+( diff(u(x,y),y) )^2 = u(x,y)
such that the solution passes through the circle
x(s)=cos(s), y(s)=sin(s), z(s)=1        (0 ≤ s ≤ 2π) .
The solution obtained "by hand", i.e. without Maple, reads
u(x,y) = (1/4) ( 1+
QQ.mw
I want to find the inverse function of the given function h(m),and also plot the inverse.I can't find any help to evaluate the inverse function in an explicit form.I plot the inverse though,but why its so ugly?How I can customize its domain & range?
I'm trying to use dsolve to get a numeric solution to a series of differential equations I have. I've got:
G := 1;
M := 1;
pT := 2;
OrbitEnergy :=  (r0) -> -1/r0+(1/2)*L^2/r0^2-L^2/r0^3;
OrbitDEs := diff(r(tau), [tau$2]) = -G*M/r(tau)^2+L^2/r(tau)^3-3*G*M*L^2/r(tau)^4, diff(phi(tau), tau) = L/r(tau)^2, diff(t(tau), tau) = sqrt(r(tau)/(r(tau)-2*G*M)+(diff(r(tau), tau))^2*r(tau)^2/(r(tau)-2*G*M)^2+r(tau)^3*(diff(phi(tau), tau))^2/(r(tau)-2*G*M));
First 1895 1896 1897 1898 1899 1900 1901 Last Page 1897 of 2430
