Dear friends,
I have to generate several pages of tables with numbers (using the option Matrix in Maple) and to write them in Latex.
Is there some option to be able to include  titles of the tables, names of the columns, notes on the bottom of the pages?
I saw some question like this in mapleprimes, but it was time ago that I wonder that now maybe the Latex Output of Maple has improved.
Thanks for your attention,
Hey folks I'm trying to solve equations using isolve for which I want conditions on my two variables x and y. I would like them to be both positive and x>y. The problem I'm having with isolve now is that I can't manipulate the output I get. Perhaps there is a way to do this but I can't see how yet. It would produce something like {x = 1, y = 2} for example and I can't extract the numerical values from it (at least using [] operators). I currently don't have access to maple...
Hi everybody,
I have a little problem with Maple 14.01:
I would like to export a figure created with plot3d as an eps file. I do so by simply right-clicking on the figure and than on export -> encapsulated postscript. The problem: it does not work properly:
With Maple 12, I get a 2mb large vector graphic. If I export the same figure under Maple 14.01, the file is only 148kb large und not a vector graphic - when I open it with Inkscape, it just looks like an ordinary jpg-picture.
1.For win 8, does there exist an arm version maple in future?
2.Will it possible to use gpu acceleration for symbolic computation in maple?
I have 8 equations (eq1, eq2, eq3, eq4, eq5, eq6, eq7 and eq8) with 8 varibles A1[n], A2[n], C1[n], C2[n], B2[n], A[k,i], D2[n], A[0,i] and where n=1..nn, k=1..nk, i=1..Q
I have some difficulties to get the matrix form AX=b
Thanks in advance for any help
I attached my maple code
piers.mws
Would much value shared experience or solutions on this
How to solve a set or a system of differential equations in maple for motion with Schwarzchild metric?
************** Schwarzchild metric *****************
with(tensor):
coord := [t, r, theta, Phi]:
g_compts:=array(symmetric,sparse,1..4,1..4):
g_compts[1,1]:=1 - 2*G*M/(r*c^2):
g_compts[2,2]:=-(1 - 2*G*M/(r*c^2))^(-1):
g_compts[3,3]:=-r^2:
g_compts[4,4]:=-(r^2)*sin(theta)^2:
g1 := create([-1,-1], eval(g_compts)):
Hi. I wanted to figure out how to plot a boundary value problem in Maple. It is a nonlinear, fourth order ordinary differential equation with four boundary conditions. The BVP has the form (d4/dt4)-3(d2/dt2)(d/dt)=0, with boundary conditions x(0)=0, x(1)=60, (d/dt)(x)(0)=0, and (d/dt)(x)(1)=0. Thanks.
Hi, Im new here. Is there still no better solution than changing the setting for everyting in MS Windows? The red on white really hurts the eyes.
I've tried out external editors (MS Visual Studio 2008 Express) but the problem with those is, that you can only run your complete code, making prototyping and developing a pain.
Thank you for any tips!
I am a retired physicist persuing independent mathematical research and don't fit into any of Maplesoft's four user catagories.
I am trying to develop a new finite element method for incompressible fluid dynamics in 3D. I must derive four vector functions which are mapped into the 84 degrees-of-freedom of the finite element. I expand each of the four functions in terms of multinomials with 192 unknown coefficients to be determined. I apply essential constraints to each...
I entered
animate(plot,[s*cos(Pi/2*(1-t)),s*sin(Pi/2*(1-t)),s=0..1],t=0..1);
and received the error
Error, (in plots/animate) unexpected options: [s*sin(.5000000000*Pi), s = 0 .. 1]
This is to draw a radial line beginning at 12 o'clock and ending at 3 o'clock.
I could get it to work as
animate(plot,[tan(Pi/2*(1-t))*x,x=0..1,view=[0..1,0..1]],t=0..1);
though.  But the length of the line is not fixed as I require.
I can solve a [0,1] linear programming problem by using:
LPSolve(Ob, con, assume = binary);
I managed to solve [-1,1] linear programming problem by using the transformation
2*w[i]-1 ie   2*0-1=-1 and 2*1-1=1 as follows:
LPSolve(add(PP[i]*(2*w[i]-1), i = 1 .. NC)-add(Draw[i]*(2*w[i]-1), i = 1 .. NC), {add(w[i], i = 1 .. NC) = PS}, maximize = true, assume = binary);
Now my question is how can I solve a [-1,0,1] problem?
I tried to use:
I'm quite new to maple and I'm not really sure how to go about fitting a curve to my data, I have inputed the data by doing;
data := [[1,3],[2,3].........[2,7]]
and then plotted it using a point plot. Now i know I need to fit a resonance curve using LSsolve but I dont know how to go about using that command. Could anyone please enlighten me.
> restart;
> Fax := 1493/2;
                                    1493
Dear friends,
I generate a table for n=1 to 3.
Matrix(  [ seq ( [n, n^2], n=1..3)]);
I would like to generate the same kind of a table for values of n= 1 to 3, 50, 100  and 1000.
How may I do it?
Thanks in advance for your help.
Jean-Jacques
First 1911 1912 1913 1914 1915 1916 1917 Last Page 1913 of 2431
