I am trying to obtain the points with equal value of a two variable function ,f(x,y), 0.01<x<0.99, 1.01<y<1.99. I tried to dsolve the problem but I have one equation, two variable and infinite answers . Ho can I get these points with interval of 0.01 and insert in a marix. Thank you in advance.
Hello everybody!
I couldn't find this question on the internet.. I hope for a answer here! I have to know this in 4 hours, and nobody here seems to be able to solve it. Thanks a lot in advance!!
What i'm trying to do is to solve these 10 variables. here is my maple:
So Robert, how can we solve the below problem with the Optimization package
in Maple?
A quadratic objective xTQx can be handled by introducing a new variable t,
making the objective "minimize t", adding the constraint  xTQx <= t,
and converting this constraint to SOC form
I am in a class of combinatorics following two definitions are to be coded in Maple. I have done my best but could not. Kindly help.
Def 1:    Let M=[mij] be a matrix of type m×n, whose entries are subsets of a set A.
Def 2:    A set matrix M is said to be a partition matrix of set A if:
    1. mir∩mis=φ, for every i,r,s, such that r≠s;
    2. m
I am brand new to Maple.  I am using Maple 13.  When I try to create a direction field for the ODE dy/dt=.2ty I get the intended result.  When I try to create the same direction field using the ODE dy/dx=.2xy I recieve the following warning.
"Warning, y is present as both a dependent variable and a name.  Inconsisent specification of the dependent variable is deprecated, and it is assumed that the name is being used in place of the dependent variable".
Test.mw
I have this data (see attached worksheet). I then run the below code
and then I get the output (see below). The problem is that I have explicity
stated in constraints 3 (con3) that w[i] should be larger than or
equal to zero. Still I get negative solution ie w[1]=-1.47*10^(-18).
Why is that?
The funny thing is that when I change constraint 3 to w[i]>=0.01 then I get :
I am a new user of Maple. I need help in defining the Sxx and Syy in terms of differential terms of P and Q in the following program. I have attached the worksheet with this mail.
Thanks a lot for your tips.
RPD
E.g. how do I say "x conditional on w" in Maple. The following doesn't evaluate:
x|w
Error, unable to match delimiters
or:
mu[x|w]=sum(v[i],i=1..n)*f(v[i]|w);
Error, `|` unexpected
 x := proc (i::integer)
      return i^2;
sum(x(m),m=1..3);
Error, invalid input: x expects its 1st argument, i, to be of type integer, but received i.
If I want to reserve the ::integer declaration, How to solve this problem. I know if there is no
alpha := vector([cos(theta), sin(theta), sin(k*theta)]);
alpha1 := map(diff, alpha, theta);
alpha11 := map(diff, alpha1, theta);
with(linalg):
cr := multiply(alpha1, alpha11)/simplify(multiply(alpha1, alpha1));
F := vector([0, 0, -m*g]);
c := multiply(F, alpha1/simplify(multiply(alpha1, alpha1)))/m;
motion := diff(f(theta), theta$2) + cr*diff(f(theta), theta)^2 = c;
pdsolve and dsolve not work, how to solve above motion equation with maple?
Is there a way to make Maple display the line where an error has been detected ?
RedVivi
> restart: with(plots):
> plotopts:="portrait,color,noborder,leftmargin=0,bottommargin=0,width=5cm,height=12cm":
> plotsetup(eps, plotoutput="test.eps", plotoptions=plotopts):
> plot(x^2,x=-5..5);
> plotopts:="portrait,color,leftmargin=0,bottommargin=0,width=5cm,height=12cm":
> plotsetup(eps, plotoutput="test_.eps", plotoptions=plotopts):
> plot(x^2,x=-5..5);
this creates two files, test.eps and test_.eps....
hi.
this is my procedure, i think its obvious what its supposed to do, but it doesnt.
#plot p to file filename with size width cm x height cm
> makeeps := proc(p, filename, width, height);
>   plotsetup(eps, plotoutput=filename,
>   plotoptions="portrait,noborder,color,leftmargin=0,bottommargin=0,width="||width||"cm,height="||height||"cm");
>   display(p);
>   plotsetup(default);
I am trying to solve a piecewise differential equation of the following form:
FOI := diff(r(x), x) = piecewise(r(x) < 0, 1, r(x) > 0, 0)
dsolve({FOI, r(0) = -1})
but MAPLE returns an error stating
Error, (in dsolve) when calling '`property/ConvertProperty`'. Received: 'real is an invalid property'
I do not know what to make of this. I have tried playing around with assumptions...
I have some difficulties to create an X-Y chart and what data structure I should use.
I have a loop, I set the maximum number of iteration to nmax.
At the end of each iteration, I will retrieve two information (variables):
-iteration number, 1 by 1 until nmax, integer: n
-an value associated with this iteration, integer: v
I will store iteratively these values (at least v) at the end of each loop...
First 1912 1913 1914 1915 1916 1917 1918 Last Page 1914 of 2431
