First problem:
I have the following loop within some longer code. If I execute the worksheet, the loop gets stuck in the "print(within*loop)" section and never stops.
Second problem:
If I don't restart the sheet, Equation 3 doesn't do the 'subs' command properly. Also, if I put the "with(Package)" commands in the beginning, Equation3  also fails to do the subs properly.
Hi! I have an aquation and I want to solve it numerically. How can I do that?
The equation is:
H(z)^(2*n)*(H(z)^2-K1*(1+z)^3-K2*(1+z)^4)=1-K1-K2;
where K1 = 0.27, K2 = 5*10^(-5) and n = -0.1.
Thanks a lot!
 I want to solve this
The function of my problem is:
f(x) = piecewise(x < 0, 0, 0 <= x, exp(-1/x^2))
where a=0,x=0.5 and ξ=.25 i want to find reminder of f(x),R, and then plot R-n plot(n is degree of diff)
Hint:
I am a beginner in maple, these days I am learning maple user manual.
There is an example given by the manual:
___________________________________________
x:=872349
while x>0 do
irem(x,7)
x:=iquo(x,7)
end do
____________________________________________
I retype them in maple, but maple always returns "Error, illegal use of an object as a name"
I check my statements carefully, it is the same...
After fixing the problem outlined in a previous post, I seem to get another error that I can't explain.
"Error, (in int) wrong number (or type) of arguments" is the product of defining a function 'u(r,theta,t)' and then defining each of its components.
I've attached the file here as well. Could someone help with troubleshooting? MapleMem5.mw
I am trying to transform this expression:
sin(sqrt(K)*t/sqrt(M))
into this expression
sin(omega[n]*t)
using the equation:
How does one raise or lower indices of tensors when one is using the atlas package. Do we have to create a table and then use the inbuilt maple command raise/lower to do this or can one do this within the atlas package.
i'm trying to run the following procedure:
> restart; with(LinearAlgebra);
> test:=proc(alpha, beta);
Error, unterminated procedure
         testAssignTypesetting:-mambiguous(
           procApplyFunction(&alpha;comma &beta;),
           Typesetting:-merror...
Every so often when I press return, the cursor will not move to another line.  I have to use an arrow key to move it to the next line to continue wit hthe execution.  This is extremely annoying.  Any idea why maple is beaving like that?
I can get the whole document executed when I use the !!! comand but the cursor ften stays in some command line in the middle of the document instead of the last line.
Also when I have a line of text in between...
I have an equation on paper that I am trying to rewrite in Maple for plotting purposes.
Because the equation is large, I split it up in different parts, "frontcoeff", "cosCterm", etc. Ultimately I want an equation "u" which is a function of (r,theta,t) and is composed of a summation over "k" and "m".
Image 1: http://postimage.org/image/1etwulgpw/
I then get the following error:
Image 2: http://postimage.org/image/1evagpvj8/
I'm looking for a way to fit a function to measured data points. The special thing about it is that each data point has an individual error in x- und y- direction, and I would like the fitting command to consider these individual errors. I'm aware of the Statistics[NonlinearFit] command, but there I only can assign one weight per data point - not one for each degree of freedom.
I'm a physics student, and in the moment this is my major problem for using...
Is there a way to plot a graph in a fliped way.
I tried to do this using Vectors. But this is not so easy.
plot(Vector(70,x->sin(x/10),Vector(70, x->x+1/10));
plot(sin(x),x=0..7)
>f:=x->(1/sqrt(1+x^3));  I typed this function into Maple, but I keep getting: Error, missing operator or ';'. I'm not sure what I'm missing!
First 1944 1945 1946 1947 1948 1949 1950 Last Page 1946 of 2431
