I'm going to put this plot into LaTeX, so it'd be nice if the font is similar. Both equations are functions of one variable.
Is there a nice, concise command to do this? Additionally, what's the easiest way to export this graph into a format useable by pdfLaTeX?
Thanks so much!
I'm running Maple 14, if that matters.
Hi everybody:
I was wondering if there's a tool in maple that would allow you to plot a function f(x,y) over a geometric shape (e,g,, a triangle). Sort of like the Matlab logo if you know what I mean. Or even simpler: for x=0,y=0..10, sin(y), and y=10,x=0..10, sin(x)
thanks a lot
dimitrios
Maples own spiralgraph or kalidascope.
It's kind of annoying sometimes when you create a plot and you haven't got enough points to see a nice smooth curve.  It's an easy fix, of course. Just add numpoints=x where x is any number you want.
However, that being neglected this simple little animation reminded me of the spiralgraph craze in the early 80's, or could even be a kalidascope if the colors changed.
animate(spacecurve,[[sin(x*t),x,cos(x*t)...
Thanks to Robert Israel, I have solved my problematic PDE.
Unfortunately it seems that solution is incorrect.
I have compared with FEA system and obtained different results.
I'm not sure but  probably point is in boundary condition (see lambda3) and I don't know
if we should not use a set of PDE's.
I will be try further but if somebody helps me I will be appreciated.
I enclosed file with calculations.
wzel
Forgive me for not using the "Maple Math" and "Maple Plot" commands.  I tried, but it says everything that I enter is an invalid expression so I'm just entering it as text...
I define two functions, they plot as expected:
f(x) := sin(x);
g(x) := 2*x;
plot( f(x) );
plot( g(x) );
Now I want to plot the composition:
plot( f(g(x)) );
Doesn't work!
Preliminaries:
  • Not processing matrics, vectors, or equations (as members).
  • Decided sequence Data Structure for an element addressable DS, is most liking to my needs.
Task at Hand:
  • Processing integers consecutive from 1 to 10,000 (later upto one million) for multiple properties.
  • Presumed marking of a memeber to indicate T/F.
  • (later) Although, in time, to perhaps? place a sequence inside that member, for additional degrees of marking, or "bigger data" too.
  • Example: bag_list[ 3] := 1; BL[5] 1, 7 1, 11 1, 13 1, 17 19 23 ...
  • ie, Marking the primes.
I am not an expert in Mapple, also my calculus courses were quite long ago. I would like to compare different decision methods. The simpler ones worked with the code below (even if it was slow). but I have problems with the differentiation and the integration of two complex methods (i.e., dia and topsis).
All these methods can be described in general with the  following function:
f:= (X::Matrix,C::Vector)-> TerminalScores::Vector
Hi There,
I'm having a problem trying to solve the folllowing system of PDEs.
PDE1:=diff(P[e](x, t), t) = 5e(-5)*diff(P[e](x, t), x, x));
PDE2:= diff(P[s](x, t), t) = 5e(-10)*(diff(P[s](x, t), x, x));
IBC:={5e-5*(D[1](P[e]))(0.2e-3, t) = 5*10^(-10)*(D[1](P[s]))(0.2e-3, t), P[e](0, t) = 1, P[e](x, 0) = 0.1e-1, P[s](0.215e-3, t) = 0};
Sol:= pdsolve({PDE1,PDE2},IBC,[P[e](x,t),P[s](x,t),numeric);
Error, (in pdsolve/numeric...
I would like to combine a maple 2d-plot with a existing jpg-file in one graph.
How can I do that?
I tried something with ImageTools, but that doesn't seem to work.
Hi at all. In my attachment you will see my problem. I want to fit datapoints with a set curve and I used the Fit-command. If I plot the points and fitting curve the curve is not on the points. Where is the false in my sheet?
test_only_Fit.mw
I used "implicitplot"  and get the plot. But I want know the data of the plot. How to get the data?
I have downloaded and unzipped a student version of Maple 14. When I click on the icon named Maple14MacInstaller.app, it flashes and nothing happens. What now?
Mac w OS X, 10.4.6, 3.06 GHz Intel Duo with 4GB RAM.
I'm not sure if this might be stretching Maple's capabilities a bit, but I was wondering if there was a way to perform model reduction (through substitution) in Maple?
Let me explain. Suppose I have a system of nonlinear equations: f(y,z,u) = 0, where u = input variables, z = intermediate variables, and y = output variables. For instance:
y = z1 + z2^2
z1 = z2 + 3*exp(u)
I have been looking for "creating a folder"-option in my group in Maplecloud. Is this possible at all or can I really only have an hierarchy depth of one?
Best regards,
Al
Since Maple 14 requires a new version of the license manager (which isn't downwards compatible for some reason..), I'm currently trying to figure out how to run two versions of maplelmg on the same Linux host, one for Maple versions 13 and below, one for 14 (and above).
Of course, this would have to happen either on different ports or another IP on the same host, which doesn't really bother me, the problem is that I cannot start two maplelmg's on the same host because...
First 1955 1956 1957 1958 1959 1960 1961 Last Page 1957 of 2431
