Of course the bottleneck is in Maple (may I say as usual, especially when you are trying to innovate).
i) Socket package is not thread safe
ii) Most of the time is spend waiting for Wait(id1, id2) etc
If all the technical Maple stuff was working I could do the below call in around 1 second or less.
Now it takes 7 seconds which is way way to long if you want to download let say 50 symbols...
with(Threads):
X := proc(symb)
  uses Sockets;
Hi.  I am supposed to sketch the set of points in the complex plane defined by
|z+2|<=|z-I|
where <= is less than or equal to and I is the complex number.
By hand, we simply substitute z=x+I*y into the above inequality, expand and simplify to get
y<=-2x-1.5
From here onwards, we sketch the straight line and shade the bottom region of the line.
In more challenging cases rather than getting a straight line, one...
r(t):= <t | t^(2) | (t^(2) )/(2) >
simplify(simplify(PrincipalNormal(r(t), t, normalized), symbolic),symbolic)
diff(r(t),t)
The three lines above are part of a worksheet that computes unit tangent vector, unit normal vector and components of acceleration for a parametric curve r(t) ,  a standard Calc 3 lesson.
I am...
I have one calculation and the result is "Length of output exceeds limit of 1000000"... What can I do with this error?
Thanks a lot.
Hi, I'm trying to use rsolve to solve the difference equaiton: y(n)-3*y(n-1)-4*y(n-2)=delta(n)+2*delta(n-1)  where deta(n) is the discrete delta function represented by charfcn[0](n).  The answer should be y(n)=(-1/5)*(-1)^n+(6/5)*4^n.  I'm getting the answer in terms of y(0) and y(1) and extra terms.  Can someone point me in the right direction?
Thanks for your help
Is it possible to specify tolerances such as +10,-5 instead of just +-10?  In other words, can the high and low limits be different?  Thanks, Ratch
Fsolve solve for numeric when I put X as an parameter in one of the equation it get an error
y1 := 2*a*b^2-b+c-d-1 = X;
y2 := a^4+b^3-b^2+c-d+2 = 0;
y3 := a*b^2-b+c-d-3 = 0;
y4 := a^3*b^2-b+c-d^3+4 = 0;
fsolve({y1, y2, y3, y4},{a,b,c,d})
Error, (in fsolve) X is in the equation, and is not solved for
5) Look at the below code. It takes 7 seconds to make the call to yahoo finance 4 times
sequentially. The strange thing is that it takes the same amount of seconds to do the call
in parrallel....hummm very strange....what is the benefit of using the Task command then ??
I have 4 cores in my machine ie kernelopts(numcpus) returns 4 so it should be very fast.
with(Sockets):
X1 := proc (...
I want to fill a matrix m by m with elements
1) the elements under the diagonal comes from the expression
Gama:=(i, k)→evalf(((x[k]-x[i])*xdot[k]-(y[k]-y[i])*ydot[k])*dtheta[i]/((x[k]-x[i])+(y[k]-y[i])^2))
2) the elements in the diagonal comes from Lambada:=(i)→-sum(Gama, k=1..M), where i<>k
I've tried to install maple 10 in windows vista but it seems imposible the setup keeps saying this.."please wait, maple 10 is being configured for your system, this make take a moment..." i've left my computer on all night but the installation doesn't end...any ideas on how to solve this problem? thank you.
Could you please explain the following:
1) str1 and str2 should be global variables right? I mean so we can call them
after the Create statements....
2) When I execute the below code and then call str1 and str2 I dont get any html output.
The " " are empty.....why?
with(Sockets):
with(Threads):
X1 := proc () local str, sid, b;  global str1;
My question is similar to the one referenced, but a bit more complicated.
Considering a PDE of order n, I would like it to be collected by the order of differentiation.
A simple example:
simplify(( (3+4*x)*diff(f(x), `$`(x, 2)))+(5+4*y+z)*(diff(f(x), x))+(1+r+y)*f(x))
where the idea is to return to the form prior to simplification, including the sort by differentiation order.
After it is simplified, I can get the coeff of only the highest order derivative, as
I want to download historical data from google finance for two Indecies simultaneous
but I dont understand where the output is saved...?!  Also should I use task or threads ?
with(Sockets):
with(Threads):
X1 := proc () local str, sid; global b; str := "";
sid := Open("google.com", 80);
Write(sid, cat("GET /finance/historical?q=INDEXSP:.INX&histperiod=daily HTTP/1.0 \n\n"));
b := Read(sid); while b <> false do str := cat(str, b...
What's wrong?
I need to minimize (z-Z) T.E-1. (z-Z).
How can you see in the first Call to LSSolve worked. By introducing objectivejacobian I have problems
Recently, I submitted for publication to a peer-reviewed math journal
a formula for the n-th order implicit derivative given an implicit function G(z,w)=0.
i.e. dz/dw = - Gw/Gz where Gw and Gz are partial derivatives of G with respect to w and z, respectively. Anyway, I proved the general formula for d^n z/ dw^n.   I have since proved the generalization of this to implicit functions of several variables, G(z,w1,w2,...,w(N))=0. A good mathematician...
First 1961 1962 1963 1964 1965 1966 1967 Last Page 1963 of 2431
