You can   Insert -> Table (and specify the size) manually,
but how do you do that using code then have data go to specified cells?
Whenever I use polynomial fit, its tells me 'Warning: there are zero degrees of freedom' what does this mean?
What is the command in Maple which is equivalent to the command "mod" in Matlab ?
Please help with the use of DEplot3d.
Following is my script, and I kept getting the error tha looks like involving the initial conditions.
> restart;
> with(plots); with(plottools); with(DEtools);
Setup the system of linear DEs:
> sys := [diff(x(t), t) = x(t)+y(t)+2*z(t), diff*(y(t), t) = x(t)+2*y(t)+z(t), diff(z(t), t) = 2*x(t)+y(t)+y(t)];
Setup some intial conditions
> ic1 := [seq([.1*i, .5*i, 0], i = -5 .. 5)];
There is an option box that asks you if you wish to save the calculations for further manipulation when you re-open the worksheet.  Part of the worksheet has downloaded data from a webpage.  However when I re-open the worksheet and try to continue calculations, it's like I'm starting all over again.
There was another mapleprimes post that mentioned you need to use the command save vars as a .m file.  But since this dialogue box comes up, I didn't...
i have a maple 14 but when i plot a function i obtain large value of legend which is not suitable when i used this plot of function. i try to used the code " font = ["HELVETICA", "ROMAN", 8],this code it work.
but the code that used to change the size of legend is not work. the code is :
legendstyle = [font = ["HELVETICA", 9], location = right]);
can you please help in this problem?
Is is possible to read an image into maple located at an http location?
I notice that the new format of Maple Primes is completely changed. I cannot find the usual login point of entry.
Also, the search feature in Maple is not able to find matches for more than one word.
e.g. I can enter only ONE of the words "solve" "differential" "numerical" into Maple's search engine. Otherwise, no matches found.
I see dsolve, but a search comes up with nothing for numerically solving the nonlinear system that I have.
Hello, does soomeone knows how to calculate:
∫ BesselJ(ε, η x) x^n dx
∫ BesselY(ε, η x) x^n dx
and/or
∫ BesselJ(ε, η x) x exp(-a x) dx
∫ BesselY(ε, η x) x exp(-a x) dx
ε and n are positive integers
a is a positive non-integer
η is a positive non-integer imaginary number
Thanks!!
I want to solve this Problem
Symbolic_Matrix.pdf
 in symbolic by maple, but i can`t.
is there any symbolic solution by maple or not,
if there is another solution please help me.
When maples calculates Riemenn or Ricci tensor it displays the result in a notation which takes many lines or even pages. Can one replace derivatives with respect to x, y and z as fx, fy, fz instead of what is given by diff(f(x,y,z),x) etc.  and denote partial derivative with respect to t as just a dot. ( I know that maple can use dot to denote total derivative but I want it to denote partial derivative). and Can one write f(t,x,y,z) simply as f. These are...
is it possible to feed maple with the input parameters and the results and get maple to find the governing equation?
Is this the simplest way to add one line of an array to another array?
a:=array(1..10,1..10):
b:=array(1..10,[1,2,3,4,5,6,7,8,9,8]):
for i from 1 to 10 do
    a[1,i]:=b[i]:
or to use with(ArrayTools):
for i from 1 to NumElems(b) do
    a[1,i]:=b[i]:
Can the command map be used here?
I'm working on a school problem and I came across a little problem which I can't figure the solution by hand, so I'm resourcing to maple for this. I have this problem: solve by variation of parameters y"+9y=sinh(2x)
I can do the wronskian and everything fine up to the integration part, which is: integral[(-1/3)sinh(2x)sin(3x),x]
I found the integration step by step of maple
Student[Calculus1][IntTutor]();
but it can't solve this problem, is there...
Several years ago I was using very nicely the classical worsheet of maple10.0.
Now, I installed Maple 14, but I dont find one environment similar to the nice "classical worksheet" of maple10.
How may I use Maple 14  to have something closer to the classical worksheet of maple 10?
Thanks in advance,
Jean-Jacques
First 1969 1970 1971 1972 1973 1974 1975 Last Page 1971 of 2431
