I would like to know how to plot different series of data on the same graph.
Thanks in Advance
hi all
in maplenet after next link  "/maplenet/imaging/image?maple=Histogram([1,2])"
i do not see image of Histogram, just image of formula 'Histogram([1,2])' , what need for generate image?
I'm trying to hide all text created in text mode (F5) so that all I see are the calculations or text typed in Math mode.  How do I do that?
I could create subsections with text but that's bulky.  I've tried document blocks but that only hides the calculations, the opposite of what I wanted.  Have I missed something?
I have a grafic, a power curve, and a few values of the curve.
The values are in 0.5 steps. I would like to calculate the values for all the 0.1 steps.
For example:
I know the values for 4, 4.5, 5 etc. and would like to find out the values for 4.1, 4.2, 4.3 etc.
Is this possible using Maple?
Best regards,
Calin
When I plot csc(k*x) for various values of k, the timing varies considerably depending on the value of k.
Here are the timings for k = 1..5 (note the strange case of k = 3):
  seq(time(plot(csc(k*x), x = 0 .. 2*Pi, -3 .. 3, discont = true)), k = 1 .. 5);
               0.031, 0.031, 14.133, 0.046, 0.062
For k = 6, the time is apalling:
I was wondering if anyone has any experience with conic optimization (ie Mosek)
to solve large scale portfolio optimization problems. It all seem so complicated.
It should be possible to call such an optimization engine from Maple right?!
I'm looking for this application : "A Double Pendulum Model using DynaFlexPro and Maple"
Does anyone have it ?
Indeed,it's no more on this site : http://www.maplesoft.com/applications/view.aspx?SID=1682
I really need to make a simulation of the motion of a double pendulum, using Maple.
After I have opened internet explorer with Maple
process[launch]("C:/Program Files/Internet Explorer/iexplore.exe")
what command do I use to close it with maple?
 hi
I want to solve this problem
Symbolic_Matrix.pdf
with that code
sumbolic_matrix.mw
hi
I have got an eq: Curl(A)=B;
Both A and B are vectors,  for example,
A(x,y,z):=Ax(x,y,z) _i+Ay(x,y,z) _j+Az(x,y,z) _k;
B(x,y,z):=Bx(x,y,z) _i+By(x,y,z) _j+Bz(x,y,z) _k;
can I get A as a funtion of B? if I can, how to deal with it, and if not, what other known conditions should be added to solve it?
any help would be appreciated@。@
I have the following data file
1.1    0.751    0
1.5    0.764    0.419
2       0.777    0.665
2.5    0.796    0.791
2.71   0.81     0.81
and I want to plot the 2nd column vs the 1st and the 3rd vs the 1st on 1 axis, with the 1st column on the x axis.
Is...
I just purchased the personal edition of Maple 14. It was working just fine for 3 or 4 days but now the java interface is distored. Even hovering the mouse over the palettes or images causes distortions. I've uninstalled and reinstalled several times but it hasn't worked.
Has anybody else encountered this? Does anybody have a solution?
 I have a problem in programming with maple if statement:
 restart;Qs:=24; p:=20; m:=3; q:=Qs/(2*p*m); if (q=1) then
> yc:=Qs/(2*p); elif (frem(q,1)~=0) then if (evalf(Qs/(2*p))<1) then
> yc:=1; else yc:=floor(Qs/(2*p)); end if; else yc:=round(0.8*Qs/(2*p)); end if;
The result is yc:=0; the result must be yc:=1;
 In Matlab:
Hello all,
I'm a new user, hopefully you can assist me as I have work on this problem for quite sometime, I keep getting error of Error, (in dsolve/numeric/bvp/convertsys) unable to convert to an explicit first-order system
I copy my work here. If anyone need the original worksheet I can send this immadiately. Please help and I would like to say Thank you.
R:= 8.31434;             ...
Compare the results of isdifferentiable on 3 piecewise defined expressions f, g, and h.
The first time the order of the asking is f, g, h. The second time (after a restart) the order is h,g,f.
The results are remarkably different! What is going on?
isdifferentiable was first brought to my attention within the last week or so, maybe it is not reliable?
If you remove all the lines with 'assuming' then the inconsistency remains.
First 1968 1969 1970 1971 1972 1973 1974 Last Page 1970 of 2431
