Hi! We just got the new Maple 14 and I'm having problem creating the resource file by using this command: "Maple14WindowsInstaller.exe -r". My steps are that I want Maple 14 to be the default application, no shortcut on the desktop and we are using a network server for our licenses. But, each time it gets to the installing part and seems to do nothing at all! In fact, once I let the installer run for 2 hours and it didn't installs anything. In other words, I can't create a resource file. I tried to run it on VMware workstation using Windows XP Pro SP3 French Edition, tried to run it on a normal computer running Windows XP Pro SP3 French Edition, etc. without any success. So any help will be greatly appreciated!
Thanks in advance for any help!
I have a set of points and 2 questions
Each point has different values associated with them.  I want each value of the points to be displayed as a specific symbolsize.  The only way I could figure out how to do that was to create a list of the points of one value and set it at a specific size, for example like this.
Suppose pointset a has value 1
a:=[[1,2],[3,4],[5,6],[4,4]]
and suppose pointset b has value 2
b:=[[2,2],[3,3],[4,4],[2,3]]
I think the only way to do what I want is this
I'm running OSX and Maple 14. Now when I do ]>? mod for example it (maple) is launching a Maplet (which crashes) in order to do something (perhaps bring up a Java version of the docs?). How do I disable this and get the old (text based) man pages back?
how can i solve two coupled differential equations like these: s1 := diff(n[D](t), t) = a-b*n[D](t)^2-c*n[D](t)-e*n[D](t)*n[T](t); s2 := diff(n[T](t), t) = b*n[D](t)^2-c*n[D](t)-e*n[D](t)*n[T](t); why dsolve({s1, s2,n[T](0)=0}) gives error?
Thank you to help with the Fourrier serie of:
 f:=t->piecewise((-tp/2<=t and t<-b[0]/(2*Rs),0),(-b[0]/(2*Rs)<=t and t<=b[0]/(2*Rs),ix/b[0]),(b[0]/(2*Rs)<t and t<ty-b[0]/(2*Rs),0),(ty-b[0]/(2*Rs)<=t and t<=ty+b[0]/(2*Rs),-ix/b[0]),(ty+b[0]/(2*Rs)<t and t<=ty+tp/2,0));
ix:=10: Rs:=73.0e-3: b[0]:=Rs*4*Pi/180: b[t]:=Rs*6*Pi/180: ty:=10*Pi/180: tp:=10*Pi/180: plot(f(t),t=-tp/2..ty+tp/2,title=`signal to analyze`);
Hi there, Here is my problem : I'm trying to represent ( and animate ) the surface of a vibrating circular drum using plot3d. Let O be the center of the drum, the function "u" I found gives the height (z) of a point on the drum located at a distance r from O at t ( time ) in cylindrical coordinates ( u does not depend on theta). So what I'm basically trying to do is to plot the surface given by the equation z = u(r,t). So far I've failed to do so using plot3d. Could someone here help me with this ? Any help will be greatly appreciated ! Thank you. Tiilt
I have got two columns of data X and Y. if i know the data would possibly fit a function with form : y=ax^n+bx+c, how could i extract the values of a, b and n? Also, how to get the R squared value for the curve fitting.
I use D[ ] to get partial derivatives,
as follows,I donot know is it right?
w := proc (x, y) options operator, arrow; A*(x^4-2*L*x^3+L^3*x)*sin(n*y/R) end proc
t4 := (D[`$`(1, 4)](w))(x, y)+2*(D[`$`(1, 2), `$`(2, 2)](w))(x, y)+(D[`$`(2, 4)](w))(x, y)
If we have three coins. Then the probability of getting three heads or three tails is:
0.5^3 + 0.5^3 = 0.25
Now, what is the probability of getting three heads or three tails when the three
coins are correlated with correlation coefficient p ??
Maple carries digits through based on the digits or precision you have preset.  Is the calculation slowed down any if you have 7 trailing 0's as opposed to 100 trailing 0's?
Hello, I just wanted to do a physics problem with Maple 10 and entered m := … to have the mass at my fingertips during the problem. But when I entered a speed it interpreted the "m" from meter as my "m" which I used as mass: I got around the problem by using the word "mass" instead of "m". Am I just doing it wrong by using too simple names, or is there something I can do in maple to prevent this? Thanks!
i want someone to help me with this intergration w := (int(K/(y-y1), y = -s .. s))/(4*Pi) he want to know if y1 is between s and -s ,while y1 really exist between s and -s thanks
a:=["34mt5","tru532","64E22N"]
I thought this command worked on Lists.
Select(HasDigit,a)
    Error, (in StringTools:-Select) second argument must be a string
So then I thought maybe map might work
map(HasDigit,b)
     [true,true,true]
okay closer.
Select(map(HasDigit, c), c)
Can't figure out how to get around that string problem
I noticed that if I use add instead on using an integral int I dont get the same value. why ??
E := 7:   p := .5:
add(p^n*2^(n-1), n = 1 .. E)-p^E*add(2^(n-1), n = 1 .. E);
evalf(int(p^n*2^(n-1), n = 1 .. E)-p^E*(int(2^(n-1), n = 1 .. E)), 5);
                                  2.5078
First 1999 2000 2001 2002 2003 2004 2005 Last Page 2001 of 2431
