What Mapple code for ploting these ten functions ?
Plot these functions. I need urgwent help with these functions :
A=\sum_{n=[1,infinity]}(3n^{2}+7n+1)^{-n}
B=\sum_{n=[1,infinity]}(-1)^{n}(3n^{2}+7n-1)/(3n^{5}+4n+1)
C=\sum_{n=[1,infinity]}(-1)^{n}(n^{2}+n-1)/(3n^{2}+n)
D=\sum_{n=[1,infinity]}sin((phi/2n)+n(phi))
IF n is uneven E=\sum_{n=[1,infinity]}a=(2/n)
IF n is nevenF=\sum_{n=[1,infinity]}a=(-1/n)
G=\sum_{n=[1,infinity]}(n^{-4)}
H=\sum_{n=[1,100]}(1/3)n^{-3}+\sum_{n=[1,100]}n^{-4}
1. For n = 5 plot I=\int e^{\frac{1}{(1+exp((n(2-x))}}
I have encountered difficulties with an optimization problem to be solved with NLPSolve. I want to minimize the integral of a parametrized function. However, when I call NLPSolve it seems that the integration variable of the int-command gets replaced for some reason I don't understand. A piece of code is quoted below. Does anybody see what I am doing wrong? Any hint will be appreciated.
First of all, I use Maple 14.
I tried to generate N samples from a defined normal distribution and then let Maple calculate sample mean, sample standard deviation and a statistic Z for each of the i samples:
with(statistics):
N:=100:
n:=100:
X:=RandomVariable(Normal(500,50));
for i to N do
X||i:=Sample(X,n):
mu||i:=1/n*sum(X||i(1,j),j=1..n):
sigma||i:=sqrt(1/(n-1)*sum(((X||i(1,j)-mu||i))^(2),j=1..n)):
Z||i:=(mu||i-500)*sqrt(n)/sigma||i:
Hello Everyone,
i try to solve a function for zero (numerically) that contains the cdf of the binomial distribution, but i can't get i work. Maple (13) simply returns the equation without any solution.... Or strikes because of the non-algebraic content...
Let p(x,t) describe a probability for a binary event. Let Bcdf(z-2,n,p(x,t)) denote the binomial cdf such that the probability that this event happens at least z  out of n times, where z and n  are integers.
I want to compute:
I have the following maple code: restart:with(Statistics):with(plots): X := RandomVariable(NonCentralFRatio(nu, omega, delta)); nu:=3;omega:=3*n; delta:=4/(2*100)*(2.5^2+1.5^2+3.5^2+4.5^2); I then want to try and solve: fsolve(CDF(X,100)=0.9,n); but I get the error: Error, (in fsolve/checkrange) cannot determine if this expression is true or false: 1.*abs(Re(_t))+1.*abs(Im(_t))
I was reading about Thomas M. Cover Universal portfolios.
earthchangesmedia.com/breaking/April2000/0418universal.htm
One of the contributing factors seem to be related to exponential growth.
Two sentences caughts my eye:
"With the universal portfolio algorithm, profits grows exponentially.
The average of exponential growth rates has the same growth rate as the maximum"
Testing a numerical implementation I want to access data, which are
suggested as maximal errors through plotting (with care) to examine
that in more detail (so plotting is considered just a help)
For univariate functions I am aware how to look into data pairs for
the command plot.
My function is bivariate and real valued.
P:= plot3d( f(x,y), ...) lets me save the result and
  op(P);
  op(1,P);
  arr:=op(3, %);
  arr; Arr:=convert(%, Matrix);
  plots[matrixplot](Arr, axes=boxed);
hi im trying to do a pretty simple 2 eq system
and i get
> e1 := 1.74*10^(-15) = D*exp(-Q/(8.31*1473));
> e2 := 7.1*10^(-15) = D*exp(-Q/(8.31*1573));
> solve({e1, e2}, {D, Q});
any help will be appreciated
In a previous thread here I was looking at working with a noncentral F distribution. I have since found out what I need to be doing is a bit different.
The theory is as follows:
So, The F(1-alpha, nu1,nu2) is actually a Quantile value of the central F distribution. In my case, I'm trying to find a minimum sample size where nu1=3 and nu2=3*n. I transform the Power Equation into a function of into a cumulative distribution question using the formula P(A>B)=1-P(A<=B).
I am trying to plot a 3d function, but there is a problem.
Here is a screenshot of the problem img130.imageshack.us/img130/6008/3dplotproblem.jpg
thank you
Hello everybody, please help me. I have a system of PDEs and I can't solve it. I have an error as:
"Error, (in pdsolve/numeric/par_hyp) Incorrect number of initial conditions, expected 3, got 2"
I want to obtain the exact (symbolic) solution of
240*t^3 + 144*t^2 - 135*t -52 =0
in the form  a+ b*I, where a, b are (symbolic) real numbers.
It is possible if I understand Wikipedia well.
"solve" gives "RootOf" and the "convert(......, radical)"  gives quantities such as
(9522 + 45*I* squarerootsymbol(226511))^(1/3)
Sorry for posting the question to two topics (here and there http://www.mapleprimes.com/forum/ihaveequationafterdsolvehowcaniuseonlyonepartitseewhensolutionbecomesequalsmth)
But it seems to me that it fits both of them.
________________
I have a differential equation.
ODE := diff(diff(x(t), t), t)+.2*(diff(x(t), t))-x(t) = sin(t)
ics := x(0) = .5, (D(x))(0) = 5
X1 := dsolve({ODE, ics})
So the solution is:
So the solution is:
X1 := x(t) = exp((1/10*(-1+sqrt(101)))*t)*((111/404)*sqrt(101)+111/404)+exp(-(1/10*(1+sqrt(101)))*t)*(111/404-(111/404)*sqrt(101))-(5/101)*cos(t)-(50/101)*sin(t)
Now I need to find out when the solution becomes equal to 1.
But Maple of course does not understand when I write
Hi all
I'm having trouble with Maple and cancelling fractions properly. I will demonstrate. As you can see the method using sub and fractions doesn't work whilst directly copying it into a stacked fraction does. I can see that it must be to do with which fraction is the main one (largest bar) but if I put in my variables like they appear it changes and thus doesn't cancel properly.
I have also include the maple file with the actual problem in context if that helps.
Any help would be much appreciated.
First 2002 2003 2004 2005 2006 2007 2008 Last Page 2004 of 2431
