Given an expression is there a easy way to convert occurrencies of diff, int, limit, product, sum to their intert forms? For diff one can use convert(%,D), but for int and sum it is not the right way. Are there other ways instead of using "subs(sum=Sum,%)" etc ?
I observe that within graphics numbers are displayed according to local settings (so 0,001 stands for 1/1000) - no problem for me, but annoying, actual output displays with a point as decimal separator. For pretty display I sometimes use something as 'eval(expr, x=1)': '%'=% which works fine in mws, but in mw it displays the eval statement - is there a workaround for both kinds of sheets? And saving a mws as mw does not respect the font size for 2D output (it changes mine from 10 to 12 (and behaves odd, it always uses italics, but we had that already i think). (Win XP home SP2,
I'm trying to animate a group of spheres moving randomly in a box but am having difficulty getting the axes to show up. Specifically i want to be able to export as a GIF, for use in a presentation but when I insert a static set of axes with an arbitrary empty bit of a plot it won't let me export. I can define a set of axes as below, but i can't seem to control the size. Any ideas how to define the axes size in the following bit of maple for one sphere?
Thanks greatly in advance.
> restart;with(plots): with(plottools):with(linalg):with(stats):
> x10:=10:y10:=10:z10:=10:
> ball1 := sphere( [x10,y10,z10], grid=[10,10],axes=normal,color=blue):
i WANT TO DEVELOP A MICROCONTROLLER BASED PID TEMPERATURE CONTROLLER.THE USER WILL SET THE DESIRED TEMPERATURE THROUGH KEYBOARD.I WILL BE USING A TEMPERATURE SENSOR(IC LM35DZ) WHICH WILL BE INPUT TO MICROCONTROLLER 8051 WHICH WILL IMPLEMENT PID ALGORITHM TO CONTROL A RELAY AND HENCE EITHER TURN ON A HEATER OR A COOLER.AN LCD WILL ALSO BE INTERFACED TO DIPLAY THE SET TEMPERATURE AND ACTUAL TEMPERATURE. I DO NOT KNOW THE C CODE FOR THIS.IF ANYONE HAS WORKED ON SUCH KIND OF SYSTEM ,THEN PLEASE SEND ME THE CODE.I WILL BE REALLY VERY GREATFUL.
When I have defined a function and a matrix f(x) A[2000,1] The matrix consists only of numbers; no variables. Is is possible to use the function on the matrix and thus get a new matrix where all the entries are the transformed values? - Kasper
I've noticed that if I'm not connected to the internet and load a worksheet in Maple-11 document mode, it more often than not loads with question marks on some of the lines. It never happens when I'm connected to the internet. Is there some kind of connectivity between Maple-11 and the internet? If anyone else can try this, please do and let me know what happens. I discovered it when I was working on my cable modem and wasn't connected for a while and was loading various worksheets in maple and began seeing the question marks. Then when I plugged the cable back in they stopped showing up.
Thanks to J. Tarr, Georgios Kokovidis and others I got my dataset imported into Maple as a matrix. After having done some computations on it, I would like to export it again to an Excel file. Is this possible? - Kasper
I would like to calculate int( (1/4)*x^3*BesselY(0,x)*BesselK(0,x),x=0..infinity); In an article authors say it is 1/(2*pi). Could help me anybody? Sandor
I'm taking a Maple course and I cannot figure out how to convert from a number to binary (without using the convert(#,binary)). So far I have toBinary:= proc(x::posint) local n, k; n:=x; k:=0; while n > 0 do k:= and I'm not sure where to go from here. I know that I need to find the remainders and decrease my n and then put it into a list and then concatinate in the reverse order. Can someone help me out? Thanks Rachel
Can Maple import a bitmap and then use it in a plot? If it can, can the orientation of the bitmap be changed in the plot? It would be much quicker and would look nicer than using the internal drawing facilities.
Dear Comrades, I'm trying to solve a system of coupled integral equations. Does anybody know how to use IntSolve? And what's the shared library? Do I have to download IntSolve from somewhere? And is this the best way to spolve integral equations if I did? Regards, Andrew
Hello, I know it is possible to catch errors using traperror and lasterror... But is it possible to also catch warnings in any way? It seems they are only messages that are printed on the screen. So, using OpenMaple/C, they can be extracted from the textCallBack stream (using id 5)... but is this also possible in the Maple environment itself, and if so, how? -- Regards, Franky.
New info on the "label=" question. I open a new work sheet and enter solve({x^2-y^2=y,2*x*y*=x}). The answer returned includes RootOf(_Z^2-3, label=_L2). Then I copy and paste that solve command after the next prompt and solve the same exact problem again. This time I get the same exact answers EXCEPT that the label is now _L5 and if I solve the same exact problem a third time I get a third label. I can only conclude that the label has nothing to do with the solutions to the problem. This makes me wonder what then is the purpose of a label? Why is it returned? What significance should one attach to it? I don't want to get bogged down about what the spec says or whether this is a bug.
I would like to import a big dataset in Maple and this is giving me some difficulties. Although Maple does have an Importdata-command, I can't figure out exactly how it works. The dataset I want to import is an excel file consisting of 2000 observations with 7 variables. Can this be done and made usefull in Maple, or do I really have to sit down and learn SAS..?
View 285_maple11introductoryprogrammingguideexercise1.6.mw on MapleNet or Download 285_maple11introductoryprogrammingguideexercise1.6.mw
View file details I'm going through the introductory programming guide for maple 11, and I recently worked on some exercises. Instead of just computing, I tried to create a procedure for the first exercise of exercise set 1.6 on page 21.
First 2326 2327 2328 2329 2330 2331 2332 Last Page 2328 of 2430
