help! i want to know what is the syntax and the semantic definition method of MAPLE?
Hi does it happen to you that when you evaluate an expression in maple or maplet you get this message,"Evaluate_result"? What this really mean?
The help page for StringTools:-FormatTime states that the %Z specifier returns the time zone, if available. On my system (linux), it just returns the string "???". For example,
 StringTools:-FormatTime("%Z");
Is there a way to get this to work?
Maple looks quite powerful, but I'm a little confused as to plotting a simple graph such as plotting these 3 data points: 43.69 Apr 08 2004 10:41:45 PDT 40 Apr 07 2004 22:48:47 PDT 32.5 Apr 06 2004 06:13:30 PDT That is, some number vs. a time of day. Thanks very much for any help. - H.
Does anyone know if there is a way to create/display nested piecewise functions in maple? I want a piecewise function where the conditions are themselves piecewise functions. Is that even possible?
After analysing a sketch I came up with two equations describing the sketch.
My first equation looks like: eq1 := tan(X/2) = Vt/Hr;
My second equation looks like: eq2 := tan(X) = (V-Vt)/Hl;
I know the values for Hr, Hl, V so I am left with two unknown values which is angle X and distance Vt.
I have typed these equations in Maple 8 and when I substitute the values Hr, Hl, V then Maple does come up with the correct solution to either angle X or distance Vt. My problem is that I do not want the specific answer to this problem. I need a general answer. That means I want an equation where I can put in any legal values for Hr, Hl, V and then the equation will calculate either Vt or X for me.
Is is possible to add comments in Maple code without gyrating through the LanguageDefinition? Below is a sample that shows an embedded comment - it would be nice if this were possible.
fn := proc(n)
  local x;
  # here's my math
  x := n + n;
C(fn);
int fn(int n)
 // here's my math
 x = n + n;
 return x;
I'm trying to create a piecewise function with vectors instead of constants. So far I have
vf := 3*vx[1] < [6, 1] and vx[1] < [-2, 5], [3, 4]+3*vx[1], 2*vx[1] < [8, -4] and -vx[1] < [2, -5], [1, 9]+2*vx[1], -3*vx[1] < [-6, -1] and -2*vx[1] < [-8, 4], [9, 5]
This won't convert to a piecewise function. However, if the vectors are in the form (1,2) instead of [1,2] (ie. with parentheses instead of braces), it works. Is there any way to convert them at this stage or earlier, when I have then as individual functions (for example: 3*vx[1] < [6, 1])?
Thanks for the help,
Am
Hi Friends My name is Sayed Hoseini and I am PhD student in University of Wollongong. Could you please have a look on this problem and let me know about any package/s which might be used for solving that? I came across to this problem in my research: We have a linear system including two differential equations and two variables; For example consider the following system: L*U=H Where: [diff(,x$2)+I*w q ] L=[ ] [q diff(,x$2)- I*w] and [u(x)] U=[ ] [v(x)] that u and v are functions of x and w, q and H are functions of x too, but fixed and I is the complex argument .
Looking for faster ways to make chi^2 nonlinear fit calculations, for functions involving integrals, I have compared timings of calculation of chi^2 at a pair of sample points evaluating the integrals by three numerical methods. In the attached worksheet they are called as follows: 1. chin, using evalf(Int(...)) 2. chin2, using the interpolant option (`dsolve/numeric`(sys, range=...)) 3. chin3, using evalf(Int(...,method=_d01ajc)) I have obtained timings with Maple 9.5 using first a Celeron 333 MHz under RH7.1 and then a P4 1.8 GHz under Win XP. My expectation was that the method of the interpolant function were the
How do I create a shared library for use with the define_external command?
In the examples,ExternalCalling help page the following command is used.
> ssystem("cl test1.c -Fetest1.dll -Gz -link -dll -export:f1"):
But this assumes the Microsoft Visual C/C++ compiler.
I want to use the new Watcom compiler included in Maple 10 for Windows.
Bob.
I'm wondering if a Maple guru would comment on the behavior of Implied Multiplication. I was working through an exercise with Maple and ran into the following behavior. Initially I had this: limit(sum(3((1+3*i/n)^3-2(1+3*i/n))/n, i = 0 .. n), n = infinity) = 231/4 which didn't look right since I expected a different result. Ater messing about I tried looking at the operators and when I did this: limit(sum(3((1+3*i/n)^3-(2)*(1+3i/n))/n, i = 0 .. n), n = infinity) = 195/4 I got the answer I expected to see. [note that Maple Primes has distributed the 2 inside the brackets above. In my document it is 2*(1+3/n)]
When using the FunctionChart call from Student[Calculus1] I keep running into a strange problem. As soon as I attempt to change the display size with the view=[x1..x2,y1..y2] option I get a tiny little graph that is no larger than an ordinary icon. Does anyone have a work around for this? As an example this misbehaves on my Maple 10 install: with(Student[Calculus1]) with(Plots) FunctionChart(x^2, x, view = [-2 .. 2, 0 .. 9]) Tim
In the Help section under procedures (or proc) it states:
argseq - the formal parameter names
I just wondered about the use of the word 'formal'.
eg in this simple Maple code
maxim:=proc (a,b,c,d)
max(a,b)+max(c,d)
maxim(2,3,5,4);
. . . the formal parameters are a, b, c, d. Is the word 'formal
' being used as "officially recognised" and a=2, b=3 etc. (ie the
order is important or is there
some deeper meaning? I'd appreciate a short example of a proc using
something else besides variable values, or Null.
David
Ok, I have the following equations: c'[t] = a[t]*b[t]*k1 - c[t]*k2, a'[t] = (-a[t])*b[t]*k1 + c[t]*k2, b'[t] = (-a[t])*b[t]*k1 + c[t]*k2, c[0] =0, a[0] =10, b[0] =10. I have data for concentration of "c" at all time intervals from 0-16. Here is the data: {0, 0}, {1, 4.98112}, {2, 6.61986}, {3, 7.42423}, {4,7.89529}, {5, 8.20004}, {6, 8.41008}, {7, 8.56123}, {8,8.67342}, {9, 8.7586}, {10, 8.82442}, {11, 8.87595}, {12, 8.91671}, {13, 8.94923}, {14, 8.97535}, {15, 8.99643}, {16, 9.01351}. I need Maple to Solve the ODE's and optimize the values for k1 and k2 to fit the data usins a least-square method or something along the lins of that. Can someone send me the code for that?
First 2425 2426 2427 2428 2429 Page 2427 of 2429
