Hi everyone
I am trying to get the maximum value (angle) for a function, which is a solution from a ODE. I tried evalf(max.. which I already thaught wouldnt work.
After that I installed the package "DirectSearch", again with no success.
Does anybody know what I am doing wrong or how I am going to get the maximum. I added the maple file with the direct seach attempt.
Thank you in advance!
Please how  can I use getdata to extract only 200x2 of 208x2 matrix from maple to excel.
For instance I have:
Q:= ( seq( seq( plottools:-getdata(ans1[s1,3])[j,3],j=1..3), s1=1));
It returns  208x2,  200x2 200x2 matrices and I can't extract it using
`<|>`( seq( seq( plottools:-getdata(ans1[s1,3])[j,3],j=1..3), s1=1));
because the matrices have different dimension. Please, how can make 208x2 matrix to 200x2?
I am trying to figure out the width-at-half-maximum for a speical case of the difference of Guaussians.  In this scenario, I start with a standard formula for a Gaussian:
f(x, x0, S, Gmax) = -Gmax*(exp(S*(x - x0)^2*(-1/2)) - 1)*heaviside(x - x0)
where x0, is the location of the peak, S is the spread, and Gmax is the amplitude.  However, then I take a difference of two, assuming that x0 is 0 for both, that Gmax is unity for both, and the only thing free to vary between them is the spread.
fDOG(x, S_a, S_d) = f(x, 0, S_a, 1) - f(x, 0, S_d, 1)
Here I also assume that S_a > S_d, and that all values (including x) are real positive numbers.  In this case, I (believe) I always get a peak function that rises from y = 0 at x = 0 to some peak, and then falls back to y = 0 at infinity.
Differentiating fDOG and solving for y = 0, I can find the time of the peak of this function:
tpeak(S_a, S_d) = (sqrt(2)*sqrt(ln(S_a/S_d))/sqrt(S_a - S_d))
I can then find the amplitude at the peak by substituting tpeak for x in fDOG. However, what I would like to do now is is find the (two) points on x where y = fDOG(tpeak, S_a, S_d)/2.  Is this possible?
The goal here is to verify if the solution found by Maple is valid for the submitted ODE or not. Following the usual, 'odetest' and simply plugging the solution provided by Maple into the submitted ODE did not inspire confidence, so I am writing to see where I went wrong. The steps which were followed...
Equation := 2/(3*int(diff(y(x), x)*x^2/(x^2 - 1), x)^(3/2))
            + int(sqrt(2)*sqrt(y(x)), x) = 0:
ImpliciteSol := simplify(expand(dsolve(Equation)[1]));
     1/16*(-9*y(x)*(-y(x)*x^2)^(1/3)*6^(2/3)*x^2+16*_C1*x^(8/3)-24*x^2+6)/x^(8/3) = 0
yofx := simplify(expand(isolate(ImpliciteSol[1], y(x)))); # does not succeed
    (1/16*(-9*y(x)*(-y(x)*x^2)^(1/3)*6^(2/3)*x^2+16*_C1*x^(8/3)-24*x^2+6)/x^(8/3) = 0)[1] = 0
I'd like to know that why in the attachment "fsolve" does not work?
How can I evaluate the value of "A" in my file?
Many thanks in advance
N := 60: L := 10: a := 2*10^(-12):
eqn:=ns=1-((((N/A)+((A*L)^(L/(1-L))))^((1-L)/L))/(A*L))*(2+(a*exp((((N/A)+((A*L)^(L/(1-L)))))^(1/L)))/((A*L*(((N/A)+((A*L)^(L/(1-L))))^((L-1)/L)))+((a*exp((((N/A)+((A*L)^(L/(1-L)))))^(1/L)))))):
seq(fsolve(eqn,A),ns=[0.9603,0.9647,0.9691]):
Download A.mw
Hello everybody!
Im working on my great great (not great at all.. ) Dutch math book. Im really considering getting a copy of "Advanced Engineering Mathematics, by Robert Lopez". But hey, i worked through the first book, and now im at the half of the other second book. So i will finish it.
They left me with no clue on how to get the deal done, that is what is so perfect about this book i guess (i did a lot of books, but these Dutch books, yeah they do me like that) they will leave you in the dark, while they get all the grandeur because they know how to get it done, and you as the reader, well as a first timer, dont know how. Ive talked to a lot of students about this book. Yes it sucks. Classes full of students did agree on that, the majority did. So yeah, im trying to get a book delivered from the university library to a university libary closer to me, so i can get the book that does have good reviews.
The things i did learn from the Dutch math book did work great in statics and mechanics. That made short work of all the questions like a hot knife through butter.
THE ACTUAL QUESTION:
I cant prove this, because i dont know how. The translation says: a. Prove that the inverse of A exists for all values of p.
b. Determine the inverse of A
My take on it thusfar:
#Opdracht 9
#a.
with(LinearAlgebra)
A := `<,>`(`<|>`(1, 1, 1, 1), `<|>`(p, p+2, p+3, p+4), `<|>`(p^2, (p+2)^2, (p+3)^2, (p+4)^2), `<|>`(p^3, (p+2)^3, (p+3)^3, (p+4)^3))
Matrix(%id = 18446747008253355422)
#b.
B := MatrixInverse(A)
Matrix(%id = 18446747008306226350)
Greetings,
The Function
Download Mapleprimes_Question_Book_2_Paragraph_4.4_Question_9a.mw
Hi, please how do I delete only the 0*I of the complex expression: 0.*I - 3?
I tried this:  remove(`=`, [0.*I-3, 5, 7, -2], 0.*I);
But couldn't work.
I want to replace   expression that contains function whose first argument is always R0 with r0.
I can do it when the function is  f(R0) or f(R0,x) but I do not know how to tell Maple to do the replacement of the first argument, if the function has 0 or more arguments beyond R0.  This is what I tried
#this works
expr:=A+f(R0);
evalindets(expr, 'anyfunc(identical(R0))', Z-> subsop(1 = r0, Z ));
A+f(R0)
A+f(r0)
#this also works, when there is one argument after R0
expr:=A+f(R0,x);
evalindets(expr, 'anyfunc(identical(R0),anything)', Z-> subsop(1 = r0, Z ));
A+f(R0, x)
A+f(r0, x)
#but how to do it for any number of arguments after R0? This does not work
expr:=A+f(R0,x,y);
A+f(R0, x, y)
A+f(R0, x, y)
#I do not want to keep adding anything to match the number of argument, as I do not know how many there could be
expr:=A+f(R0,x,y);
evalindets(expr, 'anyfunc(identical(R0),anything,anything)', Z-> subsop(1 = r0, Z ));
A+f(R0, x, y)
A+f(r0, x, y)
Download oct_11_2022_anyfunc.mw
I do not want to keep writing anything,anything,anything, for as many times as there could be more arguments.  I wan to say something like
evalindets(expr, 'anyfunc(identical(R0),anything_zero_or_more_arguments)', Z-> subsop(1 = r0, Z ));
Is there a better way to do this whole thing than what I am doing?
Update
Just after I posted this question, I found another structured type that worked
expr:=A+f(R0,x,y,z,h);
evalindets(expr, 'patfunc(identical(R0),anything)', Z-> subsop(1 = r0, Z ));
So patfunc works for zero or more argument after R0, which is what I wanted.
Given that types are core part of Maple, I find it so amazing that the help page "Definition of a Structured Type in Maple"  has so little examples and description of all these types in it. I can't figure what 80% of the types there do, since there are no examples.
Maplesoft should really do a better job on this page and add much much more examples and description. After all, strong typing is what is supposed to be the strength of Maple. But looking at this help page, it does not give one this impression at all.
I would like to determine the minimal degree polynomial with rational coefficients where alpha =2^(1/2) + 2^(1/3) is a root of this polynomail, is this possible using MAPLE
After I refer to the Mersenne prime number table, I found the following result
5, 31, the number of digits is too large to be determined
13, 8191
17, 131071
19, 524287
If the following elements all yield composite numbers
So:
2, 3, 7, 127
The length of the sequence with only 2 only generators reaches 4.
Due to its particularity, it is guessed whether 2^(2^127-1)-1 is also a prime number,
and whether the sequence with 2 as the generator is an infinite sequence of prime numbers Woolen cloth?
Then perfect numbers are also infinite.
I inadvertently discovered that the save command (and probably read, write, export and import commands too?) returns an error (something like "can't write ...") when the file length is too large (265 in my case).
Is this documented somewhere?
Is there a way to exceed this limit?
Assuming D=".../" and F="xxx.m", can we set the path of the directory D to some value and then use save something, F instead of save something cat(D, F) ?
I have a matrix and generate difference tables from it's diagonals. Works fine. Then I make a polynomial from the first row of the difference table. I have three polynomials. They are all acting inert, just will not evaluate.
I cannot see what the problem is.
interface(rtablesize = 12)
[10, 10]
i) Recurrence relation
"Recurrence Relation for next column. . The matrix starts at 1,1 not 0,0 A(i,j)=A(i-1,j-1)*(j-2)+A(i,j-1)"
NULL``
Msize := 12
A := Matrix(Msize)
A[1, 1] := 1
for i from 2 to Msize do for j from i to Msize do A[i, j] := A[i, j-1]*(j-2)+A[i-1, j-1] end do end do
A
Matrix(%id = 36893489695842121836)
viia)  General formula for diagonals:-
Select diagonal  & Difference Table procedures
diag := proc (M::Matrix, dg::posint) local i, rd, c, dt; rd := LinearAlgebra:-RowDimension(M); dt := Matrix(rd, rd); for i from dg to rd do dt[1+i-dg, 1] := M[1+i-dg, i] end do; return dt end proc
diag(A, 5)
Matrix(%id = 36893489695866397388)
diftab := proc (M::Matrix) local i, j, cl, rd; rd := LinearAlgebra:-RowDimension(M); for i from rd by -1 to 1 do if M[i, 1] = 0 then rd := rd-1 else break end if end do; cl := rd; for i from 2 to cl do for j to rd-i do M[j, i] := M[j+1, i-1]-M[j, i-1] end do end do; print(M); return M end proc
diftab(diag(A, 4))
Matrix(%id = 36893489695866348116)
gnrpoly := proc (M::Matrix) local i, p, rd, n; rd := LinearAlgebra:-RowDimension(M); for i from rd by -1 to 1 do if M[1, i] = 0 then rd := rd-1 else break end if end do; p := 0; for i from 0 to rd-1 do p := p+M[1, i+1]*binomial(n, i) end do; return p end proc
"for i from 0 to 3 do print("Diagonal  ",i);   eqn:=gnrpoly(diftab(diag(A,i+1)));    cat(poly,i):=unapply(factor(expand(eqn)),n);    print("--------------------------------------------------------------");  end do"
The equations do not evaluate. They are acting inert
poly1(n)
(1/2)*n*(1+n)
poly1(2)
(1/2)*n*(1+n)
poly2(n)
(1/24)*n*(3*n+5)*(n+2)*(n+1)
poly2(3)
poly3(n)
(1/48)*n*(n+1)*(n+3)^2*(n+2)^2
poly3(-1)
eqn
6*n+38*binomial(n, 2)+93*binomial(n, 3)+111*binomial(n, 4)+65*binomial(n, 5)+15*binomial(n, 6)
value(eval(eqn, n = 4))
eqn1 := expand(eqn)
(3/4)*n+2*n^2+(97/48)*n^3+(47/48)*n^4+(11/48)*n^5+(1/48)*n^6
eval(eqn1, [n = 4])
Download Q_10-10-22_gentrate_eqn.mw
convert(series(f(x),x,10),list) will produce a list with exponents rather than 0's. Is there a natural way to simply get a list with 0 padding? Also, can one make their own type converter?  (obviously I can make a procedure but talking about something in accordance with convert)
This forum complains when I paste an image of my Maple Flow work, asking that I copy and paste the content, instead of the image. How do I accomplish content copy and paste with Maple Flow?
First 274 275 276 277 278 279 280 Last Page 276 of 2430
