I have never use Maple before and have the following equation
ca, cb, Ka, Kb, Kw and Va are either constants or pre-determined (Va).  I know it should be easy to tabulate/calculate values of Vb for given values of [H+] (hydrogen ion concentration) but how easy would it be to determine values of [H+] for selected values of Vb?  Would it be easy to set up bearing in mind my lack of experience?
Not all of the units I work with are available directly in Maple Flow (torque, especially). Can I create new units in some manner? How does Maple Flow handle conversions? The following is an attempt to coerce desired units that does not work:
Hi everyone
I would like to plot something in 3d. I have to functions both depending on the time. (x(t), z(t))
I can plot in 2d: (t, x(t)) or (t,z(t)) or (x(t), z(t))
Now I want to show the flight path (x(t), z(t)) over time t. So I thought a 3d plot would be suitable for this.
The problem is that I dont know how to plot this. With plot3d I am only able to plot some planes. What I want to plot is the flight path in the 3d room with the axis x(t),z(t) and t.
Does anybody know how to do this?
thanks in advance!
L’éventail de la Geisha
restart:with(plots):with(geometry):
NULL;
_EnvHorizontalName := 'x':
_EnvVerticalName := 'y':
NULL;
EqBIS := proc(P, U, V)
local a, eq1, M1, t, PU, PV, bissec1;
description "P est le sommet de l'angle dont on chercche la bissectrice" ;
a := (P - U)/LinearAlgebra:-Norm(P - U, 2) + (P - V)/LinearAlgebra:-Norm(P - V, 2);
M1 := P + a*t; eq1 := op(eliminate({x = M1[1], y = M1[2]}, t));
RETURN(op(eq1[2])); end proc:
with(plottools);
r1 := 1/2;
r2 := r1/2;
R := r1*(21 - 12*sqrt(3));
                            21      (1/2)
                       R := -- - 6 3
a := arc([0, 0], 2*r1, Pi/6 .. (5*Pi)/6);
b := arc([0, 0], r1, Pi/6 .. (5*Pi)/6);
with(geometry);
eq := EqBIS(<sqrt(3)/2, 1/2>, <0, 0>, <0, 1/2>);
line(bis, eq);
                         (1/2)
                eq := 2 3      y - 2 x + 4 y - 2
                              bis
OpT := 2*sqrt(r1*R);
line(lv, x = OpT);
intersection(Omega, bis, lv);
coordinates(Omega);
evalf(%);
                                (1/2)
                      OpT := 2 3      - 3
                               lv
                             Omega
                 [                / (1/2)    \]
                 [   (1/2)      2 \3      - 1/]
                 [2 3      - 3, --------------]
                 [                     (1/2)  ]
                 [                2 + 3       ]
                  [0.464101616, 0.3923048456]
retarrt;
with(plottools);
[cos((5*Pi)/6), sin((5*Pi)/6)];
                        [  1  (1/2)  1]
                        [- - 3     , -]
                        [  2         2]
NULL;
A:=[cos(Pi/6), sin(Pi/6)];
B:=[cos(5*Pi/6), sin(5*Pi/6)];
Oo:=[0,0];
Op:=[0,1/2];
poly:=[A,B,Oo];
                            [1  (1/2)  1]
                       A := [- 3     , -]
                            [2         2]
                           [  1  (1/2)  1]
                      B := [- - 3     , -]
                           [  2         2]
                          Oo := [0, 0]
                                [   1]
                          Op := [0, -]
                                [   2]
                [[1  (1/2)  1]  [  1  (1/2)  1]        ]
        poly := [[- 3     , -], [- - 3     , -], [0, 0]]
                [[2         2]  [  2         2]        ]
                            21      (1/2)
                       R := -- - 6 3
Omega := [2*sqrt(3) - 3, 2*(sqrt(3) - 1)/(2 + sqrt(3))];
Omega1 := [3 - 2*sqrt(3), 2*(sqrt(3) - 1)/(2 + sqrt(3))];
                     [                / (1/2)    \]
                     [   (1/2)      2 \3      - 1/]
            Omega := [2 3      - 3, --------------]
                     [                     (1/2)  ]
                     [                2 + 3       ]
                     [                 / (1/2)    \]
                     [    (1/2)      2 \3      - 1/]
           Omega1 := [-2 3      + 3, --------------]
                     [                      (1/2)  ]
                     [                 2 + 3       ]
r3 := 3/16;
EF := sqrt(r3);
                            r3 := --
                                  16
                               1  (1/2)
                         EF := - 3
                               4
r := (150 - 72*sqrt(3))/193*1/2;
alpha := -5/3*r + 1/2*1/2;
p := sqrt(3)/3*1/2 - sqrt(3)/18*r;
                          75    36   (1/2)
                     r := --- - --- 3
                          193   193
                             307   60   (1/2)
                  alpha := - --- + --- 3
                             772   193
               1  (1/2)   1   (1/2) /75    36   (1/2)\
          p := - 3      - -- 3      |--- - --- 3     |
               6          18        \193   193       /
p2 := textplot([[A[], "A"], [B[], "B"], [Oo[], "O"]], align = ["above", "right"]);
display(a, b, p2, polygonplot(poly, thickness = 3, color = blue, transparency = 0.3), circle(Omega, R, color = blue, filled = true), circle(Omega1, R, color = blue, filled = true), circle([0, 3/4], 1/4, color = yellow, filled = true), circle([EF, 1/2 + r3], r3, color = green, filled = true), circle([-EF, 1/2 + r3], r3, color = green, thickness = 5), circle([p, 3/4 + alpha], r, color = red, thickness = 5), circle([-p, 3/4 + alpha], r, color = red, thickness = 5), axes = none, scaling = constrained, size = [500, 500]);
how to put color inside circles ? Thabk you.
There are a couple of warnings in the Maple Code Editor that are unneccessary. Those are valid parameters of in Maple functions.
Would it be possible to have those removed in future editions?
Info: Line 794: These names were used as global names but were not declared: enabled
Info: Line 837: These names were used as global names but were not declared: itemList
Info: Line 847: These names were used as global names but were not declared: nolist
Info: Line 854: These names were used as global names but were not declared: selectedindex
Info: Line 905: These names were used as global names but were not declared: nolist
Info: Line 910: These names were used as global names but were not declared: itemList
Info: Line 911: These names were used as global names but were not declared: selectedindex
Info: Line 961: These names were used as global names but were not declared: enabled
Info: Line 992: These names were used as global names but were not declared: unit_free
The "new puzzle" button is not working on the "Challege of the Cahllenger Puzzle" page. Can this be reactivated?
I want to set the EQ equations equal to zero and get the answers for a[0], a[1], b[1], c . How might I achieve this?
I am trying to produce a two-dimensionanl grid spanned by 2 non-standard vectors as shown below.  How might I achieve this?
How to draw a phase portrait of (2) same as in the attached figure? I tried it by using dsolve, but couldn't redraw it.
with(DEtools); with(plots)
alias(phi = phi(xi))
phi
eq := (1/2)*m*(diff(phi, xi))^2+`&Phi;__&mnplus;` = h
`&Phi;__&mnplus;` = `&-+`(1-cos(phi))
Download PP.mw
I want to solve for y in   exp(sqrt(y))= tanh(x) and get y=ln( tanh(x)^2).  But unable to figure what options or assumptions Maple needs.
For reference, here is Mathematica solution that I'd like to duplicate in Maple
Here is my Maple attempts, which uses same assumptions, but Maple solution converts the tanh(x) into exponentials which is much more complicated to look at. I tried to also simplify the answer to tanh(x) but no success so far.
Any ideas what else to try for solve?
I know that PDEtools:-Solve does the job. Which is why I find this strange. I thought that both PDEtools:-Solve and solve end up using same core code at one point. May be I should switch all my code to use PDEtools:-Solve?  Should not solve here have given same answer as PDEtools:-Solve?
Maple 2022.1 on windows 10.
eq:=sqrt(exp(y))=tanh(x);
(exp(y))^(1/2) = tanh(x)
sol:=solve(eq,y) assuming y::real, x>0
ln((-1+(exp(x))^2)^2/((exp(x))^2+1)^2)
simplify(sol)  assuming real, x>0;
convert(%,trigh)
2*ln(exp(2*x)-1)-2*ln(exp(2*x)+1)
2*ln(cosh(2*x)+sinh(2*x)-1)-2*ln(cosh(2*x)+sinh(2*x)+1)
sol:=PDEtools:-Solve(eq,y) assuming y::real, x>0
y = 2*ln(tanh(x))
Download oct_9_2022_simplifcation.mw
I have developed a series of two dimension PDE equations (x,t) and I am going to solve them numerically in Maple.
However, after putting all equations, initial conditions and boundary conditions, I faced couple of errors. I would be grateful if you kindly look at the code and let me know how I can solve it.
Here is the code:
restart: with(plots): with(LinearAlgebra):
L:=0.003:   # thickness
rho_w:=997.77:
rho_s:=1419:
lambda_s:=0.46:
lambda_w:=0.644:
lambda_g:=0.026:
cp_s:=3734:
cp_w:=4183:
cp_v:=1900:
cp_a:=1005.68:
M_v:=18.016:
M_a:=28.966:
R:=8.314:
epsilon:= t -> 0.9*(1-t/10):
Cw0:=6:
Sw0:= Cw0/rho_w/epsilon(0):
pi:=3.1415:
p0:=patm:
patm:=10^5:
T0:=256:
p_air:=0.2*19724:
h_m:=0.017904:
h_T:=16.746:
T_air:=380:
Xdb:= (x,t) -> S(x,t):
Cw:= (x,t) ->  rho_w*epsilon(t)*S(x,t):
Cg:= (x,t) -> rho_g(x,t)*epsilon(t)*(1-S(x,t)):
Cv:= (x,t) -> rho_v(x,t)*epsilon(t)*(1-S(x,t)):
Ca:= (x,t) -> rho_a(x,t)*epsilon(t)*(1-S(x,t)):
nw:= (x,t) -> -rho_w* k_rw(x,t)*K(t)/(mu_w(x,t))*(diff(p(x,t),x)-D_c(x,t)*diff(Cw(x,t),x) ):
ng:= (x,t) -> -rho_g(x,t)* k_rg(x,t)*K(t)/(mu_g(x,t))*(diff(p(x,t),x)):
nv:= (x,t) -> -w_v(x,t)*rho_g(x,t)* k_rg(x,t)*K(t)/(mu_g(x,t))*(diff(p(x,t),x))-binary(x,t):
na:= (x,t) -> -(1-w_v(x,t))*rho_g(x,t)* k_rg(x,t)*K(t)/(mu_g(x,t))*(diff(p(x,t),x))+binary(x,t):
M_g:= (x,t) -> M_v*w_v(x,t)+M_a*(1-w_v(x,t)):
rho_g:= (x,t) -> p(x,t)*M_g(x,t)/R/T(x,t):
rho_v:= (x,t) -> rho_g(x,t)*w_v(x,t):
rho_a:= (x,t) -> rho_g(x,t)*(1-w_v(x,t)):
binary:= (x,t) -> rho_g(x,t)*epsilon(t)*(1-S(x,t))*Deff(x,t)*diff(w_v(x,t),x):
Deff:= (x,t) -> 2.3*10^(-5)*p0/p(x,t)*(T(x,t)/T0)^1.81*(epsilon(t)*(1-S(x,t)))^(4/3):
mu_w:= (x,t) -> rho_w*exp(-19.143+1540/T(x,t)):
mu_g:= (x,t) -> 0.017/1000*(T(x,t)/273)^0.65:
p_veq:= (x,t) -> p_vsat(x,t)*a_w(x,t):
p_vsat:= (x,t) -> exp(-5800.2206/T(x,t)+1.3915-0.0486*T(x,t)+0.4176*10^(-4)*T^2-0.01445*10^(-7)*T^3+6.656*ln(T(x,t))):
a_w:= (x,t) -> exp(-0.182*Xdb(x,t)^(-0.696)+0.232*exp(-43.949*Xdb(x,t))*Xdb(x,t)^0.0411*ln(p_vsat(x,t))):
h_fg:= (x,t) -> 3167.2-2.432*T(x,t):
I_vap:= (x,t) -> M_v*K_eff*(p_veq(x,t)-p(x,t))/R/T(x,t):
K_eff:=1000:
rhocp:= (x,t) -> w_v(x,t)*epsilon(t)*(1-S(x,t))*rho_g(x,t)*cp_v+(1-w_v(x,t))*epsilon(t)*(1-S(x,t))*rho_g(x,t)*cp_a+epsilon(t)*S(x,t)*rho_w*cp_w+(1-epsilon(t))*rho_s*cp_s:
lambda:= (x,t) -> epsilon(t)*(1-S(x,t))*lambda_g+epsilon(t)*S(x,t)*lambda_w+(1-epsilon(t))*lambda_s:
ncp:= (x,t) -> nv(x,t)*cp_v+na(x,t)*cp_a+nw(x,t)*cp_w:
k_rw:= (x,t) -> S(x,t)^3:
k_rg:= (x,t) -> 1.01*exp(-10.86*S(x,t) ):
K:= t -> 10^(-10)*(1-t/10):
D_c:= (x,t) -> 10^(-8)*exp(-2.8+2*Xdb(x,t)):
PDE_m1:=diff(Cw(x,t),t)+ diff(nw(x,t),x)=-I_vap(x,t) :
PDE_m2:=diff(Ca(x,t),t)+ diff(na(x,t),x)=0 :
PDE_m3:=diff(Cg(x,t),t)+ diff(ng(x,t),x)=I_vap(x,t) :
PDE_T:=diff(rhocp(x,t),t)+ diff(ncp(x,t)*T(x,t),x)=diff( lambda(x,t)*diff(T(x,t),x),x) -h_fg(x,t)*I_vap(x,t):
IBC_S:={S(x,0)=Sw0, D[1](Cw)(0,t)=0, subs(x=L,nw(x,t))=epsilon(t)*S(L,t)*h_m/R/T(L,t)*(p_veq(L,t)-p_air) }:
IBC_p:={D[1](p)(0,t)=0,p(L,t)=patm,p(x,0)=patm}:
IBC_T:={h_T*(T(L,t)-T_air)+epsilon(t)*S(L,t)*h_m/R/T(L,t)*(p_veq(L,t)-p_air)*h_fg(L,t)=0, T(x,0)=T_air, D[1](T)(0,t)=0}:
IBC_w:={w_v(x,0)=0.0262, subs(x=L,nv(x,t))=epsilon(t)*(1-S(L,t))*h_m/R/T(L,t)*(p_veq(L,t)-p_air), D[1](w_v)(0,t)=0 }:
pds:=pdsolve(PDE_m1,PDE_m2,PDE_m3,PDE_T,{IBC_S,IBC_p,IBC_T,IBC_w},numeric);
I would like to automize some calculations which are variables changements.
ChgtVariables_VERS_INT:=
diff(theta[1](t),t$2)=ddq1,
diff(theta[1](t),t)=dq1,
theta[1](t)=q1,
diff(theta[2](t),t$2)=ddq2,
diff(theta[2](t),t)=dq2,
theta[2](t)=q2,
diff(theta[3](t),t$2)=theta3_dd,
diff(theta[3](t),t)=theta3_d,
theta[3](t)=q3;
how can i do to make variables qi, dqi, ddqi with i which can change?
I think that is just a question of string but i'm not very used to use this.
I thank you in advance for your help.
everyone! I want to get a system of equations (Fig. 1). But my result is a table (Fig. 2), so I wonder how to convert a table into a sequence or a system. And I am very sorry that my code is not concise, since I am a beginner. Thank you very much!
Download Equations.mw
I'm in the process of making a resonant LLC calculator to define Lr,Lm and Cr. In short, to do this I need to define the fonction of the Gain for different Qualifty factor at a given m value m. My issue is that the below code returns different results everytime. I'm trying to get the value at the top of the Q curve using the maximise fonction and trying to solve wx for that maximum value. Anybody can see what am I doing wrong. Sometime it outpiuts an imaginary number where sometime it doesn't. The expression seems correct as its producing the correct plot/curve.
Thank you for the help.
> m:=6.3:
> Q1:=1:
> GainQ1:=(8/(Pi^2))*((wx^2)*(m-1))/(sqrt((((m*wx^2)-1)^2)+(Q1^2*wx^2)*((wx^2-1)^2)*((m-1)^2))):
> semilogplot({GainQ1},wx=0.2...2,Gain,axes=boxed,thickness=5,title=`Gain (w, Q, m)`):
> Top_of_Q1:=eval(maximize(GainQ1),wx=0.1..2);wx:=solve(GainQ1=Top_of_Q1);
Hello Iam following this tutorial to solve pde with laplace transforms  but have a problem with eval which is not evaluating the following expression
with(PDEtools);
with(inttrans);
# Equations for c in physical space
PDE1 := diff(c(r, t), t) = K_1*diff(r*diff(c(r, t), r), r)/r;
#initial condition
ic1 := c(r, 0) = V
# Equation in Laplace space
PDEL1 := laplace((lhs - rhs)(PDE1), t, p);
# Apply initial condition to simplify
simplified_PDEL1 := eval(PDEL1*{ic1})
which is displayed (an treated) as
with c(r,0) not being replaced by V. When I try to solve the problem with dsolve I get the following error
Error, (in dsolve) invalid input: `PDEtools/NumerDenom` expects its 1st argument, ee, to be of type algebraic, but received {c(r, 0) = V}
If I replace manually C(r,0) by V then the error dissapears. Is this how eval is supposed to behave ?
Cheers,
First 275 276 277 278 279 280 281 Last Page 277 of 2430
