Recently, I tried to write a function to get the lexicographic product of two graphs.
In  graph theory the lexicographic product G ∙ H of graphs G and H is a graph such that
  • the vertex set of G ∙ H is the cartesian product V(G) × V(H); and
  • any two vertices (u,v) and (x,y) are adjacent in G ∙ H if and only if either u is adjacent with x in G or u = x and v is adjacent with y in H.
I'm trying to write this function as defined after making sure it doesn't exist in maple. I saw a similar post by mathematica stack.
There are many answers in the post, the most interesting to me is the following code, which follows the definition of lexicographic product.
lexicographicProduct[g1_?UndirectedGraphQ, g2_?UndirectedGraphQ, opt : OptionsPattern[]] :=
 RelationGraph[
   (* two nodes are connected if their corresponding nodes in the first graph are connected *)
   EdgeQ[g1, First[#1] \[UndirectedEdge] First[#2]] ||
   (* or their corresponding nodes in the first graph are the same and their corresponding nodes in the second graph are connected *)
   (First[#1] === First[#2] && EdgeQ[g2, Last[#1] \[UndirectedEdge] Last[#2]]) &,
   (* the vertices are the cartesian product of the two vertex sets *)
   Tuples[{VertexList[g1], VertexList[g2]}],
   (* also allow setting graph options *)
   opt
lexicographicProduct[CycleGraph[5], CycleGraph[3]]
It utilizes the  function RelationGraph in Mathematica. I feel that this function is generic in nature. So here I would ask maple if they had a similar function.
Function RelationGraph is to generate a graph based on data and a binary relation.
For example, using RelationGraph  I  can get easily  the kth power Gk of an graph G which is another graph that has the same set of vertices, but in which two vertices are adjacent when their distance in G is at most k.
Dis[g1_?UndirectedGraphQ, k_] :=
 RelationGraph[
  GraphDistance[g1, #1, #2] <= k && GraphDistance[g1, #1, #2] != 0 &,
  VertexList[g1]]
Dis[PathGraph[Range[10]], 2]
If I use maple and do not use the built-in function GraphPower, I might deal with the following.
with(GraphTheory):
with(SpecialGraphs):
graphpower:=proc(G,k):
local choo,edge,vex,g;
 vex:=convert(Vertices(G),list);
 choo:= choose(vex, 2):
 g:= Graph(Vertices(G)):
 for edge in choo do
     if Distance(G, edge[1], edge[2])<=k  then
        AddEdge(g, convert(edge,set))
     fi;
 return g;
s:=graphpower(PathGraph(10),2);DrawGraph(s)
I believe if the RelationGraph function can be  implemented in maple, the function lexicographicProduct would be easier to obtain.
Hey, guys! My Maple 2020 program does not build a plot. that is, it cuts it off. everything is correct in maple 2015.
plot(140^t*exp(-140)/t!, t = 0 .. 300)
Maple 2015
My maple 2020 creates
Why???????????
How do we plot the least integer function [x]?
I am referring to a function with the following graph
Declaring types of arguments of a procedure or checking type of something when working with lists or Arrays is easy. For example one can easily use A :: list( posint ) or type( B :: 'Array'( polynom ) ), but with MutableSet, the same approach ends with an error;
Error, module does not have a ModuleType member to accept structured type arguments.
I guess it is the same for other objects defined as a module with option object. Is there a recommended way to have type declaration for such objects or MutableSet in specific?
Dear Mapler
I have an expression that consist of power of main variable x. I aim to fetch the coefficient of square root of x for example. I get an error when I am using COEFF(esp, sqrt(x))
Is there any solution?
When I export a very simple Maple 2018 (MaxOS) document to Latex, this tex file results:
%% Created by Maple 2018.2, Mac OS X
%% Source Worksheet: untitled 3
%% Generated: Sun Jul 03 16:34:49 CEST 2022
\documentclass{article}
\usepackage{maplestd2e}
\def\emptyline{\vspace{12pt}}
\begin{document}
\pagestyle{empty}
\DefineParaStyle{Maple Bullet Item}
\DefineParaStyle{Maple Heading 1}
\DefineParaStyle{Maple Warning}
\DefineParaStyle{Maple Heading 4}
\DefineParaStyle{Maple Heading 2}
\DefineParaStyle{Maple Heading 3}
\DefineParaStyle{Maple Dash Item}
\DefineParaStyle{Maple Error}
\DefineParaStyle{Maple Title}
\DefineParaStyle{Maple Text Output}
\DefineParaStyle{Maple Normal}
\DefineCharStyle{Maple 2D Output}
\DefineCharStyle{Maple 2D Input}
\DefineCharStyle{Maple Maple Input}
\DefineCharStyle{Maple 2D Math}
\DefineCharStyle{Maple Hyperlink}
\begin{Maple Normal}{
\mapleinline{inert}{2d}{restart; 1}{\[\displaystyle \]}
}\end{Maple Normal}
}\end{Maple Normal}
\mapleinline{inert}{2d}{a := b^2-sqrt(4); "_noterminate"}{\[\displaystyle \]}
}\end{Maple Normal}
}\end{Maple Normal}
\begin{maplegroup}
}\end{Maple Normal}
\mapleresult
\begin{maplelatex}
\mapleinline{inert}{2d}{a := b^2-2; "_noterminate"}{\[\displaystyle \]}
\end{maplelatex}
\end{maplegroup}
}\end{Maple Normal}
}\end{Maple Normal}
\begin{maplegroup}
}\end{Maple Normal}
\mapleresult
\begin{maplelatex}
\end{maplelatex}
\end{maplegroup}
\mapleinline{inert}{2d}{}{\[\displaystyle \]}
}\end{Maple Normal}
}\end{Maple Normal}
\end{document}
However, when trying to process the tex file in both Overleaf and TexShop the pdf output is only an empty page. No error occurs, i.e. the maplestd2e.sty file is recognised by both Overleaf and TexShop.
What is going wrong here?
eq := a*x^3 + b*x^2 + c*x + d;
 s := x1 + x2 + x3 = -b/a;
 sp := x1*x2 + x1*x3 + x2*x3 = c/a;
 p := x1*x2*x3 = -d/a;
sol:=solve({eq, p, s, sp}, {x1, x2, x3},explicit);
 a := 1;
b := -5;
c := 6;
d := -1;
 sol;
why is not successfull ?   Thank you.
I have a problem in plotting bellow function. actually because my main program is not working so I decided to do it in simple way. I found that my program in maple can't plot the function I introduced it as a procudure and is an implicit function. can you help me please?
>EQ := proc(x, t) local y, m, func;
                 m := 3;
                 func := m*x^2 + t*y^2 = 4;
>eq := EQ(x, 10);
                     eq := 3*x^2  + 10*y^2  = 4
>implicitplot(eq, x = -1 .. 1, y = 0 .. 2)
 Error, (in plots/implicitplot) invalid input: the following extra unknowns were found in the input expression: {y}
Given this "pattern" to transfporm an expression into an arrow procedure
e := 1/b:
f := unapply(e, b):
f(3)
I would like now to use this same "pattern" to transform an expression e which depends on 2 indeterminates a and b into a "double layered arrow procedure" f.
Here is a notional example
e := a/b:
f := unapply(unapply(e, b), a);
                     a
           a -> b -> -
                     b
 f(A)(B)
                              a
                              B
How can I proceed in order that f(A)(B) gives A/B ?
TIA
I was surprised to learn that implicitplot doesn't recognize the constant Pi.  I attach a simple example to illustrate.
with(plots)
f := x-y-Pi
x-y-Pi
implicitplot(f)
Error, (in plots/implicitplot) found 3 variables that the expression depends on ({Pi, x, y}), but expected only 2
evalf(Pi)
3.141592654
g := x-y-3.14
x-y-3.14
implicitplot(g)
Download implicitplot_error.mw
dgdx := (x, T) -> diff(g(x, T), x);
g := (x, T) -> T*x + x^2;#just an example
dgdx(1, 2);
Error, (in dgdx) invalid input: diff received 1, which is not valid for its 2nd argument
So, I like to introduce a new function dgdx(x,T) from the x-derivative of g(x,T) but if I insert a value for x I get an error message. It would be great if you can help me out!
Perhaps a silly question but is it possible to stack two dataframe columns? When I use the Vector command the columns are stacked but nested.
Thank you for your help
5_6190449716501677775.pdf
I ahve a signal y_a to which adding mu(t) doesn't seem to give any plot but error , what is missing here?.
And also in second k(x,t) pdf file I want the value of k(x,t) after I did the integration. When I type k(x,t) and hit enter it's not giving me the value of k(x,t) but returns k(x,t) as it is.K(x_t).pdf
I do not remember now if this was asked before. Doing search here is hard.
But I am trying this now on 2022.1 and this gives FAIL.
What is the correct syntax to use odetest to verify solution to ode using series method with expansion around infinity? Why do I get FAIL here?
interface(version)
Physics:-Version()
`The "Physics Updates" version in the MapleCloud is 1257 and is the same as the version installed in this computer, created 2022, June 22, 16:27 hours Pacific Time.`
ode:=x^3*diff(y(x),x$2)+x^2*diff(y(x),x)+y(x)=0;
sol:=dsolve(ode,y(x),'series',x=infinity);
odetest(sol,ode,'series','point'=infinity)
x^3*(diff(diff(y(x), x), x))+x^2*(diff(y(x), x))+y(x) = 0
y(x) = _C1*(1-1/x+(1/4)/x^2-(1/36)/x^3+(1/576)/x^4-(1/14400)/x^5+O(1/x^6))+_C2*(ln(1/x)*(1-1/x+(1/4)/x^2-(1/36)/x^3+(1/576)/x^4-(1/14400)/x^5+O(1/x^6))+2/x-(3/4)/x^2+(11/108)/x^3-(25/3456)/x^4+(137/432000)/x^5+O(1/x^6))
Warning, unable to compute series necessary to test the given solution
FAIL
Download odetest_series.mw
Update
I've testsed methods given below on 6 random ode's using Maple odetest, VV method and Axel method. THis is the result obtained using Maple 2022.1
odetest was able to verify the solution zero out of 6 times.
VV method was able to verify the solution 3 out of 6 times.
Axel method was able to verify the solution 5 out of 6 times.
So based on this small test, Axel method seems to do the best. Attached worksheet. I will use this method to verify my series solution to ode's instead of Maple's odetest but will use Maple's odetest for non-series method solutions.
Example 1  Regular singular point. Complex roots
Order:=6;
ode:=sin(x)*diff(y(x),x$2)+cos(x)*diff(y(x),x)+1/x*y(x)=0;
sol:=dsolve(ode,y(x),type='series',x=0)
6
sin(x)*(diff(diff(y(x), x), x))+cos(x)*(diff(y(x), x))+y(x)/x = 0
y(x) = _C1*x^(-I)*(series(1+(1/48-(1/16)*I)*x^2+(1/57600-(217/57600)*I)*x^4+O(x^6),x,6))+_C2*x^I*(series(1+(1/48+(1/16)*I)*x^2+(1/57600+(217/57600)*I)*x^4+O(x^6),x,6))
VV method
odetest(sol,ode):
asympt(%,x);
Error, (in asympt) unable to compute series
odetest method
odetest(sol,ode,'series','point'=0);
y(t) = _C1*t^(-I)*(series(1+(1/48-(1/16)*I)*t^2+(1/57600-(217/57600)*I)*t^4+O(t^6),t,6))+_C2*t^I*(series(1+(1/48+(1/16)*I)*t^2+(1/57600+(217/57600)*I)*t^4+O(t^6),t,6))
Axel method
rhs(sol):
Y:= unapply(%, x):
eval(lhs(ode), y=Y):
MultiSeries:-asympt(%, x):
convert(%,polynom);
Example 2 Regular singular point. Dierence is integer
Order:=6;
ode:=sin(x)*diff(y(x),x$2)+cos(x)*y(x)=0;
sol:=dsolve(ode,y(x),type='series',x=0):
6
sin(x)*(diff(diff(y(x), x), x))+cos(x)*y(x) = 0
VV method
odetest(sol,ode):
asympt(%,x);
convert(%,polynom);
O(x^7)
odetest method
FAIL
Axel method
rhs(sol):
Y:= unapply(%, x):
convert(%,polynom);
Example 3 Regular singular point. Repeated root
Order:=6;
ode:=(exp(x)-1)*diff(y(x),x$2)+exp(x)*diff(y(x),x)+y(x)=0;
6
(exp(x)-1)*(diff(diff(y(x), x), x))+exp(x)*(diff(y(x), x))+y(x) = 0
VV method
odetest(sol,ode):
asympt(%,x):
convert(%,polynom);
odetest method
FAIL
Axel method
rhs(sol):
Y:= unapply(%, x):
convert(%,polynom);
Example 4 Regular singular point. Repeated root
Order:=6;
6
VV method
odetest(sol,ode):
asympt(%,x):
convert(%,polynom);
odetest method
FAIL
Axel method
rhs(sol):
Y:= unapply(%, x):
convert(%,polynom);
Example 5 . Regular singular point. Complex roots
Order:=6;
ode:=x^3*diff(y(x),x$2)+sin(x^3)*diff(y(x),x)+x*y(x)=0;
6
x^3*(diff(diff(y(x), x), x))+sin(x^3)*(diff(y(x), x))+x*y(x) = 0
VV method
odetest(sol,ode):
asympt(%,x);
#convert(%,polynom);
odetest method
Error, (in odetest/series) need to determine the sign of I*3^(1/2)
Axel method
rhs(sol):
Y:= unapply(%, x):
Error, (in MultiSeries:-multiseries) need to determine the sign of -I*3^(1/2)
Example 6 . Regular singular point. Complex roots
Order:=6;
ode:=x^2*diff(y(x),x$2)+x*diff(y(x),x)+(x+1)*y(x)=0;
6
x^2*(diff(diff(y(x), x), x))+x*(diff(y(x), x))+(x+1)*y(x) = 0
VV method
odetest(sol,ode):
asympt(%,x);
odetest method
y(x) = _C1*x^(-I)*(series(1+(-1/5-(2/5)*I)*x+(-1/40+(3/40)*I)*x^2+(3/520-(7/1560)*I)*x^3+(-1/2496+(1/12480)*I)*x^4+(9/603200+(1/361920)*I)*x^5+O(x^6),x,6))+_C2*x^I*(series(1+(-1/5+(2/5)*I)*x+(-1/40-(3/40)*I)*x^2+(3/520+(7/1560)*I)*x^3+(-1/2496-(1/12480)*I)*x^4+(9/603200-(1/361920)*I)*x^5+O(x^6),x,6))
Axel method
rhs(sol):
Y:= unapply(%, x):
convert(%,polynom);
Download test_new_odetest.mw
What is the [explict] relation between Maple's WeierstrassP and Weierstrass' P-function (e.g. https://en.wikipedia.org/wiki/Weierstrass_elliptic_function) ?
First 300 301 302 303 304 305 306 Last Page 302 of 2430
