For a month I did do not get email notfications.
I checked spam folders, settings and email filters.
Is it only me?
The attached sheet contains equations H1 to H6 and K1 to K3. What data do I need to modify to ensure that the values of H1 to H6 fall between 0 and 1, and K1 to K3 are negative? The parameter ranges are also given in the sheet. Is there a method to achieve this?
rouhg.mw
i did two case of this equation and odetest is worked good but in this case the odetest is not worked well anyone can determine what is mistake ?
F_P_Correct_case_three.mw
Dear Maple user I am facing error while running the codes  to plot the graph for two data sets .
I am attaching the files.
Error_in_Display_1.mw
Why does dsolve not call odetest by default before a solution is returned?
I mean, why do I have test each result separately. dsolve could have an odetest option (default=true).
In case of discrepancies dsolve could inform the user and suggest to call dsolve with odetest=false and run odetest separately to analyse the problem.
Set up this way, dsolve would never return potentially incorrect solutions that do not pass odetest.
HTR.mw
In above problem, Additionally How to  plot  heat transfer rate  Q versus L^2  for distinct porosity parmeters(Sh) , using  heat transfer rate formula, Q = (q*L)/(k*A*T[b])=theta'(1).
using  [Sh = 0.1, L^2 = 0.1, Nr =0 .1, Ha =0 .1, Pe = 0.1],  [Sh = 0.3, L^2 = 0.3, Nr = 0.1, Ha = 0.1, Pe =0 .1],   [Sh = 0.5, L^2 =0 .5, Nr =0 .1, Ha = 0.1, Pe =0 .1].
How can I find Mean, Median, Quartiles, Variance, StandardDeviation of data in this table
I use Mathamatica and get the result
Clear["Global`*"]
boundaries = Range[0, 10, 5/2];
frequencies = {18, 11, 13, 6};
binMeans = Mean /@ Partition[boundaries, 2, 1];
weighted = WeightedData[binMeans, frequencies];
weightedHist = HistogramDistribution[weighted, {5/2}];
Through[{Mean, Median, Quartiles, Variance, StandardDeviation}[
  weightedHist]]
I trying to simplify expressions for lines so no higher order terms. factor and op seperate out what I need but how do I select the one with the variables in this case x,y. I cant depent on this always been the last one returned from the op command.
vars=[x,y]
vars = [x, y]
k:=17
17
expr:=-2*sqrt(118)*(((-4*x + y + 51/32)*sqrt(k) + (k*x)/4 - (51*y)/4 + 153/32)*sqrt(-4012 + 1003*sqrt(k)) + ((x + 4*y)*sqrt(k) - (85*x)/4 - (17*y)/4)*sqrt(4012 + 1003*sqrt(k)))*k^(1/4)/(17051*(-1 + sqrt(k)))
-2*118^(1/2)*(((-4*x+y+51/32)*17^(1/2)+(17/4)*x-(51/4)*y+153/32)*(-4012+1003*17^(1/2))^(1/2)+((x+4*y)*17^(1/2)-(85/4)*x-(17/4)*y)*(4012+1003*17^(1/2))^(1/2))*17^(1/4)/(-17051+17051*17^(1/2))
indets(expr)
{x, y}
factor(expr)
(1/64192)*(-4012+1003*17^(1/2))^(1/2)*118^(1/2)*17^(1/4)*(17^(1/2)+5)*(40*x-24*y-3)
op(factor(expr))
1/64192, (-4012+1003*17^(1/2))^(1/2), 118^(1/2), 17^(1/4), 17^(1/2)+5, 40*x-24*y-3
select(has,vars, factor(expr))
select(has,vars, op(factor(expr)))
Error, invalid input: has expects 2 arguments, but received 7
Download 2024-09-11_Has_Select_Question.mw
I get my on results but the results are not the same please help me if i did any mistake in my code
symmetry_PDESYS_3_time_fraction[1].mw
This code is working for function f1 but not for f2
f2 := (x,y)->9*x^2-24*x*y+16*y^2+10*x-70*y + 175;
Why this code is not working for f2 ?
unprotect(D);
f1:= (x, y) -> 3*x^2 - 3*y*x + 6*y^2 - 6*x + 7*y - 9;
coeffs(f(x, y));
A, B, C, D, E, F := %;
theta := 1/2*arctan(B/(A - C));
solve({-2*A*xc - B*yc = D, -B*xc - 2*C*yc = E});
assign(%);
x := xcan*cos(theta) - ycan*sin(theta) + xc;
y := xcan*sin(theta) + ycan*cos(theta) + yc;
Eq := simplify(expand(f1(x, y)));
xcan^2/simplify(sqrt(-tcoeff(Eq)/coeff(Eq, xcan^2)))^`2` + ycan^2/simplify(sqrt(-tcoeff(Eq)/coeff(Eq, ycan^2)))^`2` = 1;
In Maple 2024, using commands like
M := Matrix([[1, 2, 3, 10], [4, 15, 6, 7], [0, 0, 0, 0]]);
ReducedRowEchelonForm(M);
we see output of the 3x4 matrices fine at first, but when I and my students try to print or save to a PDF, ellipsis (three dots) sometimes show up in the bottom row. I checked the settings for elision and they are as usual. This is only when trying to print---the ellipsis show up in both the Maple file and the printed copy. We've tested on both Mac and PC. This did not happen in Maple 2023.
I have side-by-side comparisons in an image below: the Maple looking fine before we try to print or save as a PDF, what happens in the Maple file after with the bottom row, and the elision settings. Any help would be greatly appreciated as we would like the full matrices to show up in printing or a PDF we save to.
I'm trying to solve a system of coupled differential equations numerically, but I'm getting the following error
The error occurs at the dsolve step, despite trying to ensure that all equations and conditions are in the correct form (sets/lists).
Could someone help me identify what I'm missing here?
Thanks in advance!
L := 200; K := 99; kappa := 1; omegaD := 1; beta := 1; delta := 0.5e-1; j := 2; tmax := 3000; h := L/(K+1); nsp := [`$`(-(1/2)*L+h*i, i = 0 .. L/h)]; km := nops(nsp); omegaD2 := h^2*omegaD^2; deltaHat := h*delta; a := 2; var := seq(x[i](t), i = 1 .. km); initialPositions := seq(x = a*sin(j*h*Pi*nsp[i]/L), i = 1 .. km); initialVelocities := seq((D(x[i]))(0) = 0, i = 2 .. km-1)
boundaryConditions := [x[1](t) = 0, x[km](t) = 0]
equations := seq(diff(x[n](t), t, t)-kappa*(x[n+1](t)-2*x[n](t)+x[n-1](t))+deltaHat*(diff(x[n](t), t))-omegaD2^2*(x[n](t)-beta*x[n](t)^3) = 0, n = 2 .. km-1)
sol := dsolve({equations, boundaryConditions, initialPositions, initialVelocities}, var, numeric, method = rkf45, range = 0 .. tmax)
Download dsolve_error.mw
I wanted to change  eq:= 1/2 * sqrt(-2*lambda)  to 1/2 %* sqrt(-2*lambda)  using a rule.
It works outside of rule ofcourse. But when I put %* in the RHS of the rule, maple hangs. It seems it is going into infinite loop.
I tried the trick of using '%*' but this gives syntax error.
Same problem happens when using %. and not just %*
Is there a workaround?
Attached worksheet. Make sure to save all work before trying it.
Physics:-Version()
`The "Physics Updates" version in the MapleCloud is 1804. The version installed in this computer is 1802 created 2024, September 3, 11:35 hours Pacific Time, found in the directory C:\Users\Owner\maple\toolbox\2024\Physics Updates\lib\`
libname;
(1/2)*(-2*lambda)^(1/2)
eq:= 1/2 %. sqrt(-2*lambda); #no problem
`%.`(1/2, (-2*lambda)^(1/2))
eq:= 1/2 %* sqrt(-2*lambda); #no problem
`%*`(1/2, (-2*lambda)^(1/2))
applyrule(sqrt(x::anything)/y::anything = 1/y %. sqrt(x),eq); #why this hangs?
applyrule(sqrt(x::anything)/y::anything = 1/y %* sqrt(x),eq); #why this hangs?
Download maples_hangs_applyrule_sept_10_2024.mw
I cannot find anything in the documentation that could explain the below.
According to ?name  the character ? can be used in a name with the exception of beeing the first character.
Example:
abc?:=2;
abc?
Reentering the name in 2D
"abc"?""
abc
In 2D the nane "abc"?"" does not seem to exist.
Trying now as above
"abc"?:=a:"  abc"?""
abc^2
returns an unexpected output.
Trying
"ab"?c:=b;"  "
ab
"a"?b:=c""
a
seems to cut of everything that follows the question mark (including the question mark).
This could explain the output (3) as having been parsed as abc*abc.
The variable palette only lists the name entered in 1D.
What could explain the difference between 1D and 2D when "?" is used in a name.
Download Questionmark_in_2D_names.mw
First 75 76 77 78 79 80 81 Last Page 77 of 2429
