Question: MapleSim does not show the simulation results
Hi all,
I met a problem while using the MapleSim7.
When I increase the plot points (which can be modeified in the setting tab) to get more accurate solution,
MapleSim does not show the simulation results (ex. graph) even though the simulation has finished.
MapleSim message only says "Done Simulating", but does not show the results.
When I set plot points "10000", I could obtain the results. However when I set "30000" for plot points,
I couldn't get results.
What is the problem and how can I obtain the results with many number of plot points?
