Question: Difference between Inboard frame and Euler for the rotation in the definition of a body
In my mechanism, I use absolute coordinates.
For the rotation (namely the initial angles/ angular velocites), I didn't see the difference between Inboard and Euler.
It seems to me that in the two cases, the initial angles are defined with regard to the inertial frame and for both, different kind of rotations can be defined.
Have you some ideas on these two options ?
Thank you for your help.
