Question: Using embedded component
I have a question about using embedded component in Maple 2015.
I want to import the MapleSim model to Maple and use the "Combo Box" (which is one of the embedded component in Maple) to load the parameters that were used in the MapleSim model.
Embedded Component
The picture above shows the Maple worksheet that I made simply.
As you can see, I imported the MapleSim file (which contains three parameters, m, c, and k) to the Maple by using "MapleSim Component (Embedded Component)".
After that, I wanted to load these three parameters to the "Combo Box" automatically like the picture above, but I couldn't do that.
(In the case above, I manually type m, c, and k in the "Combo Box")
Isn't there any way to load the parameters to "Combo Box" automatically?
I attached the MapleSim file that I made. It also contains the Maple worksheet.
[TS]EmbeddedComponents.msim
I appreciate any idea you may have.
