Question: How can I merge these four pictures into one? Thx!!
alias(epsilon = e, omega = w, omega[0] = w0, t[1] = t1, t[2] = t2, alpha[1] = a1, alpha[2] = a2, alpha[3] = a3); e := proc (t1, t2) options operator, arrow; e end proc; w0 := proc (t1, t2) options operator, arrow; w0 end proc; f := proc (t1, t2) options operator, arrow; f end proc; mu := proc (t1, t2) options operator, arrow; mu end proc
ode := (D@@2)(u)+u+e*a1*D(u)+e*a2*u^3-f0*cos(omega*t) = 0
(D@@2)(u)+u+epsilon*alpha[1]*D(u)+epsilon*alpha[2]*u^3-f0*cos(omega*t) = 0
e_oredr := 1:
ode := subs(D = sum('e^(i-1)*D[i]', 'i' = 1 .. e_oredr+1), ode);
((epsilon*D[2]+D[1])@@2)(u)+u+epsilon*alpha[1]*(epsilon*D[2]+D[1])(u)+epsilon*alpha[2]*u^3-f0*cos(omega*t) = 0
u := sum('q[i]*e^i', 'i' = 0 .. e_oredr);
q[1]*epsilon+q[0]
ode := collect(ode, e):
ode:=simplify(%,{e^3=0,e^2=0});
-f0*cos(omega*t)+D[1, 1](q[1])*epsilon+D[1, 1](q[0])+2*D[1, 2](q[0])*epsilon+D[1](q[0])*alpha[1]*epsilon+(alpha[2]*q[0]^3+q[1])*epsilon+q[0] = 0
for i from 0 to e_oredr do eq[i] := coeff(lhs(ode), e, i) = 0 end do;
-f0*cos(omega*t)+D[1, 1](q[0])+q[0] = 0
alpha[2]*q[0]^3+alpha[1]*D[1](q[0])+2*D[1, 2](q[0])+D[1, 1](q[1])+q[1] = 0
eq[1]:=convert(eq[1](t1, t2), diff);
alpha[2](t[1], t[2])*q[0](t[1], t[2])^3+alpha[1](t[1], t[2])*(diff(q[0](t[1], t[2]), t[1]))+2*(diff(diff(q[0](t[1], t[2]), t[1]), t[2]))+diff(diff(q[1](t[1], t[2]), t[1]), t[1])+q[1](t[1], t[2]) = 0
q[0] :=A(t2)*exp(I*t1)+b*exp(I*w*t1)+conjugate(A)(t2)*exp(-I*t1)+b*exp(-I*w*t1); convert(%, 'exp'); q[0] := unapply(%, (t1, t2)):  # Chage the value
A(t[2])*exp(I*t[1])+b*exp(I*omega*t[1])+(conjugate(A))(t[2])*exp(-I*t[1])+b*exp(-I*omega*t[1])
expand(lhs(eq[1])):
eq:=combine(%, exp):
eq:=simplify(%, power):
eq:=combine(subs(w=1/3+e*sigma,%),exp):   ## substituting the detuning parameter
expand(%):
eq:=algsubs(t1*e=t2,%):
eq:=collect(%, exp(I*t1)):
coeff(%, exp(I*t1),1):
simplify(combine(%,exp));
exp((3*I)*sigma*t[2])*alpha[2](t[1], t[2])*b^3+3*alpha[2](t[1], t[2])*A(t[2])^2*(conjugate(A))(t[2])+6*alpha[2](t[1], t[2])*b^2*A(t[2])+I*A(t[2])*alpha[1](t[1], t[2])+(2*I)*(diff(A(t[2]), t[2]))
subs({A(t2)=a(t2)*exp(I*beta(t2))/2,conjugate(A)(t2)=a(t2)*exp(-I*beta(t2))/2},%);
exp((3*I)*sigma*t[2])*alpha[2](t[1], t[2])*b^3+(3/8)*alpha[2](t[1], t[2])*a(t[2])^3*(exp(I*beta(t[2])))^2*exp(-I*beta(t[2]))+3*alpha[2](t[1], t[2])*b^2*a(t[2])*exp(I*beta(t[2]))+((1/2)*I)*a(t[2])*exp(I*beta(t[2]))*alpha[1](t[1], t[2])+(2*I)*(diff((1/2)*a(t[2])*exp(I*beta(t[2])), t[2]))
combine(%,exp);
exp((3*I)*sigma*t[2])*alpha[2](t[1], t[2])*b^3+(3/8)*alpha[2](t[1], t[2])*a(t[2])^3*exp(I*beta(t[2]))+3*alpha[2](t[1], t[2])*b^2*a(t[2])*exp(I*beta(t[2]))+((1/2)*I)*a(t[2])*exp(I*beta(t[2]))*alpha[1](t[1], t[2])+(2*I)*((1/2)*(diff(a(t[2]), t[2]))*exp(I*beta(t[2]))+((1/2)*I)*a(t[2])*(diff(beta(t[2]), t[2]))*exp(I*beta(t[2])))
map(x->x*exp(-I*beta(t2)),%);
exp((3*I)*sigma*t[2])*alpha[2](t[1], t[2])*b^3*exp(-I*beta(t[2]))+(3/8)*alpha[2](t[1], t[2])*a(t[2])^3*exp(I*beta(t[2]))*exp(-I*beta(t[2]))+3*alpha[2](t[1], t[2])*b^2*a(t[2])*exp(I*beta(t[2]))*exp(-I*beta(t[2]))+((1/2)*I)*a(t[2])*exp(I*beta(t[2]))*alpha[1](t[1], t[2])*exp(-I*beta(t[2]))+(2*I)*((1/2)*(diff(a(t[2]), t[2]))*exp(I*beta(t[2]))+((1/2)*I)*a(t[2])*(diff(beta(t[2]), t[2]))*exp(I*beta(t[2])))*exp(-I*beta(t[2]))
simplify(%,exp);
alpha[2](t[1], t[2])*b^3*exp(-I*(-3*sigma*t[2]+beta(t[2])))+(3/8)*alpha[2](t[1], t[2])*a(t[2])^3-a(t[2])*(diff(beta(t[2]), t[2]))+3*alpha[2](t[1], t[2])*b^2*a(t[2])+((1/2)*I)*a(t[2])*alpha[1](t[1], t[2])+I*(diff(a(t[2]), t[2]))
subs({3*sigma*t2-beta(t2)=C(t2),beta(t2)=3*sigma*t2-C(t2)},%);
alpha[2](t[1], t[2])*b^3*exp(I*C(t[2]))+(3/8)*alpha[2](t[1], t[2])*a(t[2])^3-a(t[2])*(diff(3*sigma*t[2]-C(t[2]), t[2]))+3*alpha[2](t[1], t[2])*b^2*a(t[2])+((1/2)*I)*a(t[2])*alpha[1](t[1], t[2])+I*(diff(a(t[2]), t[2]))
convert(%,trig);
alpha[2](t[1], t[2])*b^3*(cos(C(t[2]))+I*sin(C(t[2])))+(3/8)*alpha[2](t[1], t[2])*a(t[2])^3-a(t[2])*(3*sigma-(diff(C(t[2]), t[2])))+3*alpha[2](t[1], t[2])*b^2*a(t[2])+((1/2)*I)*a(t[2])*alpha[1](t[1], t[2])+I*(diff(a(t[2]), t[2]))
(14)
cond1 := collect(coeff(%, I, 0), [diff(C(t2), t2), cos(C(t2))]);
a(t[2])*(diff(C(t[2]), t[2]))+alpha[2](t[1], t[2])*b^3*cos(C(t[2]))+(3/8)*alpha[2](t[1], t[2])*a(t[2])^3-3*a(t[2])*sigma+3*alpha[2](t[1], t[2])*b^2*a(t[2])
(15)
cond2 := collect(coeff(%%, I, 1), [diff(A(t2), t2), sin(C(t2))]);
alpha[2](t[1], t[2])*b^3*sin(C(t[2]))+(1/2)*a(t[2])*alpha[1](t[1], t[2])+diff(a(t[2]), t[2])
(16)
a(t2):= a; C(t2):=C; cond1 = 0; cond2 =0;
a
C
alpha[2](t[1], t[2])*b^3*cos(C)+(3/8)*alpha[2](t[1], t[2])*a^3-3*a*sigma+3*alpha[2](t[1], t[2])*b^2*a = 0
alpha[2](t[1], t[2])*b^3*sin(C)+(1/2)*a*alpha[1](t[1], t[2]) = 0
(17)
alpha[1]:=unapply(alpha[1],[t1,t2]);alpha[2]:=unapply(alpha[2],[t1,t2]);
proc (t1, t2) options operator, arrow; alpha[1] end proc
proc (t1, t2) options operator, arrow; alpha[2] end proc
(18)
remove(has, cond1, cos)^2+remove(has, cond2, sin)^2 = select(has, cond1, cos)^2+select(has, cond2, sin)^2;
((3/8)*alpha[2]*a^3-3*a*sigma+3*alpha[2]*b^2*a)^2+(1/4)*a^2*alpha[1]^2 = alpha[2]^2*b^6*cos(C)^2+alpha[2]^2*b^6*sin(C)^2
(19)
simplify(%,'trig');
(9/64)*a^2*(a^2*alpha[2]+8*alpha[2]*b^2-8*sigma)^2+(1/4)*a^2*alpha[1]^2 = alpha[2]^2*b^6
(20)
af_eq:=%;
(21)
b:=0.5*f0/(1-(1/3)^2);
.5625000000*f0
(22)
with(plots, implicitplot):
 f0 :=1; alpha[1]:=0.0087;alpha[2]:=2.5871;   b:=0.5*f0/(1-(1/3)^2);#change the value
0.87e-2
2.5871
.5625000000
(23)
af_eq;
curve1,curve2:=solve(af_eq, sigma):
A0:=2:
(9/64)*a^2*(2.5871*a^2-8*sigma+6.548596875)^2+0.1892250000e-4*a^2 = .2120125612
(24)
pu1:=implicitplot([sigma=curve2,sigma=curve1],sigma =-5..20, a = 0 .. A0,  numpoints = 200000, axes = box, axesfont=[SYMBOL, 14],labels = [sigma, a], labelfont = [SYMBOL, 16],color="red",tickmarks=[9,12],thickness=3,'view' = [-5 .. 20, 0 .. 6]):
pu2:=implicitplot([sigma=curve2,sigma=curve1],sigma =-5..20, a = A0 .. 10,linestyle=[1,3],  numpoints = 20000, axes = box, axesfont=[SYMBOL, 14],labels = [sigma, a], labelfont = [SYMBOL, 16],color="red",tickmarks=[9,12],thickness=3,'view' = [-5 .. 20, 0 .. 6]):
A0:=-2:
pu3:=implicitplot([sigma=curve2,sigma=curve1],sigma =-5..20, a = -10 .. A0, linestyle=[3,1], numpoints = 200000, axes = box, axesfont=[SYMBOL, 14],labels = [sigma, a], labelfont = [SYMBOL, 16],color="red",tickmarks=[9,12],thickness=3,'view' = [-5 .. 20, -6 .. 0]):
pu4:=implicitplot([sigma=curve2,sigma=curve1],sigma =-5..20, a = A0 .. 0,  numpoints = 20000, axes = box, axesfont=[SYMBOL, 14],labels = [sigma, a], labelfont = [SYMBOL, 16],color="red",tickmarks=[9,12],thickness=3,'view' = [-5 .. 20, -6 .. 0]):
pp1:=display([pu1,pu2,pu3,pu4]);
(25)
How can I merge these pictures into one
Like this one
Download merege_two_diagram.mw
