Question: Error, module member referencing is not supported in evalhf
What is the solution for this error.
Also when I run job in command prompt I also getting following errors
Warning, the restart command only works at the top level. It cannot be executed within a procedure, or from a file being read by the read statement.
But the same code runs fine in GUI.
